Disc Type: BD-ROM
Disc dump Filename: MKB_v82_Geh_und_Sieh_AC6E
Drive: BD-RE BU40N
Drive Firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1AVytsb ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1dqUa0R ... sp=sharing
Public KeyDB Disc Submissions
jackycyk0924
Hi I would like to submit a dump for a Japanese concert Blu-ray disc. You help is much appreciated. Thanks!
Disc Type: BD-ROM
Disc dump Filename: MKB_v82_BD_ROM_8F88
Drive: BD-RE ASUS SBW-06D5H-U E101 AGDL233009WLd
Disc dump link: https://drive.google.com/file/d/14ssr6d ... sp=sharing
Disc Type: BD-ROM
sammyd1108
Awesome, I just started ripping it, been trying to do it for over a week now. For the most part, all the new stuff I get has already had someone submit it anyway so hopefully I won’t need to do this too much.keydb_helper wrote: Thu Dec 11, 2025 7:36 amHey sammyd1108, your particular disc variant (MKB20_v82_A_HISTORY_OF_VIOLENCE_8171) has been added to the public keydb.sammyd1108 wrote: Thu Dec 11, 2025 5:09 am So I just realized, that since I have a Pioneer drive, I can’t get any of the keys I need added?
Maybe I can get my old LG drive to at least open the disc.
This was only possible as the media key for a different variant of A History of Violence was added on October 3rd. Because LibreDrive doesn't currently obfuscate the volume ID (VID) returned from your drive, the dump file can be used to generate keydb records when the media key is already known.
If you do have an LG/Asus drive that would be preferable as they produce disc dumps which can be used to generate keydb records from scratch.
Carpet
The Public KeyDB website appears to be down, getting a 404 error.
It's not. I was able to get to it just fine.
FootFungus07
Troll 2 Vinegar Syndrome TGZ Key File
Disc type: UHD
Disc dump filename: MKB20_v82_VS520UHD_CE33.tgz
Drive: BD-RE BP60NB10
Drive firmware: 2120-05-07 09:35
I have a link for the TGZ file, but it seems way too small, so I'm including a second link for the MKB_RO.inf file as well:
MKB20_v82_VS520UHD_CE33.tgz link:
https://drive.google.com/file/d/1RICH0- ... drive_link
Troll 2 MKB_RO.inf file:
https://drive.google.com/file/d/1DxLaMz ... drive_link
Thanks again!
Disc type: UHD
Thanks again!
Azerbeam971
Here is the dump for the UHD Blu-Ray of Tai-Chi Master (french uhd blu-ray)
https://mega.nz/file/O5JWlBza#o1aYZYr2D ... 4iRslw6_Lg
MrPenguin
The KEYDB site only supports HTTP. Check whether your browser is trying to use HTTPS by default.Carpet wrote: Thu Dec 11, 2025 7:13 pm The Public KeyDB website appears to be down, getting a 404 error.
Juuze
Re: Rick and Morty Season 8 (bought in Germany)
Disc type: Blu-ray
Disc dump filename: MKB_v82_Rick_and_Morty_-_Season_8_E141.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://cloud.juuze.de/s/pWAdD52ryqjDHMm
Disc dump link: https://cloud.juuze.de/s/R8zjKSoDjeGgNF4
mhalter81
I have 2 out of the Blaxploitation Classics Vol 1.
MKB20_v77_Black_Caesar_5E6B,
MKB20_v77_Truck_Turner_4D2F
Disc dump links below.
https://drive.google.com/file/d/1Pt7Snm ... drive_link
https://drive.google.com/file/d/16U30cX ... drive_link
SnakePlissken
Hope this is right, here goes.
Disc type:UHD
Disc dump filename:MKB20_v82_Fade_To_Black_DC44
Drive:WH16NS60
Drive firmware:1.02
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?Yes
Disc dump link:https://www.dropbox.com/scl/fi/jfnc0q91 ... q4vzo&dl=0
Disc type:UHD
Drive:WH16NS60
Drive firmware:1.02
keydb_helper
Thanks to everyone who provided disc dump files. I believe all valid, accessible disc dump submissions have been processed and submitted to the public keydb. The following UHD discs corresponded to new media keys:
mkb20_v82_36_quai_des_orfevres_2f90
mkb20_v82_36_quai_des_orfevres_c504
MKB20_v82_Dust_Devil_UHD_557A
MKB20_v82_Rabid
MKB20_v82_Tai_Chi_Master_06CE
mkb20_v82_the_gold_rush_d128
MKB20_v82_THE_SHROUDS
Hey Juuze, could you please try using a different file host? I can't seem to download anything from either link.Juuze wrote: Fri Dec 12, 2025 12:05 am Disc dump filename: MKB_v82_Rick_and_Morty_-_Season_8_E141.tgz
Disc dump link: ...
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
MKVDUDE
Disc type: UHD
Disc dump filename: MKB20_v82_UNDER_SIEGE_-_UHD_F0F0.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link: N/A
Disc dump link: https://we.tl/t-Ju2mcNhnLm
Many thanks!
Drive: BD-RE BU40N
Many thanks!
MKVDUDE
Disc type: UHD
Disc dump filename: MKB20_v82_SNAKES_ON_A_PLANE_-_UHD_4F6C.tgz
Drive: BD-RE BU40N
Disc dump link: https://we.tl/t-FvnxNzSHIr
Many thanks!
Drive: BD-RE BU40N
Many thanks!
