Pioneer bdr 209 and Pioneer bdr 209m
jasontuk
Re: Pioneer bdr 209 and Pioneer bdr 209m
Hi, can I use my Pioneer BDR-209M drive to rip UHDs and if so can someone please tell me how? Thanks
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.51
Serial number: NJDL025412WL
Firmware date: 2018-05-08
Bus encryption flags: 13
Highest AACS version: 82
Drive platform: RS8600
Firmware version: 1.51/ID60
OS device name: E:
Revision: 1.51
PM sent.jasontuk wrote: Sat Dec 27, 2025 11:11 am Hi, can I use my Pioneer BDR-209M drive to rip UHDs and if so can someone please tell me how? Thanks
OS device name: E:
Revision: 1.51
mmn110
Hi all -- recently acquired a BDR-209BDK. I was wondering if any firmware was available which would allow it to read UHD discs.
OS device name: F:
Product: BD-RW BDR-209D
Revision: 1.51
Serial number:
Drive platform: RS8601
Firmware version: 1.51/ID61
PM is coming.mmn110 wrote: Mon Dec 29, 2025 11:07 am Hi all -- recently acquired a BDR-209BDK. I was wondering if any firmware was available which would allow it to read UHD discs.
Drive Information OS device name: F: Manufacturer: PIONEER Product: BD-RW BDR-209D Revision: 1.51 Serial number: Firmware date: 2018-05-08 Bus encryption flags: 13 Highest AACS version: 82 LibreDrive Information Status: Enabled Drive platform: RS8601 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.51/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
AviTMC
Hi Cooper,
I have both Pioneer BDR-209D and BDR-209M drives. My OS on both computers is Windows 10, but for some reason I cannot access the System Information of the optical drives. I tried both Device Manager and System Information. The details of the drives are not showing on the right pane of each window. Any assistance is greatly appreciated. I'm trying to get you the drive information of both drives, so I can see if I can flash them.
Thank you, sir.
Thank you, sir.
Arki90
Hello all,
I've bought a used external Pioneer (Buffalo) drive in order to be able to read some UHD-discs which my currently used BU40N doesn't recognize.
Mostly large triple layer BRs are not recognized by my BU40N.
Long story short, is it possible to flash the Pioneer drive to be able to recognize UHD-discs?
Here are the information which MakeMKV shows me:
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-209M
Revision: 8.11
Serienummer:
Firmware-Datum: 2014-01-16
Highest AACS version: 76
Firmware version: 8.11/ID52
Would be great if someone could help me with this.
Thanks and have a good new year!
OS-Gerätename: D:
Produzent: PIONEER
Revision: 8.11
Serienummer:
Sir Nakamura
Hi, can I use my Pioneer BDR-209M drive - inside a Buffalo Case (BRXL-16U3-EU) to rip UHDs and if so can someone please tell me how?
OS-Gerätename: E:
Produzent: PIONEER
Revision: 8.11
Serienummer:
OS-Gerätename: E:
Produzent: PIONEER
Revision: 8.11
Serienummer:
You need to install Makemkv and run it. It will show then the information you should post.AviTMC wrote: Wed Dec 31, 2025 4:38 am Hi Cooper,
Thank you, sir.
PM sent.Arki90 wrote: Wed Dec 31, 2025 11:22 am Hello all,
OS-Gerätename: D:
Produzent: PIONEER
Revision: 8.11
Serienummer:
PM sent.Sir Nakamura wrote: Wed Dec 31, 2025 6:06 pm Hi, can I use my Pioneer BDR-209M drive - inside a Buffalo Case (BRXL-16U3-EU) to rip UHDs and if so can someone please tell me how?
OS-Gerätename: E:
Produzent: PIONEER
Revision: 8.11
Serienummer:
YukiNyan
Finally found the time to try and flash my drive.
OS device name: /dev/sr0
Revision: 1.10
Serial number: XXXXXXXXXX
Firmware date: 2013-09-10
Highest AACS version: 57
Firmware version: 1.10/ID60
Revision: 1.10
Sir Nakamura
Hello Coopervid
thank you so much for the flashing instructions and software!
Before flashing, I'd like to ask you a question. In a post the same drive (BDR-209M) - also from a Buffalo case - was flashed to a BDR-S12U. Can my Pioneer BDR-209M (also from a Buffalo case) also be flashed to a BDR-S12U?
Before: viewtopic.php?p=188225#p188225
After: viewtopic.php?p=188337#p188337
If so, could I please get the files from you?
Thank you very much and Happy New Year 2016!
I had sent you everything needed in August of last year. Now just go away or ask Billy and pay your $25 to him.YukiNyan wrote: Thu Jan 01, 2026 3:07 pm Finally found the time to try and flash my drive.
Revision: 1.10
AviTMC
Thank you, Cooper, for the guidance. Please see below:Coopervid wrote: Wed Dec 31, 2025 8:48 pmYou need to install Makemkv and run it. It will show then the information you should post.AviTMC wrote: Wed Dec 31, 2025 4:38 am Hi Cooper,
Thank you, sir.
OS device name: G:
Current profile: DVD+R
Revision: 1.30
Serial number: NKDL080890WL
Firmware date: 2014-12-05
Firmware version: 1.30/ID61
kinimato
Hey @Coopervid,
I would also appreciate some help with this drive I have. It's a Pioneer BDR-S09. Please advise if this is UHD capable.
Product: BD-RW BDR-S09
Revision: 1.34
Serial number: QGDL018666CN
Firmware date: 2016-04-25
Firmware version: 1.34/ID43
Thanks for all your help!
Revision: 1.34
