Can confirm, I am having the same issue with Disc 2Hannibal8u wrote: ↑Sun Dec 21, 2025 8:19 pmPublic KeyDB – Disc not enumerating (request for dump)
Disc type: UHD Blu-ray
Title: Teenage Mutant Ninja Turtles II: The Secret of the Ooze
Edition / Label: Arrow Video – Teenage Mutant Ninja Turtles Trilogy (4K UHD box set)
Region: UHD (Region Free)
Disc number: Disc 2 (TMNT II)
Drive: LG BP60NB10
Firmware: 1.02
LibreDrive: Enabled
OS: Windows 10/11 x64
Software: MakeMKV 1.18.2 (x64 backend)
Problem description:
This UHD disc does not enumerate at all on my system.
MakeMKV reports “Please insert disc” even though the disc is physically inserted.
Important comparison:
TMNT 1 (Disc 1) → works and enumerates normally
TMNT 3 (Disc 3) → works and enumerates normally
TMNT 2 (this disc) → does not enumerate
The disc plays correctly on an Xbox Series X, confirming the disc itself is good.
Because the disc never enumerates:
No Disc Info can be read
No Disc Hash can be generated
No partial dump is possible on this drive
This appears to be a missing AACS2 / KeyDB entry specific to TMNT II in the Arrow UHD set.
Posting to flag the disc in case someone with a different LibreDrive-capable drive (or internal ASUS/LG drive) is able to enumerate and submit a dump.
Thanks in advance.
Public KeyDB Disc Submissions
stiguy1010
The disc is already supported and I succesfully ripped my TMNT 2 UHD with my LG drive (BP55EB40 flashed to BP60NB10). It's a problem with your copy or drive. My LG drive struggles with certain triple layer discs. It can take minutes before the drive recognizes the disc and even then the drive can lose focus while ripping. For these difficult discs, I sometimes back them up with Xreveal instead.Hannibal8u wrote: ↑Sun Dec 21, 2025 8:19 pmPublic KeyDB – Disc not enumerating (request for dump)
Drive: LG BP60NB10
Firmware: 1.02
LibreDrive: Enabled
doct0rgonz0
Hannibal8u
Thank you kindly for your reply. Yeah I’m starting to think maybe my lg BP60NB10 uhd drive is starting to become faulty. It’s now asking me to insert uhd disc when it’s inserted alread, even when it’s a disc instead had backup . I will check out that Xreveal software, thank you.
sandman_satx213
Black Phone
Disc type: UHD
Disc dump filename: MKB20_v77_BDROM_C0D3.tgz
Drive: BD-RE BP60NB10
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/13h4sTr ... drive_link
Disc dump link: https://drive.google.com/file/d/1ixRXB6 ... drive_link
Disc type: UHD
sandman_satx213
Black Phone 2
Disc type: UHD
Disc dump filename: MKB20_v82_BLACK_PHONE_2_2736.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1t056jG ... drive_link
Disc dump link: https://drive.google.com/file/d/1Ln6-Ao ... drive_link
Disc type: UHD
sandman_satx213
Wes Cravens New Nightmare
Disc type: UHD
Disc dump filename: MKB20_v82_WES_CRAVENS_NEW_NIGHTMARE_FC1C.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1gSgc-e ... drive_link
Disc dump link: https://drive.google.com/file/d/1yJqA2W ... drive_link
Disc type: UHD
Daredevil786
Disc type: BD
Disc ID: 0de6aa34c191ccdc55dcfdb8d01563b702dcb24f
Disc dump filename: MKB_v82_Kandisha_B704.tgz
Drive: WH16NS60
Drive firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://mega.nz/file/1p8D2K5A#xw9uAciot ... oZHYqqdaQ4
Disc dump link:https://mega.nz/file/Qg0hFCKT#tzBt11d_z ... KrjNv9IFIA
Drive: WH16NS60
Disc type: UHD
Disc ID: aaf1d2e893ff6982bea3889d7a606e03afaae27d
Disc dump filename: MKB20_v82_LE_PASSAGE_DU_GRAND_BOUDDHA_7044
Drive: WH16NS60
MKB_RO.inf link: https://mega.nz/file/otkxBAJC#6YSCO-m0E ... c8-rMadzmk
Disc dump link: https://mega.nz/file/cw9WEbjJ#BdVHyVq3D ... pysjrfAnmE
Drive: WH16NS60
Disc type: UHD
Disc ID: 2daabb65472efb1dc043b2ff5eebf0198e9f1c4b
Disc dump filename: MKB20_v82_LE_PASSAGE_DU_GRAND_BOUDDHA_A8A8.tgz
Drive: WH16NS60
MKB_RO.inf link: https://mega.nz/file/sokVkbxa#tm-vBt2_E ... HDeql-6tns
Disc dump link: https://mega.nz/file/tpEE2AxI#rGifLgq3X ... 3mtRS13_Is
Drive: WH16NS60
keydb_helper
Thanks to everyone who submitted disc dump files. I believe most valid submissions have been incorporated into the public keydb.
The following titles were entirely new additions to the public keydb:
Remember, you need to calculate the SHA-1 hash of the Unit_Key_RO.inf file inside the AACS directory.
MKB20_v65_SKYSCRAPER_843B
MKB20_v82_Bambi_A_Tale_of_Life_in_the_Woods_4B84
MKB20_v82_WHISPER_SMITH_HITS_LONDON
MKB_v82_Colonel_Redl_5FBE
MKB_v82_Hanussen_D742
Hey Liersi, thanks for trying to follow the latest submission template but I'm not sure how you calculated that disc ID value. These are the actual libaacs disc ID values of your two discs:
MKB20_v82_LE_PASSAGE_DU_GRAND_BOUDDHA_7044 - 0x372F8DF92FB7D78E47DE3DAF3DED66260C96B724
MKB20_v82_LE_PASSAGE_DU_GRAND_BOUDDHA_A8A8 - 0xAAC810F7A12000FD8C4AE99EE308E7B79595E55D
Hey 99gagamel, please include the disc ID value in any future submissions.
Hey Daredevil786, your disc has not been added to the public keydb. It will probably be added later this week. In the future, please follow the submission template in the opening post of this thread to avoid delays.Daredevil786 wrote: ↑Mon Dec 22, 2025 3:47 pmDogville (2003)
https://www.mediafire.com/file/dra2...
My latest unsupported UHD disc:
Disc Type: UHD
Disc dump filename: MKB20_v61_FIST_OF_FURY_0EE9.tgz
Drive: ASUS BW-16D1HT
Firmware version: 3.10
Disc dump link: https://limewire.com/d/LpTHy#COYIQp1Z8u
Disc Type: UHD
Could you also upload the AACS/MKB_RO.inf file from your physical UHD disk please? The MKB_RO.inf file inside your TGZ dump has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself.
Sure, sorry did not notice the file size. Hopefuly this is the file you need:
https://limewire.com/d/VrB3S#3WNNkEauXA
Any setting to do in MakeMKV to prevent this truncation in the future ?
