Public KeyDB Disc Submissions
barnstarmer
Post by barnstarmer »
Face/Off from Kino Lorber
Older disc, but the current keydb.cfg doesn't have this disc id.
Disk Type: UHD
Disc ID: 0xE8D5F4C3857FB01B2E4ADD4479623FD7E6AE8220
Disc Dump Filename: MKB20_v77_Face_Off_BF55.tgz
Drive: ASUS BC-12D2HT
Firmware: LG WH16NS60 1.02MK
Libredrive Status: Enabled
MKB_RO.inf link: [deleted]
Disc dump link: [deleted]
99gagamel
Post by 99gagamel »
Disc Type: UHD
Disc ID:=E064BA3E3F81
Disc Dump Filename: MKB20_v77_LEON_5149.tgz
Drive: BW-1601HT
Drive Firmware: 3.01
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1LvpGvm ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1YBB93- ... sp=sharing
Mossy
Post by Mossy »
MrPenguin wrote: Sat Jan 03, 2026 4:00 pm
Mossy wrote: Sat Jan 03, 2026 12:48 pm Thank you but i still can't open
oh Thank Now I can open it now Thank again
99gagamel
Post by 99gagamel »
Disc Type: UHD (Moonfall)
Disc ID:v06.3 id=EC0D0F39EDA7
Disc Dump Filename: MKB20_v76_UHD_MNF_9E6D,tgz
Drive: BH16NS55
Drive Firmware: 1.05
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1ToC-Cd ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1lyWeQZ ... p=sharingg
jwwmah
Post by jwwmah »
Disc type: UHD
Disc ID: ???
Disc dump filename: MKB20_v77_THE_ADVENTURES_OF_BARON_MUNCHAUSEN_6675
Drive: BD-RE BP60NB10
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link:
Disc dump link:
LaunderedShirt
Post by LaunderedShirt »
Disc type: UHD
Disc ID: 56e6a0d2bccaf1389b11fac5bc954596141842c6
Disc dump filename: MKB20_v77_The_Departed_7E59.tgz
Drive: BP60NB10
MKB_RO.inf link: https://www.dropbox.com/scl/fi/w3h5ztxe ... dhlqt&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/7knna8op ... a44bc&dl=0
bwcgrx
Post by bwcgrx »
I have what appears to be a new variant of Constantine UHD.
Disc type: UHD
Disc ID: 4FBDCD9284673FFC50785F6ABD83F0EAB63E6668
Disc dump filename: MKB20_v77_Constantine_F999.tgz
Drive: BD-RW BDR-UD04
Drive firmware: 1.14
MKB_RO.inf link: https://drive.google.com/file/d/1bwpgsO ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1fTDC5Z ... sp=sharing
MrPenguin
Post by MrPenguin »
bwcgrx wrote: Thu Jan 08, 2026 5:39 am I have what appears to be a new variant of Constantine UHD.
Do you also have access to a LG/ASUS/Buffalo UHD drive please? This BDR-UD04 drive means that some of the disk's metadata inside the TGZ dump file is unreadable.
keydb_helper
Post by keydb_helper »
Disc type: UHD
MKB_RO.inf link: ...
Disc dump link: ...
Hey bwcgrx, thank you for following the submission template. Unfortunately, your Pioneer BDR-UD04 disc drive is particularly problematic for the purposes of the keydb...
...is what I had repeated for the past 100 pages of this thread.
But that is no longer the case. As long as your drive is supported by LibreDrive, all disc dump files are now suitable for public keydb processing.
This applies to all disc dump files, of all disc types, from all relevant drive manufacturers. Pioneer drives are now supported to the exact same extent as LG, Asus, and Buffalo drives for both AACS 1.0 and AACS 2.0.
The following new UHD titles have been added to the public keydb:
MKB20_v77_Babe_E7AE
MKB20_v77_Babe-_Pig_in_the_City_9B64
MKB20_v77_CURE_7872
MKB20_v77_Fast_X_3E2F
MKB20_v77_Gladiator_II_D2BD
MKB20_v77_LEON_5149
MKB20_v77_Mildred_Pierce_0256
MKB20_v77_Revenge_of_the_Pink_Panther_88F0
MKB20_v77_The_Pink_Panther_Strikes_Again_C44C
MKB20_v82_DAVID_BYRNE'S_AMERICAN_UTOPIA_7154
MKB20_v82_L_IsolaDell_Ingiustizia_Alcatraz_3AD6
MKB20_v82_THE_GHOST_UHD_0F0F
MKB20_v82_The_Monkey_A908
Post by SamuriHL »
Oh damn wow!
startheater
Post by startheater »
Lord of the Rings - THE TWO TOWERS 4K Extended Edition (MIDDLE EARTH ULTIMATE COLLECTOR'S EDITION)
Disc type: UHD
Disc ID: 98C0DB460AC63AD051ECCDB2787FAC55483A84F6
Disc dump filename: MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_(EXT_)_PT_1_D551
Drive: N/A
Drive firmware: N/A
LibreDrive status: N/A
MKB_RO.inf link: https://drive.google.com/file/d/1I-Bwa9 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1-sihzD ... sp=sharing
I didn't fill anything for the drive, I have the movie on my HDD. Thank you!
MrPenguin
Post by MrPenguin »
startheater wrote: Thu Jan 08, 2026 2:46 pm Lord of the Rings - THE TWO TOWERS 4K Extended Edition (MIDDLE EARTH ULTIMATE COLLECTOR'S EDITION)
The latest KEYDB.cfg file already contains this disk, which is lucky because a TGZ dump file needs to be created directly from the UHD disk.
Also, you would need to use MakeMKV's "disk backup" functionality to copy a UHD to your hard drive, as otherwise your disk copy will be bus encrypted by your UHD drive.
startheater
MrPenguin wrote: Thu Jan 08, 2026 3:31 pm
The latest KEYDB.cfg file already contains this disk, which is lucky because a TGZ dump file needs to be created directly from the disk.
Then why do I receive an error whenever I try to open the file, either with makemkv or directly with the MPC-HC player? For the player, I have the keydb file saved in AppData\Roaming\AACS.
This is the log directly from makemkv:
MakeMKV v1.18.2 win(x64-release) started
Debug logging enabled, log will be saved as ...MakeMKV_log.txt
The program can't find any usable optical drives.
Opening files on harddrive at ...MIDDLE EARTH ULTIMATE COLLECTOR'S EDITION/THE LORD OF THE RINGS 4K/EXTENDED/02 THE TWO TOWERS/LOTR_THE_TWO_TOWERS_PT1
Evaluation version, 5 day(s) out of 30 remaining
Saved AACS dump file as ...MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_(EXT_)_PT_1_D551.tgz
DEBUG: Code 0 at K/7I6&O",`|u5 8d:213132721
DEBUG: Code 0 at K/7I6&O",`|u5 8d:121263084
Can you please help me? Thank you.
MrPenguin
Post by MrPenguin »
startheater wrote: Thu Jan 08, 2026 3:38 pm Then why do I receive an error whenever I try to open the file, either with makemkv or directly with the MPC-HC player?
Your dump on your HDD is useless without also knowing the RDK used to encrypt it, and we have no way of knowing your RDK.
You need to go back to your UHD so that MakeMKV can create a new HDD copy without bus encryption.
startheater
MrPenguin wrote: Thu Jan 08, 2026 4:03 pm Your dump on your HDD is useless without also knowing the RDK used to encrypt it, and we have no way of knowing your RDK.
You need to go back to your UHD.
I no longer have access to the original disk. Is there a workaround that I can apply to repair and open this file? Or, since makemkv cannot decrypt this file, can I assume that the file is already unusable and delete it?
I don't know if it helps, but this movie is made up of two parts/discs; the second part/disc is perfectly usable. Can I somehow use files from the second disk to "repair" the first one? In the first disc, I have these folders: Aacs, bdmv, certificate; in the second disc, I have Bdmv, certificate, makemkv (that contains Aacs and Cmap).
Maybe I have some corrupted files on the first disc, I don't know.
Thank you.
