kikkoman
#196
Post
by kikkoman » Thu Jan 01, 2026 8:29 pm
Hi ya'll.
So I'm new to this, just bought Pioneer BDR-XD08B with drive details below.
If it says LibreDrive enabled, does this mean I can start ripping 4K UHD discs? Or do I still need a separate firmware for my drive to do so.
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.02
Firmware date: 2022-12-27
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02
#197
Post
by MartyMcNuts » Thu Jan 01, 2026 9:38 pm
kikkoman wrote: Thu Jan 01, 2026 8:29 pm
Hi ya'll.
Revision: 1.02
This drive can't read 4K UHD discs as it is not a UHD model. It can't currently be cross-flashed with the available tools as the firmware is post 11/2022. Having libredrive enabled for standard blu-ray is the best this drive can get for now.
It may be possible in the future to cross-flash so check the forum every now and then for updates.
MrPenguin
#198
Post
by MrPenguin » Thu Jan 01, 2026 10:21 pm
MartyMcNuts wrote: Thu Jan 01, 2026 9:38 pm
Definitely still hang on to it though, because it's still a good drive. And I'm sure Mike is working on the problem too.
kikkoman
#199
Post
by kikkoman » Fri Jan 02, 2026 12:25 am
MrPenguin wrote: Thu Jan 01, 2026 10:21 pm
crap...that's what I get for buying without checking forums first. bought back during Black Friday but was still expensive.
good to know though thanks.
lomatrasu
#200
Post
by lomatrasu » Thu Jan 22, 2026 6:12 pm
Hi All,
this is my current drive info
OS device name: /dev/rdisk4
Product: BD-RW BDR-S13U
Revision: 1.05
Serial number:
Firmware date: 2023-08-01
Highest AACS version: 26
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.05/ID43
what are my best options?
can I do 4K UHD by downgrading firmware or is LibreDrive with Standard 4K my best case scenario?
#201
Post
by MartyMcNuts » Thu Jan 22, 2026 10:03 pm
lomatrasu wrote: Thu Jan 22, 2026 6:12 pm
Hi All,
Revision: 1.05
Serial number:
Nothing needs to be done. It is already ready to go. Just insert a UHD disc and rip it.
Szary Kot
#202
Post
by Szary Kot » Sun Feb 01, 2026 9:32 pm
Will there be a chance in the near future to unlock BDXL drives, e.g. Pioneer BDR X13JBK, to read UHD formats? Is there anything more known yet?
Licensed User MakeMKV
#203
Post
by Coopervid » Sun Feb 01, 2026 9:55 pm
Szary Kot wrote: Sun Feb 01, 2026 9:32 pm
Post your Makemkv info. If pre Dec. 2022 there is a chance.
Szary Kot
#204
Post
by Szary Kot » Sun Feb 01, 2026 10:21 pm
I have the opportunity to purchase it. The firmware is 100% newer than 12-2022. I don't know what to do, hence my question.
#205
Post
by MartyMcNuts » Sun Feb 01, 2026 10:31 pm
Szary Kot wrote: Sun Feb 01, 2026 10:21 pm
Depending on the price, is probably worth the risk anyway, even if it can never be made to read UHD as it'd be a good blu-ray ripper regardless and near impossible to find.
