New to MakeMKV - UHD Rips Not Working
AP33r43
Post by AP33r43 »
I've recently started trying to use MakeMKV to back up some blu-rays and have run into an issue that I don't understand. I've tried looking through the forums for a solution but not found any that explain my situation or how to fix it (or at least, none that I understood).
It seems like ripping regular blu-rays works, but ripping UHD blu-rays runs into what seems to be the same issue each time. I believe my drive should work as it is displayed in the UI for this, but it just... isn't. From what I understand, sometimes disks simply need a key generated or whatever by submitting them for that on here, but I don't know how to even tell if that's the case.
My drive appears as so:
OS device name: \Device\CdRom2
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: [REDACTED]
Firmware date: 2020-06-15
Highest AACS version: 82
Drive platform: RS8A10
Firmware version: 1.14
However, if I try to read various UHD blu-rays, I end up with the same thing. A log spam of things like:
  • 002004:0000 Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom2'
  • 002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom2'
Followed by:
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Saved AACS dump file as [REDACTED]
Can someone please explain what I am even looking at or where to go from here?
MrPenguin
Re: New to MakeMKV - UHD Rips Not Working
Post by MrPenguin »
AP33r43 wrote: Fri Jan 09, 2026 9:41 am It seems like ripping regular blu-rays works, but ripping UHD blu-rays runs into what seems to be the same issue each time. I believe my drive should work as it is displayed in the UI for this, but it just... isn't. From what I understand, sometimes disks simply need a key generated or whatever by submitting them for that on here, but I don't know how to even tell if that's the case.
That drive should read UHDs fine. Perhaps just wait until the UHD disk is recognized by Windows Explorer before starting MakeMKV?
AP33r43
Post by AP33r43 »
I tried a few things and what seems to have solved it is using a different USB port. Probably my motherboard's USB stuff being shit as usual.
