Tron Ares 4K dump
executor999
Tron Ares 4K dump
Post by executor999 » Wed Jan 07, 2026 4:43 pm
File download removed.
MrPenguin
Re: Tron Ares 4K dump
Post by MrPenguin » Wed Jan 07, 2026 5:55 pm
Dump file on Google Drive (unrestricted access)
The latest KEYDB.cfg file already contains this disk.
Post by SamuriHL » Wed Jan 07, 2026 6:23 pm
Yes it does and I was thankful for that. LOL Mine just arrived.
executor999
Post by executor999 » Wed Jan 07, 2026 6:36 pm
Thanks for the replies. I did a search for Tron Ares before posting and no search results. I won't touch the KEYDB website. All I get are major security warnings when I try to visit so I guess I will just wait.
MrPenguin
Post by MrPenguin » Wed Jan 07, 2026 6:54 pm
Those warnings are probably because the site only supports HTTP and not HTTPS.
Post by Woodstock » Wed Jan 07, 2026 7:10 pm
Something I agree with - there are a LOT of sites that have no reason to spend hundreds of dollars or euros each year to keep HTTPS active, and every year, it gets MORE expensive. You either get "free" certificates that require manual installation every 30 days, or more expensive ones that start at USD 50 per year.
I maintain over a dozen sites. None of which have commercial value. None of which have certificates. I also maintain several sites that DO have commercial value; two of which cost just shy of USD 500 each to "protect" for a year (wildcard certificates are NOT cheap!).
The keydb database is free; no one is charged for using it. There are still costs associated with it, but why add another one?
executor999
Post by executor999 » Wed Jan 07, 2026 7:11 pm
Thanks the heads up. I was able to download the KeyDB file and the Helper App. This is the first time I've ever had a problem with ripping a movie disc and I don't frequent this site often. Sorry for posting a redundant post, and in the wrong area. Despite all the reading I did, I thought I was following instructions correctly. I'm sure you get bombarded every day with useless posts
Thank you for all you do and pointing me in the right direction. As I'm writing this I am now successfully ripping Tron Ares UHD. :)
Post by SamuriHL » Wed Jan 07, 2026 7:32 pm
If you're on Windows you can use my tool which is a front end for FindVUK. That will allow you to see information about your discs and also keep the KeyDB sync'd and installed where MakeMKV can use it.
viewtopic.php?f=12&t=16883&p=166510#p166510
executor999
Post by executor999 » Wed Jan 07, 2026 7:33 pm
Yes, it worked perfectly. Thanks for creating it and making it available.
aostang
Post by aostang » Thu Jan 08, 2026 6:34 pm
I'm a little confused on this. I'm on Linux and thought that the _private_data.tar file in the .MakeMKV folder was what contained the keys. Mine has an update date of this morning. I don't have a separate keys file in that folder but everything has worked up until now. Am I missing something that I need to update manually?
Post by SamuriHL » Thu Jan 08, 2026 8:43 pm
The public keydb is a separate mechanism for obtaining keys. MakeMKV has its own process, however, if you drop a KEYDB.cfg file in the data directory (where the tgz files are created that you email in) it can ALSO use that as a source of keys.
aostang
Post by aostang » Thu Jan 08, 2026 9:01 pm
Yep just did that and we're good! :D
Post by SamuriHL » Thu Jan 08, 2026 10:34 pm
Just remember to update it periodically as it's constantly getting new keys added to it at random intervals throughout each day.
j-h-s
Post by j-h-s » Mon Jan 12, 2026 5:41 am
MKB20_v82_TRON-_ARES_2086 - uk 4k - submitted
Disposable9
Post by Disposable9 » Mon Jan 12, 2026 2:36 pm
Submitted MKB20_v82_TRON-_ARES_2086.tgz.
