Public KeyDB Disc Submissions
Juuze
Re: Rick and Morty Season 8 (bought in Germany)
Post by Juuze » Sun Dec 14, 2025 6:31 am
keydb_helper wrote: Fri Dec 12, 2025 8:37 am Hey Juuze, could you please try using a different file host? I can't seem to download anything from either link.
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.proton.me/urls/DZDDAXVSVC#NSDhIRlHmRXS
Disc dump link: https://drive.proton.me/urls/V2PYB7B8CM#DwhtIB4KgfcS
keydb_helper
Post by keydb_helper » Sun Dec 14, 2025 9:31 am
buffalobossie wrote: Sun Dec 14, 2025 1:12 am Disc dump filename: MKB20_v82_A_CANDLE_FOR_THE_DEVIL_UHD_17C4.tgz
Disc dump filename: MKB20_v82_CIN_026_At_Close_Range_B203.tgz
Disc dump filename: MKB20_v82_VSU014UHD_C5D3.tgz
Disc dump filename: MKB20_v82_VS518UHD_E047.tgz
Thanks for submitting your disc dump files buffalobossie. All four discs have been added to the public keydb.
Baden wrote: Sun Dec 14, 2025 3:19 am Newbie here, submitting a new dump of Thunderbirds.
Disc dump filename: MKB20_v82_Thunderbirds_4K_Collectors_Edition_3D88
Hey Baden, thanks for submitting that disc dump file. It corresponds to the same variant as Jay's earlier file, but your submission isn't as quirky. The disc has been added to the public keydb, so you should both be able to process it after grabbing the very latest keydb file.
fizban11 wrote: Sun Dec 14, 2025 4:36 am Saw someone posted for Minority Report 4K UHD back on the 8th, but my disc is failing to open, so it must be a different version. I apologize if redundant. Cheers and THX!
Thanks for the submission fizban11 but your disc variant is exactly the same as the one submitted by chucky527c on December 8. It was added to the public keydb later that day, so if you grab the latest keydb and configure MakeMKV to utilise it you'll be able to process your disc. Please check out the links in the opening post of this thread for more specific instructions.
OingoBoingo wrote: Sun Dec 14, 2025 6:07 am Disc type: UHD
Disc dump filename: MKB20_v77_NightOFTheLivingDead_2D25
Drive: PIONEER BD-RW BDR-UD04
Hey OingoBoingo, thanks for posting your disc dump file. The MakeMKV team have unfortunately blocked disc dump files produced with Pioneer drives from being used to expand the public keydb. So, unless you happen to have a UHD-capable LG/Asus/Buffalo drive with the MT1959 chipset you'll need to wait for either native MakeMKV support or for another user to provide a suitable disc dump file for your disc variant.
Aryastarck55 wrote: Sun Dec 14, 2025 3:13 am General
Is this a genuine UHD Blu-ray REMUX (1:1 copy from disc), or has the video/audio been re-encoded in any way?
What the fuck does your question have to do with this topic?
kasko
Post by kasko » Sun Dec 14, 2025 12:02 pm
MrPenguin wrote: Sat Dec 13, 2025 4:51 pm Yes, but this is the "Public KeyDB Disc Submissions" thread. Emailing your dump to svq@makemkv.com allows MakeMKV to add your disk to its own hashed keys database, but not to the public KEYDB file. If you would like KEYDB to support your disk as well then can you upload your disk into (say) OneDrive or Google Drive please, and then reply with a public download link?
Okay. I didn't know that. I thought it was the same. Thanks for the explanation.
kasko
Post by kasko » Sun Dec 14, 2025 12:06 pm
keydb_helper wrote: Sun Dec 14, 2025 12:52 am
There is no need to make posts like this in the public keydb submission thread. There isn't really an email address for keydb submissions and posting here to say you've emailed the MakeMKV team is pointless.
Your disc has been added to the public keydb thanks to a disc dump provided by another user. Feel free to follow the steps linked in the opening post of this thread to configure MakeMKV to utilise the public keydb.
keydb_helper
Post by keydb_helper » Sun Dec 14, 2025 12:13 pm
kasko wrote: Sun Dec 14, 2025 12:06 pm Okay. I didn't know that. I thought it was the same. Thanks for the explanation.
No worries, quite a few folks have mixed up the public keydb with MakeMKV's native title support. I understand the assumption as MakeMKV can utilise the public keydb but there is no direct coordination between the two projects.
jisoo9707
Post by jisoo9707 » Sun Dec 14, 2025 12:44 pm
MrPenguin
Post by MrPenguin » Sun Dec 14, 2025 1:28 pm
OingoBoingo wrote: Sun Dec 14, 2025 6:07 am Disc dump filename: MKB20_v77_NightOFTheLivingDead_2D25
Could you also provide the (zipped) AACS/MKB_RO.inf file from your physical UHD disk please? The MKB_RO.inf file inside your dump file has been truncated to only 56 bytes, which makes it unusable to anyone apart from MakeMKV itself.
Robusuke
Post by Robusuke » Sun Dec 14, 2025 2:38 pm
MrPenguin wrote: Sat Dec 13, 2025 5:13 pm
Robusuke wrote: Sat Dec 13, 2025 4:45 pm MKB20_v77_EVANGELION-1_11_YOU_ARE_(NOT)_ALONE_(4K_Ultra_HD_Blu-ray)_88AA.tgz
MKB20_v77_EVANGELION-2_22_YOU_CAN_(NOT)_ADVANCE_(4K_Ultra_HD_Blu-ray)_330C.tgz
Thanks, both of these disks are already in the latest public KEYDB.cfg file. Just download KEYDB.cfg, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV, and MakeMKV should then be able to decrypt your disks.
thank you!
buffalobossie
Post by buffalobossie » Sun Dec 14, 2025 2:46 pm
Looks like the Blu-ray counterpart of one of the UHDs I submitted also won't decrypt.
At Close Range
Disc type: Blu-ray
Disc dump filename: MKB_v82_CIN_026_At_Close_Range_8D44.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02 - Patched (microcode access re-enabled)
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1ml6ZRp ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1BqzfPv ... sp=sharing
albator78
Post by albator78 » Sun Dec 14, 2025 6:51 pm
Disc type: UHD
Disc dump filename: MKB20_v82_VolumeID_83A2.tgz FIST OF LEGEND FRENCH
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
Disc dump link: https://drive.google.com/file/d/1BeOOMA ... drive_link
keydb_helper
Post by keydb_helper » Sun Dec 14, 2025 10:14 pm
Thanks to everyone who provided suitable disc dump files. The following discs have been added to the public keydb:
MKB20_v76_DEVIL_IN_A_BLUE_DRESS_A125
MKB_v82_Rick_and_Morty_-_Season_8_E141
IgelWH
Post by IgelWH » Mon Dec 15, 2025 12:31 am
keydb_helper wrote: Sun Dec 14, 2025 10:14 pm Thanks to everyone who provided suitable disc dump files. The following discs have been added to the public keydb:
Will mine be checked too? Because i'm afraid you might miss out my submission post because i edited the post, which disappeared for a while til the mod approved my edited post.
Tobisatsu
Post by Tobisatsu » Mon Dec 15, 2025 12:45 am
These are for both discs of Alliance Entertainment's Ultraman 4K Discovery Release. Let me know if you need anything else!:
Disc type: UHD Ultraman 4K Discovery (Disc 1)
Disc dump filename: MKB20_v82_Ultraman_4K_Discovery_Ultra_HD_-_Disc_1_67C8.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):https://drive.google.com/file/d/1DxmmeK ... vJfiX/view
Disc dump link: https://drive.google.com/file/d/1eHw0y6 ... VL3RY/view
Disc type: UHD Ultraman 4K Discovery (Disc 2)
Disc dump filename: MKB20_v82_Ultraman_4K_Discovery_Ultra_HD_-_Disc_2_FE4E.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):https://drive.google.com/file/d/1iAI2GU ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1cZIxDB ... q-KmO/view
keydb_helper
Post by keydb_helper » Mon Dec 15, 2025 2:49 am
IgelWH wrote: Mon Dec 15, 2025 12:31 am Will mine be checked too? Because i'm afraid you might miss out my submission post because i edited the post, which disappeared for a while til the mod approved my edited post.
Hey IgelWH, you weren't kidding about your post getting caught up in the moderation queue. The 9CCD variant of The Super Mario Bros Movie has been added to the public keydb.
Looking at my notifications for this thread, I think the first post from Tobisatsu might've encountered the same fate...
minis
Post by minis » Mon Dec 15, 2025 3:25 am
4k Eddington Release, USA
MKB20_v82_Eddington_1C0B
https://drive.google.com/file/d/1nHu64p ... sp=sharing
