Should be. Update your SDF.bin then reboot the drive and MakeMKV.warpgremlin wrote: Tue Dec 23, 2025 1:51 amGiving this a bump. Is this a supported drive yet?warpgremlin wrote: Sat Jun 07, 2025 7:27 pm Have Pioneer drive (SATA native, via USB enclosure to a Windows box).
UHD disks won't decrypt. Need firmware update... I think.
Drive Information OS device name: D: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-S13JX Revision: 1.04 Serial number: xxxxxxxxxxxx Firmware date: 2022-12-12 Bus encryption flags: 1B Highest AACS version: 61 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS9201 Firmware version: ID72
LibreDrive for Pioneer drives
I seem to have found a drive (sold as BDR-212XJ) which isn't on the SDF supported list, and isn't even on the list of drives for which you do not have a firmware file. I've sent in the firmware dump to the support email.
Incidentally, this drive supports BDXL but not UltraHD. Is there any chance it can be cross-flashed to get UHD support?
OS device name: /dev/sr0
Product: BD-RW BDR-212M
Revision: 1.01
Serial number: TLDL001005WL
Firmware date: 2020-07-21
Highest AACS version: 81
Firmware version: GENE
sure just email me that makemkv drive info section see below for emaildestine97 wrote: Fri Dec 26, 2025 11:41 pm I seem to have found a drive (sold as BDR-212XJ) which isn't on the SDF supported list, and isn't even on the list of drives for which you do not have a firmware file. I've sent in the firmware dump to the support email.
Incidentally, this drive supports BDXL but not UltraHD. Is there any chance it can be cross-flashed to get UHD support?Code: Select all
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-212M Revision: 1.01 Serial number: TLDL001005WL Firmware date: 2020-07-21 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: GENE
Mystery501
I recently bought a BDR-XS07B-UHD which fits the criteria for a libredrive but it looks like its not enabled yet. How can I get this drive to libredrive status, if possible?
Product: BD-RW BDR-XS07U
Revision: 1.00
Serial number: redacted
Firmware date: 2019-01-07
Highest AACS version: 82
Firmware version: ID69-
Email Mike your fw dumpMystery501 wrote: Sun Dec 28, 2025 7:57 pm I recently bought a BDR-XS07B-UHD which fits the criteria for a libredrive but it looks like its not enabled yet. How can I get this drive to libredrive status, if possible?
OS device name: \Device\CdRom0 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XS07U Revision: 1.00 Serial number: redacted Firmware date: 2019-01-07 Bus encryption flags: 1B Highest AACS version: 82 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8E21 Firmware version: ID69
I am totaly lost, can any or both of my drives rip uhd? or what can they do? thanks
Drive 1: This one is actually a BDR-209BK , but I guess it was flashed differently bevore I got it from seller.
Second Drive:
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-211M
Revision: 1.53
Serienummer:
Firmware-Datum: 2020-08-03
Markierungen der Bus-Verschlüsselung: 13
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID60
Keine Disk eingelegtCode: Select all
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-S13U
Revision: 1.04
Serienummer:
Firmware-Datum: 2022-12-12
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.04/ID43
Unrestricted read speed: YesRe: LibreDrive for Pioneer drives
Just try an UHD in both drives and report back. Both should work. For the S13U you need to enable Internet access for makemkv to load the newest SDF.bin and then shut down, wait and reboot.niopio wrote: Wed Dec 31, 2025 4:48 pm I am totaly lost, can any or both of my drives rip uhd? or what can they do? thanks
Drive 1: This one is actually a BDR-209BK , but I guess it was flashed differently bevore I got it from seller.Second Drive:Code: Select all
Laufwerksinformation OS-Gerätename: D: Produzent: PIONEER Produkt: BD-RW BDR-211M Revision: 1.53 Serienummer: Firmware-Datum: 2020-08-03 Markierungen der Bus-Verschlüsselung: 13 LibreDrive Information Status: Enabled Drive platform: RS8800 Firmware name: PIONEER BDR-211 Firmware type: Original (unpatched) Firmware version: 1.53/ID60 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes Keine Disk eingelegtCode: Select all
Laufwerksinformation OS-Gerätename: D: Produzent: PIONEER Produkt: BD-RW BDR-S13U Revision: 1.04 Serienummer: Firmware-Datum: 2022-12-12 Markierungen der Bus-Verschlüsselung: 1B LibreDrive Information Status: Enabled Drive platform: RS9201 Firmware name: PIONEER BDR-213T Firmware type: Original (unpatched) Firmware version: 1.04/ID43 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
The S13U is already enabled and ready to rip UHD discs. Not sure about the other one. Give it a try.niopio wrote: Wed Dec 31, 2025 4:48 pm I am totaly lost, can any or both of my drives rip uhd? or what can they do? thanks
Hi all,
Curious if I can new FW for my drive? Just created an account so I can't message anyone directly.
I have an LG WH14NS40 that's been my go-to for the last few years. But as you know, it's only going to get harder to acquire drives now that everyone has exited the industry. managed to snag this BDR-XD05 on eBay for a decent price and want to make sure I have a reliable backup.
Thank you to everyone who's made this possible!
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number:
Firmware date: 2014-12-26
Highest AACS version: 77
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
No disc insertedRe: LibreDrive for Pioneer drives
PM sent.Crazy1 wrote: Thu Jan 01, 2026 12:15 am Hi all,
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.01 Serial number: Firmware date: 2014-12-26 Bus encryption flags: 1B Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS8231 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.01/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
Thanks for the help! Worked like a champ! Up and ripping UHDs.
Coopervid wrote: Thu Jan 01, 2026 1:02 pmPM sent.Crazy1 wrote: Thu Jan 01, 2026 12:15 am Hi all,
Hey All,
I've got a Pioneer BDR-XD05, I was wondering if anyone would be able to confirm that this drive supports 4K UHD and could help me get it configured if possible.
Thanks in advance!
Thanks in advance!
OS device name: E:
Revision: 3.01
Serial number: QFDL115020UC
Highest AACS version: 75
No disc inserted-
sure just email me that drive info see belown00bz0rz wrote: Sat Jan 03, 2026 1:38 am Hey All,
Thanks in advance!
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.01 Serial number: QFDL115020UC Firmware date: 2014-12-26 Bus encryption flags: 1B Highest AACS version: 75 LibreDrive Information Status: Enabled Drive platform: RS8231 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.01/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
Am I already good to go?
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: DHDL006043UC
Firmware date: 2022-12-27
Drive platform: RS9331
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02/ID05
Yes, MakeMKV is telling you that it has enabled LibreDrive. XD08U firmware dated >= 2022-12 is now supportedriddley wrote: Sun Jan 04, 2026 4:24 pm Am I already good to go?
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-XD08U Revision: 1.02 Serial number: DHDL006043UC Firmware date: 2022-12-27 Bus encryption flags: 1B Highest AACS version: 82 LibreDrive Information Status: Enabled ...
