Pioneer bdr 209 and Pioneer bdr 209m
jasontuk
Re: Pioneer bdr 209 and Pioneer bdr 209m
#136 Post by jasontuk » Sat Dec 27, 2025 11:11 am
Hi, can I use my Pioneer BDR-209M drive to rip UHDs and if so can someone please tell me how? Thanks
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.51
Serial number: NJDL025412WL
Firmware date: 2018-05-08
Bus encryption flags: 13
Highest AACS version: 82
Drive platform: RS8600
Firmware version: 1.51/ID60
#137 Post by Coopervid » Sun Dec 28, 2025 11:07 am
jasontuk wrote: Sat Dec 27, 2025 11:11 am Hi, can I use my Pioneer BDR-209M drive to rip UHDs and if so can someone please tell me how? Thanks
OS device name: E:
Revision: 1.51
PM sent.
mmn110
#138 Post by mmn110 » Mon Dec 29, 2025 11:07 am
Hi all -- recently acquired a BDR-209BDK. I was wondering if any firmware was available which would allow it to read UHD discs.
OS device name: F:
Product: BD-RW BDR-209D
Revision: 1.51
Serial number:
Drive platform: RS8601
Firmware version: 1.51/ID61
#139 Post by Coopervid » Tue Dec 30, 2025 11:21 am
mmn110 wrote: Mon Dec 29, 2025 11:07 am Hi all -- recently acquired a BDR-209BDK. I was wondering if any firmware was available which would allow it to read UHD discs.
OS device name: F:
Revision: 1.51
Serial number:
PM is coming.
AviTMC
#140 Post by AviTMC » Wed Dec 31, 2025 4:38 am
Hi Cooper,
I have both Pioneer BDR-209D and BDR-209M drives. My OS on both computers is Windows 10, but for some reason I cannot access the System Information of the optical drives. I tried both Device Manager and System Information. The details of the drives are not showing on the right pane of each window. Any assistance is greatly appreciated. I'm trying to get you the drive information of both drives, so I can see if I can flash them.
Thank you, sir.
Arki90
#141 Post by Arki90 » Wed Dec 31, 2025 11:22 am
Hello all,
I've bought a used external Pioneer (Buffalo) drive in order to be able to read some UHD-discs which my currently used BU40N doesn't recognize.
Mostly large triple layer BRs are not recognized by my BU40N.
Long story short, is it possible to flash the Pioneer drive to be able to recognize UHD-discs?
Here are the information which MakeMKV shows me:
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-209M
Revision: 8.11
Serienummer:
Firmware-Datum: 2014-01-16
Highest AACS version: 76
Firmware version: 8.11/ID52
Would be great if someone could help me with this.
Thanks and have a good new year!
Sir Nakamura
#142 Post by Sir Nakamura » Wed Dec 31, 2025 6:06 pm
Hi, can I use my Pioneer BDR-209M drive - inside a Buffalo Case (BRXL-16U3-EU) to rip UHDs and if so can someone please tell me how?
OS-Gerätename: E:
Produzent: PIONEER
Revision: 8.11
Serienummer:
#143 Post by Coopervid » Wed Dec 31, 2025 8:48 pm
AviTMC wrote: Wed Dec 31, 2025 4:38 am Hi Cooper,
Thank you, sir.
You need to install Makemkv and run it. It will show then the information you should post.
#144 Post by Coopervid » Wed Dec 31, 2025 8:49 pm
Arki90 wrote: Wed Dec 31, 2025 11:22 am Hello all,
OS-Gerätename: D:
Produzent: PIONEER
Revision: 8.11
Serienummer:
PM sent.
#145 Post by Coopervid » Wed Dec 31, 2025 8:51 pm
Sir Nakamura wrote: Wed Dec 31, 2025 6:06 pm Hi, can I use my Pioneer BDR-209M drive - inside a Buffalo Case (BRXL-16U3-EU) to rip UHDs and if so can someone please tell me how?
OS-Gerätename: E:
Produzent: PIONEER
Revision: 8.11
Serienummer:
PM sent.
YukiNyan
#146 Post by YukiNyan » Thu Jan 01, 2026 3:07 pm
Finally found the time to try and flash my drive.
OS device name: /dev/sr0
Revision: 1.10
Serial number: XXXXXXXXXX
Firmware date: 2013-09-10
Highest AACS version: 57
Firmware version: 1.10/ID60
Sir Nakamura
#147 Post by Sir Nakamura » Thu Jan 01, 2026 5:44 pm
Hello Coopervid
thank you so much for the flashing instructions and software!
Before flashing, I'd like to ask you a question. In a post the same drive (BDR-209M) - also from a Buffalo case - was flashed to a BDR-S12U. Can my Pioneer BDR-209M (also from a Buffalo case) also be flashed to a BDR-S12U?
Before: viewtopic.php?p=188225#p188225
After: viewtopic.php?p=188337#p188337
If so, could I please get the files from you?
Thank you very much and Happy New Year 2016!
#148 Post by Coopervid » Thu Jan 01, 2026 10:45 pm
YukiNyan wrote: Thu Jan 01, 2026 3:07 pm Finally found the time to try and flash my drive.
Revision: 1.10
I had sent you everything needed in August of last year. Now just go away or ask Billy and pay your $25 to him.
AviTMC
#149 Post by AviTMC » Fri Jan 02, 2026 3:13 am
Coopervid wrote: Wed Dec 31, 2025 8:48 pm
Thank you, sir.
Thank you, Cooper, for the guidance. Please see below:
OS device name: G:
Current profile: DVD+R
Revision: 1.30
Serial number: NKDL080890WL
Firmware date: 2014-12-05
Firmware version: 1.30/ID61
kinimato
#150 Post by kinimato » Fri Jan 02, 2026 8:52 am
Hey @Coopervid,
I would also appreciate some help with this drive I have. It's a Pioneer BDR-S09. Please advise if this is UHD capable.
Product: BD-RW BDR-S09
Revision: 1.34
Serial number: QGDL018666CN
Firmware date: 2016-04-25
Firmware version: 1.34/ID43
Thanks for all your help!
