LibreDrive for Pioneer drives
warpgremlin wrote: Tue Dec 23, 2025 1:51 am
warpgremlin wrote: Sat Jun 07, 2025 7:27 pm Have Pioneer drive (SATA native, via USB enclosure to a Windows box).
UHD disks won't decrypt. Need firmware update... I think.
Manufacturer: PIONEER
Product: BD-RW BDR-S13JX
Revision: 1.04
Serial number: xxxxxxxxxxxx
Firmware date: 2022-12-12
Highest AACS version: 61
Firmware version: ID72
Giving this a bump. Is this a supported drive yet?
Should be. Update your SDF.bin then reboot the drive and MakeMKV.
destine97
Post by destine97 »
I seem to have found a drive (sold as BDR-212XJ) which isn't on the SDF supported list, and isn't even on the list of drives for which you do not have a firmware file. I've sent in the firmware dump to the support email.
OS device name: /dev/sr0
Product: BD-RW BDR-212M
Revision: 1.01
Serial number: TLDL001005WL
Firmware date: 2020-07-21
Highest AACS version: 81
Firmware version: GENE
Incidentally, this drive supports BDXL but not UltraHD. Is there any chance it can be cross-flashed to get UHD support?
destine97 wrote: Fri Dec 26, 2025 11:41 pm I seem to have found a drive (sold as BDR-212XJ) which isn't on the SDF supported list, and isn't even on the list of drives for which you do not have a firmware file. I've sent in the firmware dump to the support email.
Revision: 1.01
sure just email me that makemkv drive info section see below for email
Mystery501
Post by Mystery501 »
I recently bought a BDR-XS07B-UHD which fits the criteria for a libredrive but it looks like its not enabled yet. How can I get this drive to libredrive status, if possible?
Product: BD-RW BDR-XS07U
Revision: 1.00
Serial number: redacted
Firmware date: 2019-01-07
Highest AACS version: 82
Firmware version: ID69
Mystery501 wrote: Sun Dec 28, 2025 7:57 pm I recently bought a BDR-XS07B-UHD which fits the criteria for a libredrive but it looks like its not enabled yet. How can I get this drive to libredrive status, if possible?
Revision: 1.00
Email Mike your fw dump
niopio
Post by niopio »
I am totaly lost, can any or both of my drives rip uhd? or what can they do? thanks
Drive 1: This one is actually a BDR-209BK , but I guess it was flashed differently bevore I got it from seller.
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-211M
Revision: 1.53
Serienummer:
Firmware-Datum: 2020-08-03
Markierungen der Bus-Verschlüsselung: 13
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID60
Keine Disk eingelegt
Second Drive:
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-S13U
Revision: 1.04
Serienummer:
Firmware-Datum: 2022-12-12
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.04/ID43
niopio wrote: Wed Dec 31, 2025 4:48 pm I am totaly lost, can any or both of my drives rip uhd? or what can they do? thanks
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.53
Serienummer:
Second Drive:
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.04
Serienummer:
Just try an UHD in both drives and report back. Both should work. For the S13U you need to enable Internet access for makemkv to load the newest SDF.bin and then shut down, wait and reboot.
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.53
Serienummer:
Second Drive:
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.04
Serienummer:
The S13U is already enabled and ready to rip UHD discs. Not sure about the other one. Give it a try.
Crazy1
Post by Crazy1 »
Hi all,
Curious if I can new FW for my drive? Just created an account so I can't message anyone directly.
I have an LG WH14NS40 that's been my go-to for the last few years. But as you know, it's only going to get harder to acquire drives now that everyone has exited the industry. managed to snag this BDR-XD05 on eBay for a decent price and want to make sure I have a reliable backup.
Thank you to everyone who's made this possible!
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number:
Firmware date: 2014-12-26
Highest AACS version: 77
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
Crazy1 wrote: Thu Jan 01, 2026 12:15 am Hi all,
Revision: 3.01
Serial number:
PM sent.
Crazy1
Post by Crazy1 »
Thanks for the help! Worked like a champ! Up and ripping UHDs.
Coopervid wrote: Thu Jan 01, 2026 1:02 pm
Revision: 3.01
Serial number:
PM sent.
n00bz0rz
Post by n00bz0rz »
Hey All,
I've got a Pioneer BDR-XD05, I was wondering if anyone would be able to confirm that this drive supports 4K UHD and could help me get it configured if possible.
Thanks in advance!
OS device name: E:
Revision: 3.01
Serial number: QFDL115020UC
Highest AACS version: 75
n00bz0rz wrote: Sat Jan 03, 2026 1:38 am Hey All,
Thanks in advance!
OS device name: E:
Revision: 3.01
sure just email me that drive info see below
riddley
Post by riddley »
Am I already good to go?
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: DHDL006043UC
Firmware date: 2022-12-27
Drive platform: RS9331
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02/ID05
MrPenguin
Post by MrPenguin »
riddley wrote: Sun Jan 04, 2026 4:24 pm Am I already good to go?
Revision: 1.02
Yes, MakeMKV is telling you that it has enabled LibreDrive. XD08U firmware dated >= 2022-12 is now supported :D.
