Where are the SDF.bin and private_data.tar located on Linux ?
georgesgiralt
Post by georgesgiralt »
Hi Guys,
Everything is in the title.
I just keep reference of these two files and can't find them on my 1.18.2 installation.
So I would like to know if they are needed and if yes where in Ubuntu/linux installation.
Thanks in advance.
MrPenguin
Re: Where are the SDF.bin and private_data.tar located on Linux ?
Post by MrPenguin »
georgesgiralt wrote: Wed Dec 10, 2025 2:52 pm So I would like to know if they are needed and if yes where in Ubuntu/linux installation.
Try $HOME/.MakeMKV/_private_data.tar. The sdf.bin file is inside _private_data.tar.
georgesgiralt
Thank you. I've a bunch of sdf_00000NNN.bin in the tar file !
