Public KeyDB Disc Submissions
HarryPeter1016
Post by HarryPeter1016 »
Disc type: Blu-ray
Drive: BD-RE BP60NB10
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link: N/A
Disc dump link: https://drive.google.com/file/d/1AU52Ws ... sp=sharing
cartload88
Post by cartload88 »
Thank you! That worked.
SOFB10
Post by SOFB10 »
Der Hobbit - Smaugs Einöde 4k - German
Disc Dump:
SOFB10
Post by SOFB10 »
Der Herr der Ringe - Die zwei Türme - 4k
Disc Dump:
SOFB10
Post by SOFB10 »
Der Herr der Ringe - die Gefährten - 4k
Disc Dump:
FootFungus07
Post by FootFungus07 »
Evil Dead Rise Arrow Video 4K UHD
Disc type: UHD
Disc dump filename: Evil Dead Rise Arrow Video 4K MKB_RO.zip
Drive firmware: 2120-05-07 09:35
Here's the MKB_RO.INF File link:
https://drive.google.com/file/d/1E9zT1g ... drive_link
Here's the TGZ file link:
https://drive.google.com/file/d/1d5EvNt ... drive_link
Thanks again!
Edgarhouse
Post by Edgarhouse »
Disc type: UHD
Disc dump filename: MKB20_v77_Ocean's_Eleven_1E9D.tgz
Drive: BD-RE WH16NS60
MKB_RO.inf link: https://drive.google.com/file/d/1htSWFk ... sp=sharing
Disc dump link: https://drive.google.com/file/d/16VWIT7 ... drive_link
Also a quick question if it's possible to get an answer here: Some of my discs can't be decrypted by my drive in my Linux distro but they can in Windows using the same drive (for this particular disc, neither could decrypt it). Could that be an issue with how the DB is set up or is this a generic issue that might need more troubleshooting from my side?
fayegumi
Post by fayegumi »
Disc type: BD-ROM
Disc ID: (unsure what this is, line in Unit_Key_RO comes out as: 0 ā 妊ꂄ蜬ୄ﬽꡶嘌 )
Disc dump filename: MKB_v82_collet_F876.tgz
Drive: BD-RE MO6L6BJ4152
Drive firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1UDJamM ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1gvkUc7 ... sp=sharing
DiscSeeker
Post by DiscSeeker »
Stingray – The Complete Series [Imprint] (Australia)
Disc type: BD
Disc dump filename/s: MKB_v82_Stingray_D[1–7]_XXXX.tgz
Drive: BD-RE HL-DT-ST WH16NS60
Disc dump link: https://drive.proton.me/urls/S2NAFVYGFR#TFJHj6rlgxUV
This is the newly released Imprint set, not to be confused with any of the existing Blu‐ray releases.
Happy New Year!
MrPenguin
Post by MrPenguin »
Edgarhouse wrote: Wed Dec 31, 2025 5:53 am Some of my discs can't be decrypted by my drive in my Linux distro but they can in Windows using the same drive (for this particular disc, neither could decrypt it).
Linux file systems are case-sensitive, whereas Windows ones typically aren't. Which means that on Linux, the KEYDB.cfg file must literally be named "KEYDB.cfg", and not (say) "keydb.cfg".
This is the most likely explanation I can think of, for disks which have complete entries in KEYDB.cfg but not in MakeMKV's own "hashed keys" database.
Lostintime
Post by Lostintime »
Disc type: UHD
Disc ID: F6337183393C7AA842E4A0F742315F1FB0144C91
Disc dump filename:MKB20_v82_Bullet_In_The_Head_8958
Drive: BD-RE BU40N
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/1ULPGVl ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1TQDUYK ... drive_link
kuronekonoyoru
Post by kuronekonoyoru »
Hi I´m having problems with King & Prince / STARRING [w/ Blu-ray, STARRING Edition (Limited Edition)]
BD-RW BDR-UD02
Disc type: Blu-ray
Disc dump filename: MKB_v82_UPXX_1178_27FE
Drive: PIONEER BD-RW BDR-UD02
https://drive.google.com/drive/folders/ ... drive_link
SupermanChamber
Post by SupermanChamber »
Disc type: BD-ROM
Disc dump filename:
MKB_v82_Summer_Pockets 下巻 DISC_1_9D00.tgz
MKB_v82_Summer_Pockets 下巻 DISC_2_ED8C.tgz
MKB_v82_Summer_Pockets 下巻 DISC_3_093A.tgz
MKB_v82_Summer_Pockets 下巻 DISC_4_102A.tgz
Drive: BD-RE BH16NS55
Drive firmware: 1.04
Disc dump link: https://www.mediafire.com/file/7orpoqi9 ... p.zip/file
99gagamel
Post by 99gagamel »
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v82_DIE_UNENDLICHE_GESCHICHTE_UHDCMF_24DC,tgz
Laufwerk: BH16NS55
Laufwerks-Firmware: 1.05
Haben Sie die öffentliche Schlüsseldatenbank in den letzten 15 Minuten synchronisiert? Ja
Haben Sie überprüft, ob alle Einreichungslinks im Inkognito-/Privatmodus erreichbar sind? Ja
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/1_FwsM6 ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/1mMJzbW ... sp=sharing
______________________________________________________________________________________________________________
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v82_Die_unendliche_Geschichte_II_E770,tgz
Laufwerk: BW-1601HT
Laufwerks-Firmware: 3.01
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/14zkJ6B ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/1BzfgDo ... sp=sharing
99gagamel
Post by 99gagamel »
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v76_DIE_KLAPPERSCHLANGE_B0D1.tgz
Laufwerk: BH16NS55
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/13HT8Zg ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/1JkiHnu ... sp=sharing
