Public KeyDB Disc Submissions
Hello her comes my submission:
Disc type: UHD
Disc ID: 0x480D440B07F74D6DBBDD46C21DB8A7B2D953F643
Disc dump filename: MKB20_v82_BARRY_LYNDON_24C0.tgz
Drive: ASUS BW-16D1HT
Drive firmware:3.10
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):
Disc dump link: https://workupload.com/file/nXqFLDNMMzd
Thank You!
Disc type: UHD
Drive firmware:3.10
Thank You!
keydb_helper
Hey Opera, thanks for the submission. Your disc has been added to the public keydb.
Hey yayodesu, none of your links seem to be accessible. Please check them and try again.
a01ik3d4_1018
Here I'm posting a shared link to the dump file for the Blu-ray disc I want Keydb to support. It's probably something no one has shared yet. Also, could someone please tell me how to check if my disc's ID is already entered in Keydb, and where disc IDs are added in the first place—is it the public key database?
This is the link to share the Blu-ray disc dump file.
https://drive.google.com/file/d/1YamX3a ... sp=sharing
https://drive.google.com/file/d/1c-2L1w ... sp=sharing
keydb_helper
Thanks for the submission. Both of your discs have been added to the public keydb.a01ik3d4_1018 wrote: Fri Dec 19, 2025 3:42 am Here I'm posting a shared link to the dump file for the Blu-ray disc I want Keydb to support. It's probably something no one has shared yet.
You can check the current support status by calculating the SHA-1 hash of the Unit_Key_RO.inf file within the AACS directory on each disc. Once you have this hash, you can open up the extracted keydb.cfg file in any text editor and search for the disc ID value.a01ik3d4_1018 wrote: Fri Dec 19, 2025 3:42 am Also, could someone please tell me how to check if my disc's ID is already entered in Keydb
As an example, the disc ID of your first disc is 0xECB4A28B5FA283600812C1D416325AC483778993. If you search for this hash in the keydb you'll see a line like this:
0xECB4A28B5FA283600812C1D416325AC483778993 = ACEes Arena Tour 2025 PROLOGUE DISC1 | D | 0000-00-00 | M | 0x77<Redacted for the forum> | I | 0xD5<Redacted for the forum> | V | 0xCD<Redacted for the forum> | U | 1-0xA2<Redacted for the forum> ; MKBv82 (BD)
Disc IDs are trivial to calculate and don't actually facilitate decryption. Decryption requires disc keys, and I do believe the public keydb is the fastest option for disc keys these days.a01ik3d4_1018 wrote: Fri Dec 19, 2025 3:42 am where disc IDs are added in the first place—is it the public key database?
The following UHD discs have also been added to the public keydb:
MKB20_v77_OSAKAMONO_UHD_442C
MKB20_v82_SPACE_1999_BREAKAWAY_9F6E
mkb20_v82_uhd_shine_242b
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v70_THE_FRIGHTENERS_KINOFASSUNG_053D.tgz
Laufwerk: BH16NS55
Laufwerks-Firmware: 1.05
Haben Sie die öffentliche Schlüsseldatenbank in den letzten 15 Minuten synchronisiert? Ja
Haben Sie überprüft, ob alle Einreichungslinks im Inkognito-/Privatmodus erreichbar sind? Ja
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/1dpCntT ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/1QJUyN2 ... sp=sharing
Laufwerk: BH16NS55
Disc type: UHD
Disc ID:
Disc dump filename: MKB20_v82_UNDER_SIEGE_-_UHD_F0F0
Drive: BD-RE ASUS BW-16D1HT
Drive firmware:3.01
MKB_RO.inf link:https://drive.google.com/file/d/1_1bnre ... share_link
Disc dump link:https://drive.google.com/file/d/1TogM9S ... sp=sharing
Disc type: UHD
Disc ID:
Drive firmware:3.01
Submitting The Dam Busters UHD just released by Film Movement Classics:
Disc type: UHD
Disc ID:
Disc dump filename: MKB20_v82_The_Dam_Busters_A5B9.tgz
Firmware version: 3.10
MKB_RO.inf link: https://drive.google.com/file/d/1rvGfpO ... drive_link
Disc dump link: https://drive.google.com/file/d/1FMggsp ... drive_link
Disc type: UHD
Disc ID:
Can you adjust the "Share" option for these files please, so that people can access them?
Think I have changed permissions now, thanks
Thanks, and I believe the latest KEYDB.cfg file already contains this disk.
keydb_helper
Thanks 99gagamel, your disc has been added to the public keydb.99gagamel wrote: Fri Dec 19, 2025 7:42 am Disc-Dump-Dateiname: MKB20_v70_THE_FRIGHTENERS_KINOFASSUNG_053D.tgz
Thanks warhorus, your disc has also been added to the public keydb.
You wasted everyone's time by just copying and pasting the template. Actually read the questions and check before posting. Your disc was added to the public keydb on December 13.westhamm wrote: Fri Dec 19, 2025 4:11 pm Did you sync the public keydb within the last 15 minutes? YES
Disc type: BluRay
Disc dump filename: MKB_v82_Black_Phone_2_2CB6.tgz
Drive firmware: 3.10
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1avjkeL ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1TADQk6 ... sp=sharing
Re: Public KeyDB Disc Submissions - Westernhagen live
Interesting, even as i posted this one a week ago, the fix is not available yet. What can be the reason? Thats way longer, than 12 hrs...TheSound wrote: Sat Dec 13, 2025 6:06 pm many thanks for help. Unfortunately i do not have any public storage space available
Disc type: Blu-Ray
Disc dump filename: MKB_v82_Westernhagen_LIVE_E27E.tgz
Drive: BW-16D1HT
Drive firmware: 3.01 - Original (unpatched)
Link: https://transfer.it/t/5cx47Bt3WBgC
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v76_I_Am_Legend_36B5.tgz
Laufwerk: BW-1601HT
Laufwerks-Firmware: 3.01
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/18TWopq ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/1LG3vbu ... sp=sharing
Laufwerk: BW-1601HT
keydb_helper
Hey 99gagamel, thank you for following the template and including the MKB_RO.inf file. Your disc has been added to the public keydb.
MKB20_v77_Vanilla_Sky_(Remastered)_B832
MKB20_v82_Zodiac_0A5E
Don't be a dickhead. Your disc was added to the public keydb on December 10 - 4 days before your post. I ignored your post because you couldn't be fucked to follow my instructions about checking the support status before posting to this thread.TheSound wrote: Sat Dec 20, 2025 9:54 am Interesting, even as i posted this one a week ago, the fix is not available yet. What can be the reason? Thats way longer, than 12 hrs...
Your disc has now been supported for over 10 days, so feel free to stop waiting and read the opening post of this thread.
