Public KeyDB Disc Submissions
jojojiggy
MKb2_v77_The Firm (Remastered)_39F
Post by jojojiggy »
Disc type: UHD
Disc ID: This isn't showing up in the log file. I tried getting chat GPT to answer why but still can't get it
Disc dump filename: MKb2_v77_The Firm (Remastered)_39F
Drive: HL-DT-ST HL-DT-ST BD-RE BU40N, firmware 1.05
Drive firmware: 2124-04-23 13:47
LibreDrive status: Possible, not yet enabled Drive platform: MT1959
MKB_RO.ini, and the dump file are here:
https://drive.google.com/drive/folders/ ... drive_link
MrPenguin
Re: MKb2_v77_The Firm (Remastered)_39F
Post by MrPenguin »
jojojiggy wrote: Thu Jan 08, 2026 10:00 pm Disc dump filename: MKb2_v77_The Firm (Remastered)_39F
You have not yet enabled LibreDrive, which means that your TGZ dump file doesn't contain some crucial disk metadata and so cannot be used.
jojojiggy wrote: Thu Jan 08, 2026 10:00 pm Disc type: UHD
You need to flash your drive to enable libredrive and UHD readability therefore your dump file is no good. Also, the Disc ID is the SHA-1 of the Unit_Key_RO.inf file located in the AACS folder on the disc.
jojojiggy
Post by jojojiggy »
MartyMcNuts wrote: Thu Jan 08, 2026 10:45 pm
Ok I will. ChatGPT told me I didn't need to. haha. After my initial post I used the KeyDB Helper and I found the DiscId: 0x81C28C418FEEDBDDC3D4A98F9961C71BD3775834.
It says that it's not in the database
jojojiggy
Post by jojojiggy »
jojojiggy wrote: Thu Jan 08, 2026 10:58 pm
Update. I flashed the drive and it seems to be working now! Thanks! I'm not sure why KeyDB Helper said it wasn't in the database.
Post by SamuriHL »
Don't listen to ChatGPT. It has no idea what it's talking about. Flash your drive and post a newly generated image.
MrPenguin
Post by MrPenguin »
jojojiggy wrote: Thu Jan 08, 2026 11:30 pm Update. I flashed the drive and it seems to be working now! Thanks! I'm not sure why KeyDB Helper said it wasn't in the database.
By the sound of it, your disk is in MakeMKV's own "hashed keys" database. However, it currently only has a partial entry in the public KEYDB.cfg file.
It should be possible to complete your disk's KEYDB entry if you could provide a new discatt.dat file now that you've enabled LibreDrive. To do this,
just use MakeMKV to start creating an encrypted disk back-up into a temporary directory, wait for the discatt.dat file to appear (it should be one of the very first files created), copy the file to a safe location, and then abort the back-up.
dave_or_did
Post by dave_or_did »
Peking Opera Blues UHD
Disc type: UHD
Disc ID: ?
Disc Label: Peking Opera Blues UHD
Disc dump filename: MKB20_v82_Peking_Opera_Blues_-_UHD_0A14
Drive: BD-RW BDR-UD04
Drive firmware: 1.14_DFDL154556WL
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1cu-92c ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1L7_f7s ... drive_link
MKVDUDE
Post by MKVDUDE »
Another 2 please!
Disc type: UHD
Disc dump filenames:
MKB20_v82_THE_VISITOR_BF90.tgz
MKB20_v82_WESTWORLD_-_UHD_5642.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-N14LWh7QB3
Many thanks!
Rico1977
Post by Rico1977 »
Hi.
This is the first time I’m asking for help here, and I hope I’ve managed to provide everything requested below.
Disc type: UHD
Disc ID: ed19654dc10e730b6ab1aeabd943a66069c43c00
Disc dump filename: MKB20_v72_Jaws_E7E9
Drive: BW-16D1HT
Drive firmware: 3.10
Did you sync the public keydb within the last 15 minutes? yes
MKB_RO.inf link: https://drive.google.com/file/d/1kIhPVh ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1e9E-Oz ... sp=sharing
This disc with JAWS has been giving me problems; I’ve had to reflash my player twice after trying to rip it :wink: .
Thank you.
SkyRayN
Post by SkyRayN »
Disc type:
Disc ID:608bb95622d88300572f90660b954152862c0f9b
Disc dump filename:MKB_v82_VOYAGERS_794E
Drive:Pioneer BD-RW BDR-TD04D
Drive firmware:Pioneer RS1040
LibreDrive status:Possible, but very unlikely to happen
Did you sync the public keydb within the last 15 minutes? : Yes
Have you verified that all submission links are accessible in incognito/private browsing? : Yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):included in Disc dump
Disc dump link:
https://drive.google.com/file/d/1hbFu0W ... drive_link
kasko
Post by kasko »
MrPenguin
Post by MrPenguin »
Rico1977 wrote: Fri Jan 09, 2026 1:06 pm This disc with JAWS has been giving me problems; I’ve had to reflash my player twice after trying to rip it :wink: .
Your UHD drive still hasn't enabled LibreDrive. What does MakeMKV's "Info" window say?
Rico1977
Post by Rico1977 »
MrPenguin wrote: Fri Jan 09, 2026 3:02 pm
It says ‘enabled’ for the LibreDrive status.
Rico1977
Post by Rico1977 »
This is the first disc I’ve had these kinds of problems with. I’ve also tested it in a Panasonic player that I own, but it’s not possible to rip this disc in that player either.
Right now when I test it, MKV ends up saying that there is no disc in the drive.
Once, MKV managed to open the disc, but before I had time to do anything it started re-reading the disc, and it ended with me having to re-flash my Asus drive yet again.
