SDF update November 2025
Re: SDF update November 2025
greg1wto66 wrote:
Wed Dec 17, 2025 6:52 am
Have you tried to delete makemkv folder where the fw dump and sdf bin is located ? It should recreate folder and make full dump once you run mmkv again and insert uhd disk.
I had a same issue with my drive. It worked afterwards
That's a somewhat extreme action I wouldn't recommend. The previous poster did the equivalent by moving any dump files, _private_data.tar, keydb.cfg (if present), and sdf.bin (if present) out of the folder. They then power cycled their optical drive and rebooted their computer. In many cases, that'll fix up problems, as it did for you. In their case, it did not solve the problem, unfortunately.
If you delete the whole folder, you'll lose any custom profiles you've made (in the .xml files) and any settings you changed (in the .conf files).
WithoutRhythm
Post by WithoutRhythm »
I'm not sure if this is fully related to the SDF update, but a few months ago my drive stopped working for any blu rays at all. After much troubleshooting and forum diving and trial and error I found that deleting my _private_data.tar file and turning off internet updates (to prevent MakeMKV from trying to download any SDF updates) was the only thing that worked to enable any blu ray ripping at all. I detailed some of the error codes in this thread.
I'm not too well-versed in this, but it does seem like something in the new SDF updates is interfering with my drive's ability to rip standard blu rays (haven't even gotten to the point of trying UHDs yet).
Things that did not work for me included power cycling my drive, manually installing the latest SDF.bin, updating my proxy to something like 8.8.8.8, checking all the connections in my drive and enclosure, trying out different discs, installing an older version of MakeMKV, manually opening all the disc's files before attempting to rip it, and deleting all the files in the makemkv folder (but keeping internet updates on).
Here's my current information:
OS device name: /dev/rdisk4
Manufacturer: PIONEER
Product: BD-RW BDR-S13U
Revision: 1.05
Serial number: xxxxxxxxxxxx
Firmware date: 2023-08-01
Highest AACS version: 78
Firmware version: ID43
When I had the latest SDF.bin installed and things were not working, this is what my LibreDrive information was:
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.05/ID43
drgonzo
Post by drgonzo »
MakeMKV downloaded an updated SDF.bin file today and now my Pioneer BDR-X13JX is working perfectly with LibreDrive.
It recognized the drive right away, and I just successfully used it to rip my first UHD disc.
visionviper
Post by visionviper »
Great results with my drive! Thank you for all the hard work!
OS device name: /dev/sr0
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: Dxxxx
Firmware date: 2022-12-27
Highest AACS version: 82
Drive platform: RS9331
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02/ID05
kaysee
Post by kaysee »
MakeMKV 1.18.2 did a firmware dump for a Pioneer BDR-208DBK with a request to send it to support@, which was a surprise. It looks like this drive and FW revision are in the list of already known firmware versions.
OS device name: ****
Product: BD-RW BDR-208D
Revision: 1.10
Serial number: ****
Bus encryption flags: 13
Highest AACS version: 81
There was no Firmware Date field, and also no LibreDrive information section.
nicholfd
Post by nicholfd »
kaysee wrote:
Wed Jan 07, 2026 12:30 am
Revision: 1.10
Serial number: ****
Did you send it? If they need it, they'll use it. If you don't send it, and they need it, it doesn't help anyone... :wink: They'll figure out what to do with it.
kaysee
Post by kaysee »
Yes, but mystified why a drive that is not obscure or recent, and seems to be listed in the known drives list, needs FW submitted.
nicholfd
Post by nicholfd »
kaysee wrote:
Wed Jan 07, 2026 1:02 am
It may have been an "erroneous" message/dump. The firmware version/drive hardware version are specific to what they need. If yours is reporting NO versions, then that may have triggered the dump/message.
I would wonder more why you see no version/revision info...
kaysee
Post by kaysee »
The list at the beginning of this thread suggests that this BDR-TD05AS might be able to have LibreDrive enabled. I sent a firmware dump, but am not sure what happens after that.
Product: BD-RW BDR-TD05AS
Revision: 1.01
Firmware date: 2013-01-25
Drive platform: Pioneer RS8211
Firmware version: ID23
kaysee wrote:
Mon Jan 19, 2026 2:34 pm
Revision: 1.01
Long, long time ago. We would be happier if mike could implement crossflashing drives with new firmwares.
InigoMontoya
Post by InigoMontoya »
Was hoping for some clarification. I asked about my drives a couple months back, but neither of them were compatible. But now I'm looking at the top of this thread, and I'm not seeing one of my drives firmware listed in the "drives for which we do not have a firmware file" list. Doesn't that mean mine should work now? Or am I still out of luck because its a post 11/2022 firmware? Specs below. Thank you!
Revision: 1.02
Serial number:
Drive platform: RS9330
MrPenguin
Post by MrPenguin »
InigoMontoya wrote:
Mon Feb 09, 2026 11:49 pm
Revision: 1.02
Serial number:
Your drive can now enable LibreDrive. However, it is not a UHD-capable model. You would need to cross-flash its firmware before you could use it to rip UHD disks.
Mike has yet to release a cross-flasher for Pioneer firmware >= Dec 2022, and we can only hope that he is still working on it.
InigoMontoya
MrPenguin wrote:
Tue Feb 10, 2026 11:01 pm
Revision: 1.02
Serial number:
Yea. That's what I figured. Thanks for the update!
InigoMontoya
So I'm thinking about buying a UHD blu ray burner from ebay (shipping from china), but I want to be sure that it'll rip UHD disks. This whole thing is a little confusing and I just want to double check before I make the purchase. From what I can tell, this one should do the trick. Firmware is pre 12/2022, and its a UHD model. Here's the info. Its a Pioneer BDR-S11JX drive.
Product: BD-RW BDR-S11
Revision: 1.53
Serial number:
Firmware date: 2020-08-03
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID43
Any help would be greatly appreciated!
InigoMontoya wrote:
Fri Feb 13, 2026 5:35 am
Revision: 1.53
Serial number:
that drive can be flashed to do UHD email me that drive info section
