Public KeyDB Disc Submissions
AFK88L
Post by AFK88L » Fri Dec 05, 2025 2:15 am
Relay (2025) Blu-ray
Disc type: BD-ROM
Disc dump filename: MKB_v82_R-129966-8_3C8A.tgz
Drive: BD-RE BH16NS55
Drive firmware: 1.05
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1X5gTlp ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1U1PknR ... sp=sharing
keydb_helper
Post by keydb_helper » Fri Dec 05, 2025 8:16 am
xiaoxiao wrote: Thu Dec 04, 2025 8:29 pm Disc dump filename: MKB20_v61_BLADE_RUNNER_2049_EBC7
MKB_RO.inf link :https://drive.google.com/file/d/1XtIeVw...
Disc dump link:https://drive.google.com/file/d/1XtIeVw...
Hey xiaoxiao, you seem to have posted the link to your MKB_RO.inf file twice so your disc cannot be added to the keydb. Please add the link to your disc dump file when you get the chance.
katja2500
Post by katja2500 » Fri Dec 05, 2025 2:49 pm
Fahrt zur Hölle, ihr Halunken 4K(German Disc):
MKB20_v82_Fahrt_zur_Hölle,_ihr_Halunken_7A31
Disc dump link: https://drive.google.com/open?id=1fcOOS ... p=drive_fs
MrPenguin
Post by MrPenguin » Fri Dec 05, 2025 3:10 pm
katja2500 wrote: Fri Dec 05, 2025 2:49 pm MKB20_v82_Fahrt_zur_Hölle,_ihr_Halunken_7A31
Can you also provide the (zipped) aACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside your TGZ dump has been truncated to only 56 bytes, making it unusable to anyone except MakeMKV itself.
jayper
Post by jayper » Fri Dec 05, 2025 4:35 pm
katja2500
Post by katja2500 » Fri Dec 05, 2025 4:53 pm
MKB20_v82_Fahrt_zur_Hölle,_ihr_Halunken_7A31,aACS/MKB_RO.inf file:
https://drive.google.com/open?id=1sngfz ... p=drive_fs
Daredevil786
Post by Daredevil786 » Fri Dec 05, 2025 5:16 pm
Gougeo
Post by Gougeo » Fri Dec 05, 2025 6:09 pm
I've updated my ASUS BW-16D1HT drive to 3.10MK, however when I tried to decrypt the UHD disk of Wicked I get an error. Here's the attached tgz file.
Thanks for your help.
Toad King
Post by Toad King » Fri Dec 05, 2025 10:51 pm
Disc type: UHD
Disc dump filename: MKB20_v82_Leaving_Las_Vegas-_Unrated_Cut_F8A2.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Not required
Disc dump link: https://drive.google.com/file/d/1T6Vcf4 ... 8gugV/view
MrPenguin
Post by MrPenguin » Fri Dec 05, 2025 11:05 pm
katja2500 wrote: Fri Dec 05, 2025 4:53 pm MKB20_v82_Fahrt_zur_Hölle,_ihr_Halunken_7A31,aACS/MKB_RO.inf file:
You have provided the same 56 byte long MKB_RO.inf file from inside the TGZ dump file. Thanks, but we already had that one. Can you provide the one from your physical UHD disk instead please?
keydb_helper
Post by keydb_helper » Fri Dec 05, 2025 11:34 pm
Toad King wrote: Fri Dec 05, 2025 10:51 pm Disc dump filename: MKB20_v82_Leaving_Las_Vegas-_Unrated_Cut_F8A2.tgz
Hey Toad King, thanks for following the submission template. Your disc has been added to the public keydb.
The following UHD discs have also been added to the public keydb:
MKB20_v82_BOOGIE_NIGHTS_A332
mkb20_v82_fahrt_zur_hoelle_ihr_halunken_7a31
If your UHD disc hasn't been added to the public keydb it probably means there was an issue with your submission. Please re-read the opening post of this thread and follow the submission template. I'm sick of partial disc dumps without the corresponding MKB_RO.inf files and non-public links to file hosts.
From now on, posts which do not follow the submission template will be further de-prioritized.
3amgirl
Post by 3amgirl » Sat Dec 06, 2025 12:26 am
Disc type: UHD
Disc dump filename: MKB20_v66_Twilight_07C5.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1hUJ3cE ... sp=sharing
Disc dump link: https://drive.google.com/file/d/17q_f2E ... sp=sharing
The_Red_Shoes
Post by The_Red_Shoes » Sat Dec 06, 2025 12:42 am
New dump files for
Ultravox - The Collection Deluxe
New Order - Movement, Brotherhood And Low-life BRs
https://we.tl/t-DubwHDKGZR
keydb_helper
Post by keydb_helper » Sat Dec 06, 2025 3:58 am
3amgirl wrote: Sat Dec 06, 2025 12:26 am Disc dump filename: MKB20_v66_Twilight_07C5.tgz
Hey 3amgirl, thanks for following the submission template and including the MKB_RO.inf file. Your disc has been added to the public keydb along with these related discs:
MKB20_v82_BreakingDawn_PT1_UHD_C0A4
MKB20_v82_BreakingDawn_PT2_uhd_A76E
MKB20_v82_ECLIPSE_1B76
MKB20_v82_NEW_MOON_9D46
Happy_Camper
Post by Happy_Camper » Sat Dec 06, 2025 9:52 am
OS device name: F:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: *Redacted*
Firmware version: 1.02
TYPE: BD
It's currently not in keyDB
DISCID: 5799000579679AAF90B87D80A64F311B2CE1EAED
[LINK REMOVED]
I forgot to add this if you need it.
Vol Size: 20670578688
Thank you for adding it.
