keydb_helper
Post
by keydb_helper » Fri Dec 12, 2025 8:37 am
Thanks to everyone who provided disc dump files. I believe all valid, accessible disc dump submissions have been processed and submitted to the public keydb. The following UHD discs corresponded to new media keys:
mkb20_v82_36_quai_des_orfevres_2f90
mkb20_v82_36_quai_des_orfevres_c504
MKB20_v82_Dust_Devil_UHD_557A
MKB20_v82_Rabid
MKB20_v82_Tai_Chi_Master_06CE
mkb20_v82_the_gold_rush_d128
MKB20_v82_THE_SHROUDS
Juuze wrote: Fri Dec 12, 2025 12:05 am
Disc dump filename: MKB_v82_Rick_and_Morty_-_Season_8_E141.tgz
Disc dump link: ...
Hey Juuze, could you please try using a different file host? I can't seem to download anything from either link.
Public KeyDB Disc Submissions
MKVDUDE
Post
by MKVDUDE » Fri Dec 12, 2025 1:01 pm
Disc type: UHD
Disc dump filename: MKB20_v82_UNDER_SIEGE_-_UHD_F0F0.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: N/A
Disc dump link:
https://we.tl/t-Ju2mcNhnLm
Many thanks!
MKVDUDE
Post
by MKVDUDE » Fri Dec 12, 2025 1:04 pm
Disc type: UHD
Disc dump filename: MKB20_v82_SNAKES_ON_A_PLANE_-_UHD_4F6C.tgz
Drive: BD-RE BU40N
Disc dump link:
https://we.tl/t-FvnxNzSHIr
Many thanks!
ergassia
Post
by ergassia » Fri Dec 12, 2025 1:41 pm
Hi, dumps to two new UHD 4K Italian version of Once Upon a Time in America (1984)
The dumps are in the same file zip.
Disc type: UHD
Disc ID: 0xF0E36B942527990CBA3249FF4707BDCB90E1ED9D
Disc dump filename: MKB20_v82_C'era_una_volta_in_America_-_EXTENDED_E5F2.tgz
Drive: BD-RE BU40N
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link:
https://www.mediafire.com/file/xs2q18il ... p.zip/file
Disc type: UHD
Disc ID: 0x057613790E4E1EA3E484F1D85BA5709383121B0E
Disc dump filename: MKB20_v82_C'era_una_volta_in_America_C438.tgz
Drive: BD-RE BU40N
MKB_RO.inf link:
Thanks in advance.
mureined
Post
by mureined » Fri Dec 12, 2025 2:33 pm
Disc type: UHD
Disc dump filename: MKB20_v82_KILL_BILL_-_VOLUME_2_338E.tgz
Drive: BD-RE BU40N
Drive firmware: 1.00
MKB_RO.inf link:
https://we.tl/t-6PESSSInsu
Disc dump link:
https://we.tl/t-F8o179xhz0
Many thanks!
mureined
Post
by mureined » Fri Dec 12, 2025 2:39 pm
Disc type: UHD
Disc dump filename: MKB20_v82_KILL_BILL_-_VOLUME_1_59D6.tgz
Drive: BD-RE BU40N
MKB_RO.inf link:
https://we.tl/t-zhC1oWTSaY
Disc dump link:
https://we.tl/t-gXROc9xQzF
Many thanks!
(Duplicate entry, I had forgot to attach MKB_RO.inf link. Aplogies for the mistake.)
keydb_helper
Post
by keydb_helper » Fri Dec 12, 2025 2:56 pm
MKVDUDE wrote: Fri Dec 12, 2025 1:01 pm
MKVDUDE wrote: Fri Dec 12, 2025 1:04 pm
Hey MKVDUDE, thanks again for following the submission template. Both of your discs have been added to the public keydb.
MKVDUDE
Post
by MKVDUDE » Fri Dec 12, 2025 8:09 pm
keydb_helper wrote: Fri Dec 12, 2025 2:56 pm
Thanks again for another quick turnaround!
rhett7660
Post
by rhett7660 » Fri Dec 12, 2025 8:34 pm
Disc type: UHD
Disc dump filename: MKB20_v77_The_Emperor's_New_Groove_571C.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: N.A
Disc dump link:
https://drive.google.com/file/d/19aAxeF ... drive_link
MrPenguin
Post
by MrPenguin » Fri Dec 12, 2025 11:21 pm
rhett7660 wrote: Fri Dec 12, 2025 8:34 pm
Can you change the "Share" option for this file please, so that people can download it?
keydb_helper
Post
by keydb_helper » Sat Dec 13, 2025 6:43 am
MKB20_v77_SPINAL_TAP_II_END_CONTINUES_AC8A
MKB20_v82_Fade_To_Black_DC44
MKB20_v82_GI_Jane_UHD_5DBE
MKB20_v82_Possession_UHD
mureined
Post
by mureined » Sat Dec 13, 2025 9:49 am
keydb_helper wrote: Sat Dec 13, 2025 6:43 am
Thank you very much for adding the files to the DB! I can confirm both disks above open up perfectly.
kasko
Post
by kasko » Sat Dec 13, 2025 1:05 pm
Dump MKB20_v82_Daylight_9E16.tgz
