Public KeyDB Disc Submissions
MrPenguin
Post by MrPenguin »
kasko wrote:
Sat Dec 13, 2025 1:05 pm
Dump MKB20_v82_Daylight_9E16.tgz
Could you provide a public download link for this TGZ dump file please, if you wish your disk to be added to the public KEYDB file?
Chris01992
Post by Chris01992 »
Disc type: UHD
Disc dump filename: MKB20_v82_NIGHTMARE_ALLEY_-_DISC_TWO_B576.tgz
Drive: LG BU40N
Drive firmware: 1.03 - Patched (microcode access re-enabled)
LibreDrive status: Enabled
MKB_RO.inf link: [Not sure where to find this on MacOS]
Disc dump link: https://drive.google.com/file/d/1a31DFM ... share_link
Chris01992
Not sure if this is the correct place for this, but the disc returned an error saying that a newer version of AACS protection was in use & was unsupported.
Disc type: Blu-Ray
Disc dump filename: MKB_v82_THE_CURE_-_SHOW_OF_A_LOST_WORLD_4C50.tgz
Drive: LG BU40N
Disc dump link: https://drive.google.com/file/d/10-7dfQ ... share_link
kasko
Post by kasko »
MrPenguin wrote:
Sat Dec 13, 2025 1:28 pm
I sent the dump via email.
MKVDUDE
Post by MKVDUDE »
Disc type: UHD / BD
Disc dump filenames: MKB20_v82_THE_WILD_GEESE_UHD_89B2.tgz + MKB_v82_THE_WILD_GEESE_BD_CB7E.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-yDnd0Ymn7X
Many thanks!
Robusuke
Post by Robusuke »
Hello, I would like to share a disk dump file. Is this correct?
MKB20_v77_EVANGELION-1_11_YOU_ARE_(NOT)_ALONE_(4K_Ultra_HD_Blu-ray)_88AA.tgz
MKB20_v77_EVANGELION-2_22_YOU_CAN_(NOT)_ADVANCE_(4K_Ultra_HD_Blu-ray)_330C.tgz
Firmware version: 0.BU10O
MrPenguin
Post by MrPenguin »
kasko wrote:
Sat Dec 13, 2025 2:04 pm
Yes, but this is the "Public KeyDB Disc Submissions" thread. Emailing your dump to svq@makemkv.com allows MakeMKV to add your disk to its own hashed keys database, but not to the public KEYDB file. If you would like KEYDB to support your disk as well then can you upload your disk into (say) OneDrive or Google Drive please, and then reply with a public download link?
MrPenguin
Post by MrPenguin »
Robusuke wrote:
Sat Dec 13, 2025 4:45 pm
Thanks, both of these disks are already in the latest public KEYDB.cfg file. Just download KEYDB.cfg, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV, and MakeMKV should then be able to decrypt your disks.
TheSound
Public KeyDB Disc Submissions - Westernhagen live
Post by TheSound »
many thanks for help. Unfortunately i do not have any public storage space available
Disc type: Blu-Ray
Disc dump filename: MKB_v82_Westernhagen_LIVE_E27E.tgz
Drive: BW-16D1HT
Drive firmware: 3.01 - Original (unpatched)
Link: https://transfer.it/t/5cx47Bt3WBgC
IgelWH
Post by IgelWH »
Here's my German 4K UHD Blu Ray Disc of the Super Mario Bros. Movie
Disc type: UHD
Disc dump filename: MKB20_v77_The_Super_Mario_Bros_Movie_(2023)_9CCD
Drive: ASUS BW-16D1HT
Drive firmware: 3.10MK
Did you sync the public keydb within the last 15 minutes? Yes (I downloaded it from the site again and put it on the MakeMKV directory and also in C:\ProgramData\aacs
MKB_RO.inf link : https://mega.nz/file/KZZCGBCS#83od2TfvB ... 45QzqValPY, https://mega.nz/file/zYRwgYwB#eRl2yhPM7 ... 0GLkzclG98 (from the DUPLICATE folder)
Disc dump link: https://mega.nz/file/fUxAzAya#eRBUmukko ... T2yrKPIV8c
keydb_helper
Post by keydb_helper »
treatsbyjay wrote:
Sat Dec 13, 2025 12:25 pm
First time submitting so hope I got all this right!
Disc dump filename: MKB20_v82_Thunderbirds_4K_Collectors_Edition_3D88.tgz
Hey Jay, thanks for submitting that disc dump file. You did everything right, but MakeMKV seems to have run into an issue whilst generating that disc dump file.
Could you please move that dump file out of MakeMKV's data directory, completely power off your disc drive, restart your computer and generate a new disc dump file? Feel free to post the newly generated disc dump file to this thread whenever you get a chance.
There is no need to change any MakeMKV setting or drive firmware. I believe the cause was either a transient issue or possibly a quirk of your particular disc.
Apart from Thunderbirds, I believe all other submissions have been processed and added to the public keydb:
MKB20_v77_Scars_of_Dracula_8354
mkb20_v82_daylight_9e16
mkb20_v82_hellraiser_e90e
MKB20_v82_JACKIE_BROWN_E202
TheSound wrote:
Sat Dec 13, 2025 6:06 pm
Please don't attach disc dump files to forum posts, it creates work for the moderators and cause issues. There are many free public file hosts. Swisstransfer, Wetransfer, Mediafire etc are all fine choices for the purposes of the keydb.
There is no need to make posts like this in the public keydb submission thread. There isn't really an email address for keydb submissions and posting here to say you've emailed the MakeMKV team is pointless.
Your disc has been added to the public keydb thanks to a disc dump provided by another user. Feel free to follow the steps linked in the opening post of this thread to configure MakeMKV to utilise the public keydb.
buffalobossie
Post by buffalobossie »
A Candle for the Devil
Disc type: UHD
Disc dump filename: MKB20_v82_A_CANDLE_FOR_THE_DEVIL_UHD_17C4.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02 - Patched (microcode access re-enabled)
MKB_RO.inf link: https://drive.google.com/file/d/1bxS68U ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1_ga1Z3 ... sp=sharing
At Close Range
Disc type: UHD
Disc dump filename: MKB20_v82_CIN_026_At_Close_Range_B203.tgz
MKB_RO.inf link: https://drive.google.com/file/d/18_Syj1 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/11ZEORz ... sp=sharing
The Garbage Pail Kids Movie
Disc type: UHD
Disc dump filename: MKB20_v82_VSU014UHD_C5D3.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1JHXVNf ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1AlI9zR ... sp=sharing
Timecrimes
Disc type: UHD
Disc dump filename: MKB20_v82_VS518UHD_E047.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1o4iLEE ... sp=sharing
Disc dump link: https://drive.google.com/file/d/15ypeaE ... sp=sharing
Baden
Post by Baden »
keydb_helper wrote:
Sun Dec 14, 2025 12:52 am
Newbie here, submitting a new dump of Thunderbirds.
Disc type: UHD
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.mediafire.com/file/0bf5x7d4 ... O.inf/file
Disc dump link: https://www.mediafire.com/file/nsgmnmoh ... 8.tgz/file
fizban11
Post by fizban11 »
Saw someone posted for Minority Report 4K UHD back on the 8th, but my disc is failing to open, so it must be a different version. I apologize if redundant. Cheers and THX!
Disc type: UHD
Disc dump filename: MKB20_v82_MINORITY_REPORT_9A41
Drive: BD-RE LG WH16NS40
Drive firmware: 1.05
MKB_RO.zip
(3.14 MiB) Downloaded 186 times
OingoBoingo
Post by OingoBoingo »
Hi, this is the dump for the Italian 4k of Night Of the Living Dead ( 1968 ) recently included in a boxset with the other Romero's zombie movies.
Disc type: UHD
Disc dump filename: MKB20_v77_NightOFTheLivingDead_2D25
Drive: PIONEER BD-RW BDR-UD04
Drive firmware: 1.14
Disc dump link: https://mega.nz/file/hNg0GDYT#NoLxdn1eh ... 023seVLKJ0
