sent via email
MKB20_v82_The_Phoenician_Scheme_7E6D
Dump File Submitted - The Phoenician Scheme 7E6D
NeuroDawg
MrPenguin
Re: Dump File Submitted - The Phoenician 7E6D
If this doesn't work, could you upload your TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file.
NeuroDawg
Re: Dump File Submitted - The Phoenician Scheme 7E6D
Here's the link.
https://drive.google.com/file/d/1agsBHk ... rive_linka
I'll give the keydb.cfg a go.
NeuroDawg
It's working now.
MrPenguin
Thanks, and can you also provide the AACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside the TGZ dump has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself. The MKB_RO.inf file is big, so it's a good idea to ZIP it up before uploading it.
MrPenguin
That's odd, because the KEYDB doesn't have a complete entry for this disk?!
