Tron Ares 4K dump
queeg500
Re: Tron Ares 4K dump
Post by queeg500 »
Attached is the dump for Tron Ares MKB20_v82_TRON-_ARES_2086.tgz
if some kind soul could add it to the public Database that would be grand.
https://drive.google.com/file/d/1zuyarK ... drive_link
Post by SamuriHL »
It's not attached. You'd have to host it somewhere and post a link. The forum won't allow attachments over a certain size.
queeg500
Post by queeg500 »
Thank you, spotted that. that's some response time - under 60 sec from post lol
direwolf
Post by direwolf »
https://drive.google.com/file/d/1fjrUh9 ... drive_link
UK 4k Disk Log.
Error: Failed to Open Disk
direwolf
Post by direwolf »
Anyone have any luck on this?
MrPenguin
Post by MrPenguin »
direwolf wrote: Tue Jan 13, 2026 7:06 pm Anyone have any luck on this?
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKVV also writes its TGZ dump files) and restarting MakeMKV?
GFly91
Post by GFly91 »
liels
Post by liels »
I downloaded a new keydb.cfg and am getting a dump file. However, mine appears to be asserting a v77 AACS instead of the v82 the posted dump files imply. Should I submit that too?
Type: Blu-ray
Label: TRON_ARES
Protection: AACS2.0/C v77
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Saved AACS dump file as /Users/phil/Library/MakeMKV/MKB20_v77_TRON-_ARES_8CF9.tgz
shockracer
Post by shockracer »
:roll:
liels wrote: Sun Feb 15, 2026 8:51 pm I downloaded a new keydb.cfg and am getting a dump file. However, mine appears to be asserting a v77 AACS instead of the v82 the posted dump files imply. Should I submit that too?
Type: Blu-ray
Label: TRON_ARES
Have you found a solution to the "Failed to open disc" issue?
