Dumb Submitted Barry Lyndon
MasterDB2205
Post by MasterDB2205 »
Barry Lyndon German 4K
MrPenguin
Re: Dumb Submitted Barry Lyndon
Post by MrPenguin »
MasterDB2205 wrote:
Sun Dec 14, 2025 1:51 pm
Unfortunately this TGZ dump was created using a Pioneer BDR-S11 UHD drive, which means that some of the disk's metadata is unusable to KEYDB :(. Would you also happen to have access to an LG/ASUS/Buffalo UHD drive please?
MasterDB2205
Unfortunately not. But this wasn't the first file I've made available here, created with my Pioneer Drive. So, I'll refrain from making data available in the future if it doesn't help you. The work is then wasted.
Best regards
MrPenguin
Post by MrPenguin »
MasterDB2205 wrote:
Sun Dec 14, 2025 7:06 pm
Your work isn't necessarily wasted, because someone may still be able to match your disk to a Unit Key. However, you are very unlikely also to learn the dusk's VUK, which is what MakeMKV would need.
Did you email the dump to svq@makemkv.com?
MasterDB2205
Nope.
MasterDB2205 wrote:
Mon Dec 15, 2025 8:48 am
Nope.
If you do email the dump, a hashed key will eventually be produced and MakeMKV will be able to decrypt the disc. This works regardless of the brand of optical drive you have.
UHD FAQ
MasterDB2205
MasterDB2205 wrote: ↑Mon Dec 15, 2025 9:48 am
Nope.
Done.
MasterDB2205
Barry Lyndon still not working. :(
keydb_helper
Post by keydb_helper »
MasterDB2205 wrote:
Thu Dec 18, 2025 6:17 am
That is the unfortunate downside of the MakeMKV team choosing to obfuscate disc metadata read with Pioneer drives. If they ever change this policy, the public keydb will be able to accommodate Pioneer disc dump files in the same manner as the currently supported LG/Asus/Buffalo drives.
I'm not optimistic about such a change ever happening, so I'd recommend buying a BU40N, BP50NB40, BP60NB10, BH16NS55 or BW-16D1HT whilst they are still somewhat widely available.
Public KeyDB Disc Submissions
