Public KeyDB Disc Submissions
Relay (2025) Blu-ray
Disc type: BD-ROM
Disc dump filename: MKB_v82_R-129966-8_3C8A.tgz
Drive: BD-RE BH16NS55
Drive firmware: 1.05
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1X5gTlp ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1U1PknR ... sp=sharing
Disc type: BD-ROM
keydb_helper
Hey xiaoxiao, you seem to have posted the link to your MKB_RO.inf file twice so your disc cannot be added to the keydb. Please add the link to your disc dump file when you get the chance.xiaoxiao wrote: Thu Dec 04, 2025 8:29 pm Disc dump filename: MKB20_v61_BLADE_RUNNER_2049_EBC7
MKB_RO.inf link :https://drive.google.com/file/d/1XtIeVw...
Disc dump link:https://drive.google.com/file/d/1XtIeVw...
Fahrt zur Hölle, ihr Halunken 4K(German Disc):
MKB20_v82_Fahrt_zur_Hölle,_ihr_Halunken_7A31
Disc dump link: https://drive.google.com/open?id=1fcOOS ... p=drive_fs
Can you also provide the (zipped) aACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside your TGZ dump has been truncated to only 56 bytes, making it unusable to anyone except MakeMKV itself.
MKB20_v82_Fahrt_zur_Hölle,_ihr_Halunken_7A31,aACS/MKB_RO.inf file:
https://drive.google.com/open?id=1sngfz ... p=drive_fs
Daredevil786
I've updated my ASUS BW-16D1HT drive to 3.10MK, however when I tried to decrypt the UHD disk of Wicked I get an error. Here's the attached tgz file.
Thanks for your help.
Disc type: UHD
Disc dump filename: MKB20_v82_Leaving_Las_Vegas-_Unrated_Cut_F8A2.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Not required
Disc dump link: https://drive.google.com/file/d/1T6Vcf4 ... 8gugV/view
You have provided the same 56 byte long MKB_RO.inf file from inside the TGZ dump file. Thanks, but we already had that one. Can you provide the one from your physical UHD disk instead please?katja2500 wrote: Fri Dec 05, 2025 4:53 pm MKB20_v82_Fahrt_zur_Hölle,_ihr_Halunken_7A31,aACS/MKB_RO.inf file:
keydb_helper
Hey Toad King, thanks for following the submission template. Your disc has been added to the public keydb.Toad King wrote: Fri Dec 05, 2025 10:51 pm Disc dump filename: MKB20_v82_Leaving_Las_Vegas-_Unrated_Cut_F8A2.tgz
The following UHD discs have also been added to the public keydb:
MKB20_v82_BOOGIE_NIGHTS_A332
mkb20_v82_fahrt_zur_hoelle_ihr_halunken_7a31
From now on, posts which do not follow the submission template will be further de-prioritized.
Disc type: UHD
Disc dump filename: MKB20_v66_Twilight_07C5.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1hUJ3cE ... sp=sharing
Disc dump link: https://drive.google.com/file/d/17q_f2E ... sp=sharing
Drive: BD-RE BU40N
The_Red_Shoes
New dump files for
Ultravox - The Collection Deluxe
New Order - Movement, Brotherhood And Low-life BRs
https://we.tl/t-DubwHDKGZR
keydb_helper
Hey 3amgirl, thanks for following the submission template and including the MKB_RO.inf file. Your disc has been added to the public keydb along with these related discs:
MKB20_v82_BreakingDawn_PT1_UHD_C0A4
MKB20_v82_BreakingDawn_PT2_uhd_A76E
MKB20_v82_ECLIPSE_1B76
MKB20_v82_NEW_MOON_9D46
Happy_Camper
OS device name: F:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: *Redacted*
Firmware version: 1.02
TYPE: BD
It's currently not in keyDB
DISCID: 5799000579679AAF90B87D80A64F311B2CE1EAED
[LINK REMOVED]
I forgot to add this if you need it.
Vol Size: 20670578688
Thank you for adding it.
OS device name: F:
Revision: 1.02
TYPE: BD
[LINK REMOVED]
