Public KeyDB Disc Submissions
ehmkayvee
Post by ehmkayvee »
Disc type: Blu-ray
Disc dump filename: MKB_v82_映画ドラえもん_のび太の絵世界物語_0EEE
Drive: BD-RW BDR-XD08U
Drive firmware: 1.04
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1YL61V0 ... share_link
Disc dump link: https://drive.google.com/file/d/1SrHR-X ... share_link
mediumwave
Post by mediumwave »
Disc type: BD
Disc dump filename/s: MKB_v82_BROTHERHOOD_F556.tgz; MKB_v82_MOVEMENT_8BDE.tgz; MKB_v82_LOWLIFE_9DDC.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
keydb_helper
Post by keydb_helper »
dougy wrote:
Wed Dec 10, 2025 7:14 am
Could you please double check? I did everything again (disc dump and MKB_RO.inf).
Sorry, but there is no need for me to double check. I only post here after titles are added to the public keydb. If you open up your downloaded keydb.cfg file in a text editor you should be able to find a line like this:
0xE77E4797D5E234B5AAE62C1E7E170CBF33D0EA0E = 28 Years Later (28 Years Later - Blu-ray™) ... <Keys redacted for the forum>
If you can't find a line which contains your disc ID (0xE77E4797D5E234B5AAE62C1E7E170CBF33D0EA0E), it means you haven't grabbed the latest keydb file.
Why doesn’t this work?
If it doesn't work, it means you have either:
1. Put the keydb file in the wrong folder. Make sure you put the unzipped keydb file in the same directory where you originally found your MKB_v82_28_Years_Later_E8D2.tgz disc dump file.
2. The file is not named correctly. macOS/Linux systems can treat files in a case sensitive manner. You've already tried 'keydb.cfg', so I think the other two possibilities are either: 'KEYDB.CFG' or 'KEYDB.cfg'
If you still can't get it working after confirming the correct folder and renaming the keydb.cfg file, please make a new forum thread.
November 26 2025:
keydb_helper wrote:
Thu Nov 27, 2025 12:52 am
Thanks to everyone who provided suitable disc dump files. I believe all submitted discs have been added to the public keydb. The following UHD disc submissions corresponded to new media keys:
[b]MKB20_v82_DOGMA_UHD_1B6E[/b]
hfmets wrote:
Wed Dec 10, 2025 12:06 am
Disc dump filename: MKB20_v82_Dogma_1B6E.tgz
Fuck off hfmets. Don't waste my time by submitting titles which are already supported by the public keydb.
mediumwave
Sorry, I forgot the MKB_RO files for the New Order discs. Zipped for each disc attached.
Please let me know if I need to resubmit altogether!
MKB_RO.zip
(46.03 KiB) Downloaded 127 times
FeeFeeZ
Post by FeeFeeZ »
Disc type: Blu-ray
Disc dump filename: MKB_v82_BD_ROM_DCD6
Drive: BUFFALO BRUHD (MO4K4CH0948)
MKB_RO.inf link: https://drive.google.com/file/d/1yYvkEB ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1kPydJL ... sp=sharing
Hi! My first time submitting here.
This is a Blu-ray disc that comes with a Japanese mini album ClariS-リンクス(完全生産限定盤), catalog number VVCL-2832~3 from Sacra Music (Sony Music Entertainment)
Thanks in advance!
HeebusJeebus
Post by HeebusJeebus »
Disc type: Blu-Ray
Disc dump filename: MKB_v82_Rick_and_Morty_-_Season_8_7DB6
Drive: BH16NS55
Drive firmware: 1.02
MKB_RO.inf link: https://drive.google.com/file/d/1DIsTzC ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1CxAqWY ... sp=sharing
I've just correctly seen to the keydb stage. The disc might now be working, if it does I'll delete this post.
I can't delete the post anymore but the discs ripped fine now, though with AV sync errors I've never seen before.
Respectfully, it's all very well saying how easy this is (and once you've been fully through it once and got it working, it is) but it isn't intuitive at all for first timers who've ripped hundreds of discs who suddenly get these issues, and makemkv itself only advises you to click a link about the AACS version and nothing else. I had to trawl around to find this thread, then look at other linked threads, then I found my data directory wasn't the default so it wasn't picking up the keydb file despite the default directory still containing a _private_data.tar file, then found a weird issue with my drive I had to power cycle to correct I've never seen before which timed exactly to the launch of makemkv where it first successfully picked up the keydb file. Both these issues just made it look like I'd done things properly but that the disc was still unsupported.
I just thought I'd have a go to be helpful to the community and get my issue on the radar. I put no in for that sync check at first and changed it once I'd sussed it out. I checked the contents of that keydb file and it didn't look like my disc was listed in it, it just had a different naming convention to earlier seasons & I had to search my specific disc name, which makes sense in retrospect as disc authoring is never predictable so that's totally on me. I've also for the first time in the years I've used it as a paying customer, been advised by makemkv to install java to get the rip to work properly. So there's more oddities & silly mistakes contributing to the confusion.
Regardless things seem fine for this disc now. Thanks keydb_helper for all of this as it did ultimately get my rip completed. It does work and is simple when you get your head round it. There's quite a few random pitfalls for newcomers though & shit like this directed to an account with 1 post does the community no good whatsoever:
"Fuck off hfmets. Don't waste my time by submitting titles which are already supported by the public keydb."
I appreciate it's frustrating dealing with new users when you feel your write-up is perfect, but that's just part of the process unfortunately, especially for off-path processes like this.
If an admin can delete this post please do so. I won't be back.
keydb_helper
Thanks to everyone for trying to follow the submission template.
I don't know why, but I'm seeing an awful of people including this line in their posts when they apparently haven't grabbed the latest keydb for several weeks (if ever):
mediumwave wrote:
Wed Dec 10, 2025 8:57 am
It would really be appreciated if you all could actually grab the latest keydb and try it out before posting to this thread.
These four titles have all been supported for several days or weeks:
HeebusJeebus wrote:
Wed Dec 10, 2025 1:27 pm
It doesn't take long to sync the keydb, it is absolutely free, and it can avoid unnecessary posts.
These titles corresponded to new keydb submissions:
MKB20_v77_Dead_of_Night_4DA0
MKB_v82_BD_ROM_DCD6
sammyd1108
Post by sammyd1108 »
I’m trying to submit a couple, but how do you get the disc dump links? I have the disc pulled up in MakeMKV but see nowhere to access that so I can post it on here.
Nobody_Special
Post by Nobody_Special »
Dump for Chernobyl 4K.
sammyd1108
A History of Violence - Criterion
Disc type: UHD
Disc dump filename: MKB20_v82_A_HISTORY_OF_VIOLENCE_8171.tgz
Drive: BD-RW BDR-212U
Drive firmware: 1.01/ID83
Did you sync the public keyed within the last 15 minutes? Yes
Disc dump link: https://drive.google.com/file/d/1wygWxv ... share_link
sammyd1108
Zombieland
Disc type: UHD
Disc dump filename: MKB21_v70_Zombieland_CC8B.tgz
Disc dump link: https://drive.google.com/file/d/1XVw7ZQ ... share_link
The_Red_Shoes
Post by The_Red_Shoes »
2 new dump files for:
New Tesseract and Marius Müller Westernhagen Blu-rays: https://we.tl/t-Wnt6JSm45g
MrPenguin
Post by MrPenguin »
sammyd1108 wrote:
Wed Dec 10, 2025 4:50 pm
Can you adjust this file's "Share" option please, so that people can access it?
MrPenguin
Post by MrPenguin »
Nobody_Special wrote:
Wed Dec 10, 2025 3:30 pm
I think the latest KEYDB.cfg file already has this disk.
sammyd1108
MrPenguin wrote:
Wed Dec 10, 2025 5:06 pm
Just fixed that, sorry. It was my first time doing this.
