Dump File Submitted - The Phoenician Scheme 7E6D
NeuroDawg
#1 Post by NeuroDawg » Sun Jan 11, 2026 1:59 pm
sent via email
MKB20_v82_The_Phoenician_Scheme_7E6D
MrPenguin
Re: Dump File Submitted - The Phoenician 7E6D
#2 Post by MrPenguin » Sun Jan 11, 2026 2:02 pm
NeuroDawg wrote: Sun Jan 11, 2026 1:59 pm I've submitted a dump of "The Phoenician" version 7E6D
If this doesn't work, could you upload your TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file.
NeuroDawg
Re: Dump File Submitted - The Phoenician Scheme 7E6D
#3 Post by NeuroDawg » Sun Jan 11, 2026 2:09 pm
Here's the link.
https://drive.google.com/file/d/1agsBHk ... rive_linka
I'll give the keydb.cfg a go.
NeuroDawg
#4 Post by NeuroDawg » Sun Jan 11, 2026 2:16 pm
It's working now.
MrPenguin
#5 Post by MrPenguin » Sun Jan 11, 2026 2:20 pm
NeuroDawg wrote: Sun Jan 11, 2026 2:09 pm Here's the link.
Thanks, and can you also provide the AACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside the TGZ dump has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself. The MKB_RO.inf file is big, so it's a good idea to ZIP it up before uploading it.
MrPenguin
#6 Post by MrPenguin » Sun Jan 11, 2026 2:24 pm
NeuroDawg wrote: Sun Jan 11, 2026 2:16 pm It's working now.
That's odd, because the KEYDB doesn't have a complete entry for this disk?!
#7 Post by Coopervid » Sun Jan 11, 2026 3:35 pm
MrPenguin wrote: Sun Jan 11, 2026 2:24 pm
Maybe he used XReveal or AnyDVD. These post are really helpful. :oops:
