Nope. Good to go!Webraider72 wrote: Sun Nov 30, 2025 1:50 am Good evening,
Here are the credentials of my drive. This Is the first time it has shown status Enabled for LibreDrive since I owned it and it was one of the dreadful firmware 1.03 which wasn't supported initially. As this is a UHD "capable" drive, Do I still need to flash it to rip UHD? I have a Mac by the way, and don't have access to windows. Thank you in advance!
LibreDrive for Pioneer drives
Webraider72
Great, Thanks!
rdosrun
are there any pioneer drives that can still be purchased for under 300 a drive?
Doubt it as the worlds supply is dwindling extrememly fast!!rdosrun wrote: Wed Dec 03, 2025 3:19 am are there any pioneer drives that can still be purchased for under 300 a drive?
asmcom
I think Marty has forgot about meMartyMcNuts wrote: Wed Dec 03, 2025 4:24 amDoubt it as the worlds supply is dwindling extrememly fast!!rdosrun wrote: Wed Dec 03, 2025 3:19 am are there any pioneer drives that can still be purchased for under 300 a drive?
I have drives available and more Pioneer stock arriving shortly. The global supply is running very low, but we are fortunate to have secured additional units that were initially held back for warranty purposes.
You can find the current Pioneer Libre-Drive Friendly Blu-ray Writer Drive BDR-XD08TBSG LibreDrive Friendly model here for under £300.00.
https://shop.uhdfriendlydrives.co.uk/pr ... mware-1-01
Kind Regards
Asmcom
asmcom
Stock is running low on the above drive, but hopefully we will have a bulk order before Christmas.
Asmcom
Asmcom
messos
Hi there,
I'm trying to flash a pioneer BDR XD05, I can't find the files or method anywhere, could someone please help.
appreciate your help in advance!
Post your Makemkv info.messos wrote: Wed Dec 03, 2025 9:51 am Hi there,
tabish121
I managed to pick up a Pioneer drive but I'm guessing it needs cross flashed to support UHD, is that correct?
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.31
Serial number: OHD**
Firmware date: 2015-05-25
Bus encryption flags: 13
Highest AACS version: 82
Drive platform: RS8600
Firmware version: 1.31/ID60
Revision: 1.31
Yes. PM is coming. Just reload your browser in a minute.tabish121 wrote: Wed Dec 03, 2025 4:51 pm I managed to pick up a Pioneer drive but I'm guessing it needs cross flashed to support UHD, is that correct?
Revision: 1.31
messos
Sorry I uploaded details for the wrong drive. The pioneer drive details that I want to flash are below:
OS device name: /dev/rdisk4
Product: BD-RW BDR-XD05
Revision: 1.21
Serial number: NGDL**
Firmware date: 2014-04-02
Highest AACS version: 81
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 1.21
Revision: 1.21
PM sent.messos wrote: Thu Dec 04, 2025 12:27 am Sorry I uploaded details for the wrong drive. The pioneer drive details that I want to flash are below:
Revision: 1.21
geekdrew
Hi Coopervid et al,
I just registered and the forum won't let me directly PM you yet. :'(
I have this drive:
I assume that it's able to be flashed, from reading this thread?
I have this drive:
PIONEER
BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 68
Libredrive:
Drive platform: RS8511
Firmware Name: PIONEER BDR-UD03
Firmware version: 1.14
PM sent.geekdrew wrote: Sat Dec 06, 2025 1:09 am Hi Coopervid et al,
I have this drive:
I assume that it's able to be flashed, from reading this thread?Code: Select all
PIONEER BD-RW BDR-UD03 Revision: 1.14 Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 68 Libredrive: Status: Enabled Drive platform: RS8511 Firmware Name: PIONEER BDR-UD03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Thanks![]()
malcom_ren
i just bought a pioneer bluray drive, waited 2 months to arrive and i cant rip blu rays... i dont know what to do
