And yet the discatt.dat file inside your TGZ dump still doesn't contain your disk's metadata?
Public KeyDB Disc Submissions
MrPenguin
Rico1977
Hmm, strange... Could it be that the dump file was created after the drive updated itself during the attempt to open the disc? I’m having a lot of trouble with this disc. I’ve only managed to get a dump file once out of all the many times I’ve tried…
This is the first disc I’ve ever had these kinds of problems with. I’ve tested it in another external drive that I also own, but it’s not possible to rip this disc in that one either.
Right now when I test it, MKV ends up saying that there is no disc in the drive.
MKV actually managed to open the disc once, but after a couple of seconds MKV started re-reading the disc, and that ended with me having to re-flash my Asus drive yet again.
keydb_helper
Don't repeatedly reflash your drive firmware. The firmware is cryptographically signed, so if it were somehow corrupted the drive would go into boot/DFU mode. Any perceived benefit to repeatedly reflashing the firmware is a side effect of the self-reboot stage of the update process. You can achieve an even greater effect by just powering down the drive entirely and waiting 10-15 seconds.Rico1977 wrote: Fri Jan 09, 2026 4:12 pm MKV actually managed to open the disc once, but after a couple of seconds MKV started re-reading the disc, and that ended with me having to re-flash my Asus drive yet again.
The following disc dumps have been added to the public keydb:
MKB20_v68_AQUAMAN_5D07
MKB20_v76_Singin'_in_the_Rain_57D7
MKB20_v77_Abenteuer_in_Rio_108C
MKB20_v77_All_Quiet_on_the_Western_Front_4F14
MKB20_v77_ARCANE_SEASON_1_-_DISC_1_DB22
MKB20_v77_ARCANE_SEASON_1_-_DISC_2_D316
MKB20_v77_ARCANE_SEASON_1_-_DISC_3_ADDE
MKB20_v77_BDROM_2A0E
MKB20_v77_Dantes_Peak_0FA0
MKB20_v77_DAS_CABINET_DES_DR_CALIGARI_-_4K_UHD_DD61
MKB20_v77_Rebirth_-_Die_Apokalypse_beginnt_3A80
MKB20_v77_Superman™-_The_Movie_FDBD
MKB20_v77_The_Ring_EE96
MKB20_v77_TWIN_PEAKS_-_FIRE_WALK_WITH_ME_-_4K_UHD_73EC
MKB20_v77_UP_UHD_A9CF
MKB20_v82_ATTENTION_LES_DEGATS_A96C
MKB20_v82_BIRTH_UHD_20B2
MKB20_v82_CAPTAIN_BLOOD_E218
MKB20_v82_Earthquake_DA0C
MKB20_v82_Fong_Sai_Yuk_46E4
MKB20_v82_Fong_Sai_Yuk_II_6B42
MKB20_v82_HOUSE_PARTY_308A
MKB20_v82_KISS_OF_THE_SPIDER_WOMAN_8F96
MKB20_v82_ONE_BATTLE_AFTER_ANOTHER_E66E
MKB20_v82_SS_EXPERIMENT_LOVE_CAMP_5A26
MKB20_v82_THE_DEAD_6362
MKB20_v82_TheHouseWithLaughingWindows
MKB20_v82_TheLifeOfChuck_UHD66_224C
MKB20_v82_THE_VISITOR_BF90
MKB20_v82_UHD_The_Astronaut_D425
MKB20_v82_WESTWORLD_-_UHD_5642
MKB20_v82_WICKED_FOR_GOOD_39D6
- Do not submit Stranger Things S2D2, S4D3, or S5D2
dave_or_did
My Pioneer disc dump didn't get added, so I'm trying again:
Peking Opera Blues - Arrow UHD
Disc type: UHD
Disc ID: ?
Disc Label: Peking Opera Blues UHD
Disc dump filename: MKB20_v82_Peking_Opera_Blues_-_UHD_0A14
Drive: BD-RW BDR-UD04
Drive firmware: 1.14_DFDL154556WL
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1cu-92c ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1L7_f7s ... drive_link
Disc type: UHD
Disc ID: ?
berrx
Disc type: BD-ROM
Disc ID: Not shown in MakeMKV log (AACS v82). Can be extracted from the provided dump.
Disc dump filename: MKB_v82_Special_Disc_BF88
Drive: HL-DT-ST BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link:
https://drive.google.com/file/d/1i43HJL ... 3Zr_5/view
Disc dump link:
MKB_RO.inf link:
Disc dump link:
TheOfficialRD3
Disc type: BD-ROM UHD
Disc ID: Deep Impact (Remastered) ???
Disc dump filename: MKB20_v77_Deep_Impact_(Remastered)_8C41
Drive: RS9201
Drive firmware: 1.03/ID72
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
Disc dump link:
I included a snip image of drive information in case i missed something. Not sure exactly what is needed for disc id
Drive: RS9201
Disc dump link:
The disc ID is not in the log. It is the SHA-1 of the Unit_Key_RO.inf file in the AACS folder on the disc.berrx wrote: Sat Jan 10, 2026 10:50 am Disc type: BD-ROM
MKB_RO.inf link:
Disc dump link:
The Disc ID is the SHA-1 of the Unit_Key_RO.inf file in the AACS folder on the disc.TheOfficialRD3 wrote: Sat Jan 10, 2026 1:40 pm Disc type: BD-ROM UHD
Drive: RS9201
Disc dump link:
TheOfficialRD3
Disc ID: 01D540C70F08A7018AC87D94FFB7231E60431EE5
Drive: RS9201
Disc dump link:
Drive: RS9201
Disc dump link:
berrx
Disc type: BD-ROM
Disc ID: 0x4B7B77294C41DC9FCB6B98908A34DB890CA688A3
MKB_RO.inf link:
https://drive.google.com/file/d/1hrJqGM ... drive_link
Disc dump link:
https://drive.google.com/file/d/1i43HJL ... drive_link
Apologies — I was not aware that the Disc ID was required. It is now included below.
MKB_RO.inf link:
Disc dump link:
Rico1977
Hi.
Disc type: UHD
Disc ID: 8cda0d39a8a383708af6735fc63dc92e8a7c42a7
Disc dump filename: MKB20_v82_MARVEL_STUDIOS'_THUNDERBOLTS_1A37
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link: https://drive.google.com/file/d/11pIItr ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1Ou7q-v ... sp=sharing
Thank you!!
Disc type: UHD
Drive: BW-16D1HT
Thank you!!
Rico1977
Thanks, I’ll try turning off the player next time.keydb_helper wrote: Sat Jan 10, 2026 2:55 amDon't repeatedly reflash your drive firmware. The firmware is cryptographically signed, so if it were somehow corrupted the drive would go into boot/DFU mode. Any perceived benefit to repeatedly reflashing the firmware is a side effect of the self-reboot stage of the update process. You can achieve an even greater effect by just powering down the drive entirely and waiting 10-15 seconds.Rico1977 wrote: Fri Jan 09, 2026 4:12 pm MKV actually managed to open the disc once, but after a couple of seconds MKV started re-reading the disc, and that ended with me having to re-flash my Asus drive yet again.
I should also mention that the player sounds very strange and strained when it tries to read this disc. Could it be the disc itself that’s faulty, causing the players to be unable to read it?
dave_or_did
Here's the Disc ID - 5ea38005be385f5be9fdcea618c3485eb0f762b8dave_or_did wrote: Sat Jan 10, 2026 8:47 am My Pioneer disc dump didn't get added, so I'm trying again:
Disc type: UHD
Disc ID: ?
whyemu
First post! I got a couple Luna Sea concert Blu-Rays that are not apart of the archive yet, so I'll be submitting this first one to make sure I'm doing it right, and then I got about 3 more so far that need to be decrypted.
Disc type: BD_ROM
Disc ID: 7F4F165ADF0E84E7ABB69954872D8D83CFA18B6E
Disc dump filename: UPXY_9037
Drive: BD-RW BDR-UD03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://1drv.ms/u/c/3a110ca3201c24b3/IQ ... 0?e=ZYhrnu
Disc dump link: https://1drv.ms/u/c/3a110ca3201c24b3/IQ ... I?e=MBkQOX
Disc type: BD_ROM
keydb_helper
Thanks to everyone who provided new disc dump files.
The following disc variants have been added to the public keydb:
MKB20_v77_Babylon_FF8D
MKB20_v77_DontLookNow_39F8
MKB20_v77_Four_Flies_On_Grey_Velvet_EACE
MKB20_v77_IlTerzoUomo_UHD_E032
MKB20_v77_MI_DEAD_RECKONING_PART_1_302B
MKB20_v77_THIS_IS_SPINAL_TAP_6794
MKB20_v77_WAR_OF_THE_WORLDS-REMASTERED_786B
MKB20_v77_What_Lies_Beneath_8C52
MKB20_v82_ALTERED_STATES_C08A
MKB20_v82_BDROM_4C22
MKB20_v82_BLU-RAY_UHD_10DC
MKB20_v82_How_to_Train_Your_Dragon_(2025)_EEDA
