Public KeyDB Disc Submissions
fbro265
Disc type: UHD
Disc dump filename: MKB20_v82_Downton_Abbey-_The_Grand_Finale_8CD0.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: https://gofile.io/d/TQ5GPp
Disc dump link: https://gofile.io/d/TQ5GPp
Drive: BD-RE BU40N
dougy
Disc type: UHD
Disc dump filename: MKB20_v82_UHD_BALR_C7E0.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1hnEJwO ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1Xl-Jhr ... sp=sharing
thanks in advance
thanks in advance
csbond2
That much I understood when I read it and I'm not trying to be a pain I have no clue as to how to get to it off of the disc it's not in MKV anywhere and I don't have a program that will open the disc to find it. So if I need to get something different to do that with somebody will have to let me know that part. Sorry for any inconvenience if it becomes impossible for me to do it I will just wait for MKV to take care of it.
MrPenguin
Open the disk in "Windows Explorer"?csbond2 wrote: Tue Dec 16, 2025 5:09 pm That much I understood when I read it and I'm not trying to be a pain I have no clue as to how to get to it off of the disc it's not in MKV anywhere and I don't have a program that will open the disc to find it. So if I need to get something different to do that with somebody will have to let me know that part. Sorry for any inconvenience if it becomes impossible for me to do it I will just wait for MKV to take care of it.
TheSound
Please don't attach disc dump files to forum posts, it creates work for the moderators and cause issues. There are many free public file hosts. Swisstransfer, Wetransfer, Mediafire etc are all fine choices for the purposes of the keydb.TheSound wrote: Sat Dec 13, 2025 6:06 pm many thanks for help. Unfortunately i do not have any public storage space available
Thanks for reminding, i added the link
csbond2
MKB_RO.inf for Riddick (Steelbook)
https://drive.google.com/file/d/1GxutTI ... sp=sharing
csbond2
Thank you.MrPenguin wrote: Tue Dec 16, 2025 5:34 pmOpen the disk in "Windows Explorer"?csbond2 wrote: Tue Dec 16, 2025 5:09 pm That much I understood when I read it and I'm not trying to be a pain I have no clue as to how to get to it off of the disc it's not in MKV anywhere and I don't have a program that will open the disc to find it. So if I need to get something different to do that with somebody will have to let me know that part. Sorry for any inconvenience if it becomes impossible for me to do it I will just wait for MKV to take care of it.
PotatoTomato
Disc type: UHD
Disc dump filename: MKB20_v70_Avatar-_The_Way_of_Water_AE55
Drive: LG BU40N
MKB_RO.inf link: https://www.mediafire.com/file/jclws91d ... O.inf/file
Disc dump link: https://www.mediafire.com/file/w6d6013c ... 5.tgz/file
If additional information is needed, please let me know.
Thank you
Drive: LG BU40N
Thank you
csbond2
Thank you.keydb_helper wrote: Tue Dec 16, 2025 1:51 amHey Jay, thanks for following up but your disc variant was added to the keydb a couple of days ago thanks to the equivalent disc dump file provided by the user Baden.treatsbyjay wrote: Mon Dec 15, 2025 10:22 am I knew mine wouldn't be that easy haha. I've followed your instructions, here's the new dump MakeMKV created.
Hey jisoo9707, your disc dump files seems to be structured quite strangely. Did you happen to edit or modify the file? Was it created from a commercial/pressed disc? Or does it correspond to a BDAV disc created with a Blu-ray recorder?
Hey csbond2, thanks for the honesty. Luckily for you that file isn't required for your particular disc as the media key was already present in the keydb record of a different disc variant. Grab the very latest keydb and you should be good to go,
Hey Ben, thanks for the submission. Your Pioneer disc drive is fine for 1080p discs but it can't be used to generate UHD keydb entries from scratch. Luckily for you, the user FonduemangVI posted a suitable disc dump file created with an LG drive in the Dogma title thread so both of your discs have been added to the public keydb.benpollard wrote: Mon Dec 15, 2025 1:53 pm Disc dump filename: MKB_v82_DOGMA_BCEA.tgz
Disc dump filename: MKB20_v82_Dogma_UHD_ED9E.tgz
Hey bcrush, thanks for following the template but your disc was added to the public keydb on November 20. Please make sure you try the latest keydb before posting in the future.
Thanks to everyone else who provided suitable, new disc dump files. The following discs have been added to the public keydb:Code: Select all
MKB20_v76_UHD_JOLT_D99B MKB20_v77_Riddick_E7B7 MKB20_v82_ARCANE_SEASON_2_-_DISC_1_FFC6 MKB20_v82_ARCANE_SEASON_2_-_DISC_2_7D15 MKB20_v82_ARCANE_SEASON_2_-_DISC_3_0EB7 MKB20_v82_BUGONIA_UPK75_00CC MKB20_v82_Cloud_Atlas_A6EA MKB20_v82_Dogma_UHD_ED9E MKB_v82_DOGMA_BCEA
keydb_helper
Thanks to everyone who provided suitable disc dump files. The following discs have been added to the public keydb:
MKB20_v77_Mission-_Impossible_Dead_Reckoning_Part_One_F473
MKB20_v82_OLD_BOY_8466
MKB_v82_GYROAXIA_mini_Album「REVOLVER」【Blu-ray付生産限定盤】_F116
MKB_v82_サイレント・ウィッチ_沈黙の魔女の隠しごと_3_8CD2
MKB_v82_舞台『刀剣乱舞』士伝_真贋見極める眼_本編DISC_源清麿_部隊編入ver_FAE4
MKB_v82_舞台『刀剣乱舞』士伝_真贋見極める眼_特典DISC_A32C
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
PotatoTomato
Wow, that was fast! Thank you for your excellent workkeydb_helper wrote: Tue Dec 16, 2025 10:26 pm Thanks to everyone who provided suitable disc dump files. The following discs have been added to the public keydb:Code: Select all
MKB20_v70_Avatar-_The_Way_of_Water_AE55 MKB20_v77_Mission-_Impossible_Dead_Reckoning_Part_One_F473 MKB20_v82_Downton_Abbey-_The_Grand_Finale_8CD0 MKB20_v82_OLD_BOY_8466 MKB20_v82_UHD_BALR_C7E0 MKB_v82_GYROAXIA_mini_Album「REVOLVER」【Blu-ray付生産限定盤】_F116 MKB_v82_サイレント・ウィッチ_沈黙の魔女の隠しごと_3_8CD2 MKB_v82_舞台『刀剣乱舞』士伝_真贋見極める眼_本編DISC_源清麿_部隊編入ver_FAE4 MKB_v82_舞台『刀剣乱舞』士伝_真贋見極める眼_特典DISC_A32C
BobRaygen
Hello, I am new so not sure if this is the right place to put this. But I got errors about a few of the Arcane Season 2 discs that resulted in a .tgz dump.
I already submit an email requesting these be looked at, the file names are as follows:
MKB20_v82_ARCANE_SEASON_2_-_DISC_1_FFC6.tgz
MKB20_v82_ARCANE_SEASON_2_-_DISC_2_7D15.tgz
MKB20_v82_ARCANE_SEASON_2_-_DISC_3_0EB7.tgz
NOTE: The discs 4-6 worked, but the descriptions were labeled as discs 1-3 respectively. I haven't tried to rip yet, so not sure if they work anyway.
Sanjuro
Disc type: UHD Blu-ray
Disc dump filename: MKB20_v77_VIDEODROME_0D81
Drive: BD-RE BU40N
Did you sync the public keydb within the last 15 minutes? Yes.
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1v_FrOQ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1BBjt4H ... sp=sharing
Drive: BD-RE BU40N
keydb_helper
Hi BobRaygen, please carefully read the first post of this thread. It explains how you can get your discs to work with MakeMKV. I believe all three of your discs are already supported by the public keydb (which is distinct from MakeMKV's native title support).BobRaygen wrote: Wed Dec 17, 2025 12:05 am Hello, I am new so not sure if this is the right place to put this. But I got errors about a few of the Arcane Season 2 discs that resulted in a .tgz dump.
Hey Sanjuro, thanks for following the submission template. The 0D81 variant of Videodrome has been added to the public keydb.
Padr49904
Disc type:BD
Disc dump filename: MKB_v82_Digimon_the_Movies_4-6_A74E
Drive: BD-RE BU40N
Drive firmware: 1.04
Did you sync the public keydb within the last 15 minutes?: Yes
MKB_RO.inf link: https://drive.google.com/file/d/1gpitEy ... drive_link
Disc dump link: https://drive.google.com/file/d/1dm4a0h ... drive_link
Drive: BD-RE BU40N
