Public KeyDB Disc Submissions
99gagamel
#1486 Post by 99gagamel » Tue Jan 06, 2026 8:27 am
Disc Type: UHD (Moonfall)
Disc ID:v06.3 id=EC0D0F39EDA7
Disc Dump Filename: MKB20_v76_UHD_MNF_9E6D,tgz
Drive: BH16NS55
Drive Firmware: 1.05
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1ToC-Cd ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1lyWeQZ ... p=sharingg
jwwmah
#1487 Post by jwwmah » Wed Jan 07, 2026 4:30 am
Disc type: UHD
Disc ID: ???
Disc dump filename: MKB20_v77_THE_ADVENTURES_OF_BARON_MUNCHAUSEN_6675
Drive: BD-RE BP60NB10
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link:
Disc dump link:
LaunderedShirt
#1488 Post by LaunderedShirt » Wed Jan 07, 2026 11:23 pm
Disc type: UHD
Disc ID: 56e6a0d2bccaf1389b11fac5bc954596141842c6
Disc dump filename: MKB20_v77_The_Departed_7E59.tgz
Drive: BP60NB10
MKB_RO.inf link: https://www.dropbox.com/scl/fi/w3h5ztxe ... dhlqt&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/7knna8op ... a44bc&dl=0
bwcgrx
#1489 Post by bwcgrx » Thu Jan 08, 2026 5:39 am
I have what appears to be a new variant of Constantine UHD.
Disc type: UHD
Disc ID: 4FBDCD9284673FFC50785F6ABD83F0EAB63E6668
Disc dump filename: MKB20_v77_Constantine_F999.tgz
Drive: BD-RW BDR-UD04
Drive firmware: 1.14
MKB_RO.inf link: https://drive.google.com/file/d/1bwpgsO ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1fTDC5Z ... sp=sharing
MrPenguin
#1490 Post by MrPenguin » Thu Jan 08, 2026 11:03 am
bwcgrx wrote: Thu Jan 08, 2026 5:39 am I have what appears to be a new variant of Constantine UHD.
Do you also have access to a LG/ASUS/Buffalo UHD drive please? This BDR-UD04 drive means that some of the disk's metadata inside the TGZ dump file is unreadable.
keydb_helper
#1491 Post by keydb_helper » Thu Jan 08, 2026 11:20 am
Disc type: UHD
MKB_RO.inf link: ...
Disc dump link: ...
Hey bwcgrx, thank you for following the submission template. Unfortunately, your Pioneer BDR-UD04 disc drive is particularly problematic for the purposes of the keydb...
...is what I had repeated for the past 100 pages of this thread.
But that is no longer the case. As long as your drive is supported by LibreDrive, all disc dump files are now suitable for public keydb processing.
This applies to all disc dump files, of all disc types, from all relevant drive manufacturers. Pioneer drives are now supported to the exact same extent as LG, Asus, and Buffalo drives for both AACS 1.0 and AACS 2.0.
The following new UHD titles have been added to the public keydb:
MKB20_v77_Babe_E7AE
MKB20_v77_Babe-_Pig_in_the_City_9B64
MKB20_v77_CURE_7872
MKB20_v77_Fast_X_3E2F
MKB20_v77_Gladiator_II_D2BD
MKB20_v77_LEON_5149
MKB20_v77_Mildred_Pierce_0256
MKB20_v77_Revenge_of_the_Pink_Panther_88F0
MKB20_v77_The_Pink_Panther_Strikes_Again_C44C
MKB20_v82_DAVID_BYRNE'S_AMERICAN_UTOPIA_7154
MKB20_v82_L_IsolaDell_Ingiustizia_Alcatraz_3AD6
MKB20_v82_THE_GHOST_UHD_0F0F
MKB20_v82_The_Monkey_A908
KeyDB Download
#1492 Post by SamuriHL » Thu Jan 08, 2026 11:50 am
Oh damn wow!
startheater
#1493 Post by startheater » Thu Jan 08, 2026 2:46 pm
Lord of the Rings - THE TWO TOWERS 4K Extended Edition (MIDDLE EARTH ULTIMATE COLLECTOR'S EDITION)
Disc type: UHD
Disc ID: 98C0DB460AC63AD051ECCDB2787FAC55483A84F6
Disc dump filename: MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_(EXT_)_PT_1_D551
Drive: N/A
Drive firmware: N/A
LibreDrive status: N/A
MKB_RO.inf link: https://drive.google.com/file/d/1I-Bwa9 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1-sihzD ... sp=sharing
I didn't fill anything for the drive, I have the movie on my HDD. Thank you!
MrPenguin
#1494 Post by MrPenguin » Thu Jan 08, 2026 3:31 pm
startheater wrote: Thu Jan 08, 2026 2:46 pm Lord of the Rings - THE TWO TOWERS 4K Extended Edition (MIDDLE EARTH ULTIMATE COLLECTOR'S EDITION)
The latest KEYDB.cfg file already contains this disk, which is lucky because a TGZ dump file needs to be created directly from the UHD disk.
Also, you would need to use MakeMKV's "disk backup" functionality to copy a UHD to your hard drive, as otherwise your disk copy will be bus encrypted by your UHD drive.
startheater
#1495 Post by startheater » Thu Jan 08, 2026 3:38 pm
MrPenguin wrote: Thu Jan 08, 2026 3:31 pm
The latest KEYDB.cfg file already contains this disk, which is lucky because a TGZ dump file needs to be created directly from the disk.
Then why do I receive an error whenever I try to open the file, either with makemkv or directly with the MPC-HC player? For the player, I have the keydb file saved in AppData\Roaming\AACS.
This is the log directly from makemkv:
MakeMKV v1.18.2 win(x64-release) started
Debug logging enabled, log will be saved as ...MakeMKV_log.txt
The program can't find any usable optical drives.
Opening files on harddrive at ...MIDDLE EARTH ULTIMATE COLLECTOR'S EDITION/THE LORD OF THE RINGS 4K/EXTENDED/02 THE TWO TOWERS/LOTR_THE_TWO_TOWERS_PT1
Evaluation version, 5 day(s) out of 30 remaining
Saved AACS dump file as ...MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_(EXT_)_PT_1_D551.tgz
DEBUG: Code 0 at K/7I6&O",`|u5 8d:213132721
DEBUG: Code 0 at K/7I6&O",`|u5 8d:121263084
Can you please help me? Thank you.
MrPenguin
#1496 Post by MrPenguin » Thu Jan 08, 2026 4:03 pm
startheater wrote: Thu Jan 08, 2026 3:38 pm Then why do I receive an error whenever I try to open the file, either with makemkv or directly with the MPC-HC player?
Your dump on your HDD is useless without also knowing the RDK used to encrypt it, and we have no way of knowing your RDK.
You need to go back to your UHD so that MakeMKV can create a new HDD copy without bus encryption.
startheater
#1497 Post by startheater » Thu Jan 08, 2026 4:19 pm
MrPenguin wrote: Thu Jan 08, 2026 4:03 pm Your dump on your HDD is useless without also knowing the RDK used to encrypt it, and we have no way of knowing your RDK.
You need to go back to your UHD.
I no longer have access to the original disk. Is there a workaround that I can apply to repair and open this file? Or, since makemkv cannot decrypt this file, can I assume that the file is already unusable and delete it?
I don't know if it helps, but this movie is made up of two parts/discs; the second part/disc is perfectly usable. Can I somehow use files from the second disk to "repair" the first one? In the first disc, I have these folders: Aacs, bdmv, certificate; in the second disc, I have Bdmv, certificate, makemkv (that contains Aacs and Cmap).
Maybe I have some corrupted files on the first disc, I don't know.
Thank you.
MrPenguin
#1498 Post by MrPenguin » Thu Jan 08, 2026 5:02 pm
startheater wrote: Thu Jan 08, 2026 4:19 pm I no longer have access to the original disk. Is there a workaround that I can apply to repair and open this file?
To salvage these files, you would need to know the RDK used to encrypt them. And since you have no way of obtaining this RDK, your copies are useless.
startheater wrote: Thu Jan 08, 2026 4:19 pm I don't know if it helps, but this movie is made up of two parts/discs; the second part/disc is perfectly usable.
Then MakeMKV must already have disabled bus encryption before you copied the second disk.
startheater wrote: Thu Jan 08, 2026 4:19 pm Can I somehow use files from the second disk to "repair" the first one?
No.
sam14229
#1499 Post by sam14229 » Thu Jan 08, 2026 8:02 pm
Submission for Warfare UHD (Italian version)
Label: Warfare_UHD
Timestamp: 2025-10-29 12:09:39
Protection: AACS2.0/C v82
Data capacity: 49.39 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Dump file name: MKB20_v82_WARFARE_886C.tgz
Dump file url: https://drive.proton.me/urls/Y81XWP99F8#RsCSIEwabCLi
Thank you
MrPenguin
#1500 Post by MrPenguin » Thu Jan 08, 2026 9:42 pm
sam14229 wrote: Thu Jan 08, 2026 8:02 pm Dump file name: MKB20_v82_WARFARE_886C.tgz
I think the latest KEYDB.cfg file already contains this disk
