Dump File Submitted - The Phoenician Scheme 7E6D
NeuroDawg
Post by NeuroDawg »
sent via email
MKB20_v82_The_Phoenician_Scheme_7E6D
MrPenguin
Re: Dump File Submitted - The Phoenician 7E6D
Post by MrPenguin »
NeuroDawg wrote: Sun Jan 11, 2026 1:59 pm I've submitted a dump of "The Phoenician" version 7E6D
If this doesn't work, could you upload your TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file.
NeuroDawg
Re: Dump File Submitted - The Phoenician Scheme 7E6D
Post by NeuroDawg »
Here's the link.
https://drive.google.com/file/d/1agsBHk ... rive_linka
I'll give the keydb.cfg a go.
NeuroDawg
Post by NeuroDawg »
It's working now.
MrPenguin
Post by MrPenguin »
NeuroDawg wrote: Sun Jan 11, 2026 2:09 pm Here's the link.
Thanks, and can you also provide the AACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside the TGZ dump has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself. The MKB_RO.inf file is big, so it's a good idea to ZIP it up before uploading it.
MrPenguin
Post by MrPenguin »
NeuroDawg wrote: Sun Jan 11, 2026 2:16 pm It's working now.
That's odd, because the KEYDB doesn't have a complete entry for this disk?!
MrPenguin wrote: Sun Jan 11, 2026 2:24 pm
Maybe he used XReveal or AnyDVD. These post are really helpful. :oops:
