I sent the dump via email.
Public KeyDB Disc Submissions
MKVDUDE
Disc type: UHD / BD
Disc dump filenames: MKB20_v82_THE_WILD_GEESE_UHD_89B2.tgz + MKB_v82_THE_WILD_GEESE_BD_CB7E.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-yDnd0Ymn7X
Many thanks!
Drive: BD-RE BU40N
Many thanks!
Robusuke
Hello, I would like to share a disk dump file. Is this correct?
MKB20_v77_EVANGELION-1_11_YOU_ARE_(NOT)_ALONE_(4K_Ultra_HD_Blu-ray)_88AA.tgz
MKB20_v77_EVANGELION-2_22_YOU_CAN_(NOT)_ADVANCE_(4K_Ultra_HD_Blu-ray)_330C.tgz
Firmware version: 0.BU10O
MrPenguin
Yes, but this is the "Public KeyDB Disc Submissions" thread. Emailing your dump to svq@makemkv.com allows MakeMKV to add your disk to its own hashed keys database, but not to the public KEYDB file. If you would like KEYDB to support your disk as well then can you upload your disk into (say) OneDrive or Google Drive please, and then reply with a public download link?
MrPenguin
Thanks, both of these disks are already in the latest public KEYDB.cfg file. Just download KEYDB.cfg, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV, and MakeMKV should then be able to decrypt your disks.Robusuke wrote: Sat Dec 13, 2025 4:45 pm MKB20_v77_EVANGELION-1_11_YOU_ARE_(NOT)_ALONE_(4K_Ultra_HD_Blu-ray)_88AA.tgz
TheSound
Public KeyDB Disc Submissions - Westernhagen live
many thanks for help. Unfortunately i do not have any public storage space available
Disc type: Blu-Ray
Disc dump filename: MKB_v82_Westernhagen_LIVE_E27E.tgz
Drive: BW-16D1HT
Drive firmware: 3.01 - Original (unpatched)
Link: https://transfer.it/t/5cx47Bt3WBgC
Disc type: Blu-Ray
Drive: BW-16D1HT
IgelWH
Here's my German 4K UHD Blu Ray Disc of the Super Mario Bros. Movie
Disc type: UHD
Disc dump filename: MKB20_v77_The_Super_Mario_Bros_Movie_(2023)_9CCD
Drive: ASUS BW-16D1HT
Drive firmware: 3.10MK
Did you sync the public keydb within the last 15 minutes? Yes (I downloaded it from the site again and put it on the MakeMKV directory and also in C:\ProgramData\aacs
MKB_RO.inf link : https://mega.nz/file/KZZCGBCS#83od2TfvB ... 45QzqValPY, https://mega.nz/file/zYRwgYwB#eRl2yhPM7 ... 0GLkzclG98 (from the DUPLICATE folder)
Disc dump link: https://mega.nz/file/fUxAzAya#eRBUmukko ... T2yrKPIV8c
Disc type: UHD
keydb_helper
Hey Jay, thanks for submitting that disc dump file. You did everything right, but MakeMKV seems to have run into an issue whilst generating that disc dump file.treatsbyjay wrote: Sat Dec 13, 2025 12:25 pm First time submitting so hope I got all this right!
Disc dump filename: MKB20_v82_Thunderbirds_4K_Collectors_Edition_3D88.tgz
Could you please move that dump file out of MakeMKV's data directory, completely power off your disc drive, restart your computer and generate a new disc dump file? Feel free to post the newly generated disc dump file to this thread whenever you get a chance.
There is no need to change any MakeMKV setting or drive firmware. I believe the cause was either a transient issue or possibly a quirk of your particular disc.
Apart from Thunderbirds, I believe all other submissions have been processed and added to the public keydb:
MKB20_v77_Scars_of_Dracula_8354
mkb20_v82_daylight_9e16
mkb20_v82_hellraiser_e90e
MKB20_v82_JACKIE_BROWN_E202
MKB20_v82_NIGHTMARE_ALLEY_-_DISC_TWO_B576
MKB_v82_THE_CURE_-_SHOW_OF_A_LOST_WORLD_4C50
Please don't attach disc dump files to forum posts, it creates work for the moderators and cause issues. There are many free public file hosts. Swisstransfer, Wetransfer, Mediafire etc are all fine choices for the purposes of the keydb.TheSound wrote: Sat Dec 13, 2025 6:06 pm many thanks for help. Unfortunately i do not have any public storage space available
There is no need to make posts like this in the public keydb submission thread. There isn't really an email address for keydb submissions and posting here to say you've emailed the MakeMKV team is pointless.
Your disc has been added to the public keydb thanks to a disc dump provided by another user. Feel free to follow the steps linked in the opening post of this thread to configure MakeMKV to utilise the public keydb.
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
buffalobossie
A Candle for the Devil
Disc type: UHD
Disc dump filename: MKB20_v82_A_CANDLE_FOR_THE_DEVIL_UHD_17C4.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02 - Patched (microcode access re-enabled)
MKB_RO.inf link: https://drive.google.com/file/d/1bxS68U ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1_ga1Z3 ... sp=sharing
At Close Range
Disc type: UHD
Disc dump filename: MKB20_v82_CIN_026_At_Close_Range_B203.tgz
MKB_RO.inf link: https://drive.google.com/file/d/18_Syj1 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/11ZEORz ... sp=sharing
The Garbage Pail Kids Movie
Disc type: UHD
Disc dump filename: MKB20_v82_VSU014UHD_C5D3.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1JHXVNf ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1AlI9zR ... sp=sharing
Timecrimes
Disc type: UHD
Disc dump filename: MKB20_v82_VS518UHD_E047.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1o4iLEE ... sp=sharing
Disc dump link: https://drive.google.com/file/d/15ypeaE ... sp=sharing
Disc type: UHD
At Close Range
Disc type: UHD
Disc type: UHD
Timecrimes
Disc type: UHD
Baden
Newbie here, submitting a new dump of Thunderbirds.keydb_helper wrote: Sun Dec 14, 2025 12:52 amHey Jay, thanks for submitting that disc dump file. You did everything right, but MakeMKV seems to have run into an issue whilst generating that disc dump file.treatsbyjay wrote: Sat Dec 13, 2025 12:25 pm First time submitting so hope I got all this right!
Disc type: UHD
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.mediafire.com/file/0bf5x7d4 ... O.inf/file
Disc dump link: https://www.mediafire.com/file/nsgmnmoh ... 8.tgz/file
fizban11
Saw someone posted for Minority Report 4K UHD back on the 8th, but my disc is failing to open, so it must be a different version. I apologize if redundant. Cheers and THX!
Disc type: UHD
Disc dump filename: MKB20_v82_MINORITY_REPORT_9A41
Drive: BD-RE LG WH16NS40
Drive firmware: 1.05
Disc type: UHD
OingoBoingo
Hi, this is the dump for the Italian 4k of Night Of the Living Dead ( 1968 ) recently included in a boxset with the other Romero's zombie movies.
Disc type: UHD
Disc dump filename: MKB20_v77_NightOFTheLivingDead_2D25
Drive: PIONEER BD-RW BDR-UD04
Drive firmware: 1.14
Disc dump link: https://mega.nz/file/hNg0GDYT#NoLxdn1eh ... 023seVLKJ0
Disc type: UHD
Juuze
Re: Rick and Morty Season 8 (bought in Germany)
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.proton.me/urls/DZDDAXVSVC#NSDhIRlHmRXSkeydb_helper wrote: Fri Dec 12, 2025 8:37 am Hey Juuze, could you please try using a different file host? I can't seem to download anything from either link.
Disc dump link: https://drive.proton.me/urls/V2PYB7B8CM#DwhtIB4KgfcS
keydb_helper
Thanks for submitting your disc dump files buffalobossie. All four discs have been added to the public keydb.buffalobossie wrote: Sun Dec 14, 2025 1:12 am Disc dump filename: MKB20_v82_A_CANDLE_FOR_THE_DEVIL_UHD_17C4.tgz
Hey Baden, thanks for submitting that disc dump file. It corresponds to the same variant as Jay's earlier file, but your submission isn't as quirky. The disc has been added to the public keydb, so you should both be able to process it after grabbing the very latest keydb file.Baden wrote: Sun Dec 14, 2025 3:19 am Newbie here, submitting a new dump of Thunderbirds.
Thanks for the submission fizban11 but your disc variant is exactly the same as the one submitted by chucky527c on December 8. It was added to the public keydb later that day, so if you grab the latest keydb and configure MakeMKV to utilise it you'll be able to process your disc. Please check out the links in the opening post of this thread for more specific instructions.fizban11 wrote: Sun Dec 14, 2025 4:36 am Saw someone posted for Minority Report 4K UHD back on the 8th, but my disc is failing to open, so it must be a different version. I apologize if redundant. Cheers and THX!
Hey OingoBoingo, thanks for posting your disc dump file. The MakeMKV team have unfortunately blocked disc dump files produced with Pioneer drives from being used to expand the public keydb. So, unless you happen to have a UHD-capable LG/Asus/Buffalo drive with the MT1959 chipset you'll need to wait for either native MakeMKV support or for another user to provide a suitable disc dump file for your disc variant.OingoBoingo wrote: Sun Dec 14, 2025 6:07 am Disc type: UHD
What the fuck does your question have to do with this topic?Aryastarck55 wrote: Sun Dec 14, 2025 3:13 am General
Is this a genuine UHD Blu-ray REMUX (1:1 copy from disc), or has the video/audio been re-encoded in any way?
kasko
Okay. I didn't know that. I thought it was the same. Thanks for the explanation.MrPenguin wrote: Sat Dec 13, 2025 4:51 pm Yes, but this is the "Public KeyDB Disc Submissions" thread. Emailing your dump to svq@makemkv.com allows MakeMKV to add your disk to its own hashed keys database, but not to the public KEYDB file. If you would like KEYDB to support your disk as well then can you upload your disk into (say) OneDrive or Google Drive please, and then reply with a public download link?
