Thank youkeydb_helper wrote: ↑Thu Dec 11, 2025 2:19 amHey Toad King, albator78 & chucky527c, thank you for the new submissions. Your discs have been added to the public keydb along with these other titles:chucky527c wrote: ↑Thu Dec 11, 2025 2:06 amDisc dump filename: MKB20_v82_UHD_Omniscient_Reader_6AD2.tgzCode: Select all
MKB20_v76_THE_SWORD_AND_THE_SORCERER MKB20_v77_BLACK_HAWK_DOWN MKB20_v77_MEGALOPOLIS_2DF4 MKB20_v77_LES_TROIS_MOUSQUETAIRES_D3F4
Public KeyDB Disc Submissions
Disc type: UHD
Disc dump filename:
MKBv82「でっちあげ_~殺人教師と呼ばれた男」_AE10
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
Disc dump link: https://drive.google.com/file/d/11GzYv- ... sp=sharing
Disc dump filename:
Drive: BD-RE BU40N
Disc type: BD(AACSv82)
Disc dump filename: MKB_v82_22_7_keisangai_season1_Vol_1_D64C.tgz
Drive: BU40N
Drive firmware: 1.03MK
LibreDrive status: Yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://gofile.io/d/LAbIck
Disc dump link: https://gofile.io/d/D0KL8y
tried rdkfrommmkv & aacskeys with no luck. ripped other 4 BDs w/ no problems. wondering why.
Drive: BU40N
Disc Type: BD-ROM
Disc dump Filename: MKB_v82_Geh_und_Sieh_AC6E
Drive: BD-RE BU40N
Drive Firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1AVytsb ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1dqUa0R ... sp=sharing
Drive: BD-RE BU40N
jackycyk0924
Hi I would like to submit a dump for a Japanese concert Blu-ray disc. You help is much appreciated. Thanks!
Disc Type: BD-ROM
Disc dump Filename: MKB_v82_BD_ROM_8F88
Drive: BD-RE ASUS SBW-06D5H-U E101 AGDL233009WLd
Disc dump link: https://drive.google.com/file/d/14ssr6d ... sp=sharing
Disc Type: BD-ROM
sammyd1108
Awesome, I just started ripping it, been trying to do it for over a week now. For the most part, all the new stuff I get has already had someone submit it anyway so hopefully I won’t need to do this too much.keydb_helper wrote: ↑Thu Dec 11, 2025 7:36 amHey sammyd1108, your particular disc variant (MKB20_v82_A_HISTORY_OF_VIOLENCE_8171) has been added to the public keydb.sammyd1108 wrote: ↑Thu Dec 11, 2025 5:09 amSo I just realized, that since I have a Pioneer drive, I can’t get any of the keys I need added?
Maybe I can get my old LG drive to at least open the disc.
This was only possible as the media key for a different variant of A History of Violence was added on October 3rd. Because LibreDrive doesn't currently obfuscate the volume ID (VID) returned from your drive, the dump file can be used to generate keydb records when the media key is already known.
If you do have an LG/Asus drive that would be preferable as they produce disc dumps which can be used to generate keydb records from scratch.
The Public KeyDB website appears to be down, getting a 404 error.
It's not. I was able to get to it just fine.
FootFungus07
Troll 2 Vinegar Syndrome TGZ Key File
Disc type: UHD
Disc dump filename: MKB20_v82_VS520UHD_CE33.tgz
Drive: BD-RE BP60NB10
Drive firmware: 2120-05-07 09:35
I have a link for the TGZ file, but it seems way too small, so I'm including a second link for the MKB_RO.inf file as well:
MKB20_v82_VS520UHD_CE33.tgz link:
https://drive.google.com/file/d/1RICH0- ... drive_link
Troll 2 MKB_RO.inf file:
https://drive.google.com/file/d/1DxLaMz ... drive_link
Thanks again!
Disc type: UHD
Thanks again!
Azerbeam971
Here is the dump for the UHD Blu-Ray of Tai-Chi Master (french uhd blu-ray)
https://mega.nz/file/O5JWlBza#o1aYZYr2D ... 4iRslw6_Lg
The KEYDB site only supports HTTP. Check whether your browser is trying to use HTTPS by default.Carpet wrote: ↑Thu Dec 11, 2025 7:13 pmThe Public KeyDB website appears to be down, getting a 404 error.
Re: Rick and Morty Season 8 (bought in Germany)
Disc type: Blu-ray
Disc dump filename: MKB_v82_Rick_and_Morty_-_Season_8_E141.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://cloud.juuze.de/s/pWAdD52ryqjDHMm
Disc dump link: https://cloud.juuze.de/s/R8zjKSoDjeGgNF4
I have 2 out of the Blaxploitation Classics Vol 1.
MKB20_v77_Black_Caesar_5E6B,
MKB20_v77_Truck_Turner_4D2F
Disc dump links below.
https://drive.google.com/file/d/1Pt7Snm ... drive_link
https://drive.google.com/file/d/16U30cX ... drive_link
SnakePlissken
Hope this is right, here goes.
Disc type:UHD
Disc dump filename:MKB20_v82_Fade_To_Black_DC44
Drive:WH16NS60
Drive firmware:1.02
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?Yes
Disc dump link:https://www.dropbox.com/scl/fi/jfnc0q91 ... q4vzo&dl=0
Disc type:UHD
Drive:WH16NS60
Drive firmware:1.02
