Public KeyDB Disc Submissions
Browneye9999
Post by Browneye9999 »
Browneye9999 wrote:
Sun Dec 21, 2025 3:33 am
Disc dumps for 48hrs, Once Upon a Time in the West and White Christmas.
https://drive.google.com/drive/folders/ ... drive_link
Sorry I have now added the relevant .inf files also
MrPenguin
Post by MrPenguin »
thaelis wrote:
Mon Dec 22, 2025 11:39 pm
Sure, sorry did not notice the file size. Hopefuly this is the file you need:
Yes, that's the one. Thanks :).
Any setting to do in MakeMKV to prevent this truncation in the future ?
Unfortunately not :(. I think MakeMKV does this when it realizes that it already knows the disk's Media Key, and so doesn't need to calculate it again. Which is fine for MakeMKV precisely because it makes the TGZ dump files so much smaller. It's just that it makes them much less useful for KEYDB too.
Toad King
Post by Toad King »
Disc type: UHD
Disc ID:
6b258e2c8c3de8f490c2aa3cd0af3d0a0cab18d2
aa387f97d84684657ad076933623779280797158
Disc dump filename:
MKB20_v77_Enter_the_Ninja_17F8
MKB20_v77_Revenge_of_the_Ninja_A8D4
Drive: BD-RE WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Not needed
Disc dump link: https://drive.google.com/drive/folders/ ... dVbDomRK9I
nuelamile
Post by nuelamile »
deleted
MisakaChey
Post by MisakaChey »
Disc type:UHD
Disc ID:0xB8F0E233A4BE30BD39842EA977114B8158C790C8
Disc dump filename:MKB20_v77_Arknights_ambience_synesthesia_2024_722F
Drive:BW-16D1HT
Drive firmware:3.10MK
LibreDrive status:Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1IEQeif ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1UZ2Djr ... sp=sharing
There's a kinda same name key in the keydb.cfg file, but it's not useable for my new version disc.
Thanks a lot.
MrPenguin
Post by MrPenguin »
MisakaChey wrote:
Tue Dec 23, 2025 3:14 pm
MKB_RO.inf link:
Can you also upload the AACS/MKB_RO.inf file fron the actual physical UHD disk please? The copy of this file inside your TGZ dump has been truncated to only 56 bytes, and so is unusable to anyone except MakeMKV itself.
MisakaChey
MrPenguin wrote:
Tue Dec 23, 2025 3:29 pm
MKB_RO.inf link:
Of course!
The MKB_RO.inf file has been replaced to UHD disk version.
Scavenger
Post by Scavenger »
UK variant of Pee Wee's Big Adventure UHD (UK variant of BD is already supported in MakeMKV)
Disc type: UHD
Disc ID: 06102E35B32EB3C34FDA2EC8161421614DAD2095
Disc dump filename: MKB20_v82_PEE_WEES_BIG_ADVENTURE_913E
Drive: LG BP60NB10
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): not truncated
Disc dump link:
EDIT:
It got added, but doesn't work. Turns out the MKB_RO.inf from the dump file is truncated after all (3.63 MB in dump file, 5 MB on disc). I incorrectly assumed that anything over ~56 byte is not truncated. Sorry about that. The MKB_RO.inf from the disc:
EDIT 2:
Now working. Links removed.
reverandbob
Post by reverandbob »
Bugonia
Disc type: Blu-ray (AACS 1.0)
Disc dump filename:MKB_v82_Bugonia_451A.tgz
Drive: BD-RE WP50NB40
Drive firmware: 1.03
LibreDrive status: N/A
Disc dump link: https://drive.google.com/file/d/1GHg_n5 ... drive_link
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the updated template and submitted new disc dump files. The following discs have been added to the public keydb:
MKB20_v61_FIST_OF_FURY_0EE9
MKB20_v77_HPXR_3115_FACA
MKB20_v77_HPXR_3117_E932
MKB20_v82_DOGVILLE_4436
MKB_v82_卓球少女_-閃光のかなたへ-_5EF4
MKB_v82_卓球少女_-閃光のかなたへ- 特典DISC_D89C
Scavenger wrote:
Tue Dec 23, 2025 6:02 pm
It got added, but doesn't work. Turns out the MKB_RO.inf from the dump file is truncated after all (3.63 MB in dump file, 5 MB on disc). I incorrectly assumed that anything over ~56 byte is not truncated. Sorry about that. The MKB_RO.inf from the disc: ...
Hey Scavenger, the ~3.6MB MKB_RO.inf file in your disc dump is usable. MakeMKV can remove the long sequence of trailing null bytes from the end of MKB_RO.inf files without issue. It really is just the 56 byte very truncated form which is problematic.
The reason that the initially added record didn't work for you was that it only contained the volume ID. The volume ID alone cannot be used to decrypt a disc. I'd prefer it if people would avoid adding entries to the keydb which contain only the volume ID as it leads to this type of confusion.
UHD discs can be decrypted if just the unit key is available. MakeMKV requires the volume unique key (VUK - the " | V | " part of a keydb record) in order to decrypt discs. There is no technical reason for this limitation but it explains why a disc might be playable via VLC but not decryptable in MakeMKV.
Your disc has a full record now, so it should work with MakeMKV once you grab the latest keydb. Make sure you have a line like this in your keydb.cfg file:
0x06102E35B32EB3C34FDA2EC8161421614DAD2095 = PEE WEES BIG ADVENTURE | D | 0000-00-00 | M | 0x9B<Redacted for the forum> | I | 0xC3<Redacted for the forum> | V | 0x92<Redacted for the forum> | U | 1-0xE5<Redacted for the forum> ; MKBv82/BEE (UHD)
Daredevil786 wrote:
Mon Dec 22, 2025 3:47 pm
Dogville (2003)
Your disc has been added to the public keydb. Please ensure you follow the latest submission template for any future submissions to avoid processing delays.
MisakaChey
keydb_helper wrote:
Wed Dec 24, 2025 12:22 am
Dogville (2003)
Really appreciate this, I didn't think this can be solved this fast, nice work!
RURU1229
Post by RURU1229 »
Disc type: BD-ROM
Disc ID:
Disc dump filename: MKB_v82_劇場版_うたの☆プリンスさまっ♪_TABOO_NIGHT_XXXX_DISC1_5A2E
Drive: BD-RE HL-DT-ST BD-RE BP60NB10
LibreDrive status: Possible (with patched firmware)
MKB_RO.inf link: <Link>
Disc dump link: <Link>
dougy
Post by dougy »
Disc type: UHD
Disc dump filename: MKB20_v82_Jurassic_World_Rebirth_1914.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1PHlObs ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1YCyI0s ... sp=sharing
Disc type: UHD
Disc dump filename: MKB20_v82_Novocaine_51EA.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1dwL4Sz ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1s2-ALk ... sp=sharing
tanks in advance
MrPenguin
Post by MrPenguin »
dougy wrote:
Wed Dec 24, 2025 10:53 am
Your links to both dumps are the same.
dougy
Post by dougy »
MrPenguin wrote:
Wed Dec 24, 2025 12:15 pm
You're right...sorry I fixed that.
