Ask for help, brothers
404 NOT FOUND
Could you please help me find the flash tool of ASUS BW-16D1HT 1.01 version? Someone has this tool, but I can't get it through it.
Re: Ask for help, brothers
Why would you want it? Did you brick an older MT1939 drive? If so, use SDFtool Flasher and the recover method with the BW-16D1HT 1.01 firmware found in the first post: viewtopic.php?p=94848#p94848404 NOT FOUND wrote: Mon Dec 22, 2025 9:39 am Could you please help me find the flash tool of ASUS BW-16D1HT 1.01 version? Someone has this tool, but I can't get it through it.![]()
404 NOT FOUND
回复:寻求帮助,兄弟们
Hello, I don't want to restore the 1.01 firmware. I want to ask if there is this version of the flash tool.
Re: 回复:寻求帮助,兄弟们
Even if there was an ASUS BW-16D1HT 1.01 original flasher tool, why would you want it? It would only ever be compatible with the older, pre 2015 version of the drive with the old MT1939 drive platform.404 NOT FOUND wrote: Tue Dec 23, 2025 1:32 am Hello, I don't want to restore the 1.01 firmware. I want to ask if there is this version of the flash tool.
The newer version of the BW-16D1HT with the MT1959 drive platform starts with firmware v3.01.
Why not just say why you are looking for it??
404 NOT FOUND
回复:寻求帮助,兄弟们
Hello, brother. If there is a 1.01 flash tool like this, I can flash LG into ASUS. LG 16NS48 and ASUS BW16D1HT 1.01 are the same machine.
Re: 回复:寻求帮助,兄弟们
I haven't seen an old original MT1939 flasher like that on these forums. You know you could probably use the old modified ASUS flasher with the old BW-16D1HT 1.01 firmware bin file. The threads are below:404 NOT FOUND wrote: Tue Dec 23, 2025 6:26 am Hello, brother. If there is a 1.01 flash tool like this, I can flash LG into ASUS. LG 16NS48 and ASUS BW16D1HT 1.01 are the same machine.
Modified ASUS flasher tool: viewtopic.php?p=70766#p70766
Old BW-16D1HT 1.01 firmware file (bottom of first post): viewtopic.php?p=94848#p94848
404 NOT FOUND
回复:寻求帮助,兄弟们
Thank you for your reply, but this post is not what I want. Hello, brother, please ask for the upgrade tool of ASUS BW16D1HT 1.01 version, that is, LG BH16NS48 and ASUS BW16D1HT 1.01 version mutual brush tool. The motherboard chip is MT1959UWDN and the new ASUS BW16D1HT 3.01 version motherboard chip MT1959RWDN is not a machine. The difference between 1959U and 1959R can be paid. I also need an upgrade software for LG BH12LS35, an older model.
Re: 回复:寻求帮助,兄弟们
Not sure what "mutual brush tool" means...404 NOT FOUND wrote: Wed Dec 24, 2025 1:22 am Thank you for your reply, but this post is not what I want. Hello, brother, please ask for the upgrade tool of ASUS BW16D1HT 1.01 version, that is, LG BH16NS48 and ASUS BW16D1HT 1.01 version mutual brush tool. The motherboard chip is MT1959UWDN and the new ASUS BW16D1HT 3.01 version motherboard chip MT1959RWDN is not a machine. The difference between 1959U and 1959R can be paid. I also need an upgrade software for LG BH12LS35, an older model.
The tool you are looking for is not here. I'm not sure if it even still exists. The BW-16D1HT 1.01 is 10+ years old so I doubt that firmware version flashing tool still exists.
You said you want to flash a BH16NS48 (MT1939 drive platform) to a BW-16D1HT 1.01 (MT1939 drive platform). As I said before, this can be done using the old modified ASUS flasher along with the BW-16D1HT 1.01 firmware file.
