Ultimate UHD Drives Flashing Guide Updated 2025
tomatodory
Post by tomatodory »
asmcom wrote:
Sat Nov 29, 2025 4:30 pm
tomatodory wrote:
Sat Nov 29, 2025 3:01 pm
Billycar11 wrote:
Fri Nov 28, 2025 7:31 am
i have moved to exclusively to pioneer xd08
as the other drives are now gone
I know that the S12 and S13 series, along with some of the 212 and 213 models, used glass lenses, but I'm unable to find any definite info as to whether the XD08 uses a glass lens or a plastic lens. Do you know?
If it does use a glass lens as the others, that's great, but if it uses a plastic lens I was wondering if you notice anything different from how the UBK you used to have read discs to how the XD08 you have now reads discs?
Yes the Xd08 has a Glass Lens & the XD08EMB-S, XD08UMB-S
Asmcom :mrgreen:
That's great news. Once I'm done christmas shopping for everyone else I'll have to get me one of those XD08EMB-S you sell, since I'm in Europe as well.
asmcom
Post by asmcom »
You will need to be fast as they are selling fast. The good news is that we have nearly secured more Pioneer stock that was being retained by Pioneer, which they are going to release soon.
Asmcom :mrgreen:
Mr_Orange
Post by Mr_Orange »
asmcom wrote:
Sun Nov 30, 2025 12:44 pm
Which models?
nupfaka
Post by nupfaka »
Any help is appreciated!
Attempting to flash and getting error...
Input file not found -- /HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Internal error 0x83000001
What am I missing?
Running...
Mac OS 14.7.6
Makemkv 1.17.7
OS device name: /dev/rdisk2
Product: BD-RE BP60NB10
Revision: 1.02
Serial number:
Firmware date: 2121-07-08 15:56
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.02
asmcom
Post by asmcom »
Mr_Orange wrote:
Sun Nov 30, 2025 12:51 pm
Which models?
When we secure, information will come in due course Mr_Orange.
Clare
OfficerTux
Post by OfficerTux »
Coopervid wrote:
Thu Nov 27, 2025 3:52 pm
Better get this Verbatim. It contains a BU40N.
https://www.amazon.de/Verbatim-Blu-ray- ... 0cfb8&th=1
The drive arrived today and ripping normal Blurays works fine. It can open 4K discs but as expected I cannot copy them with the original FW.
Here is the drive Info:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO1P6NB5204
Highest AACS version: 76
From the first post I read that I should flash this firmware:
BU40N on any Firmware directly to > BU40N 1.03MK
But further down below it says
LG 1.04+ / BU40N 1.03 / Asus 3.10+ and similar
The newer OEM firmwares cannot be flashed easily due to the additional downgrade checks
And mine is on FW 1.05 so it probably is encrypted?
I downloaded "The all you need firmware pack" and found the BU40N firmware. My flash command will look like this:
 makemkvcon64.exe f --all-yes -d D: rawflash enc -i Path\To\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Did I get it right?
Thanks in advance :)
McMurphy66
Post by McMurphy66 »
Hi all, newbie post but not new to makemkv - backed-up my archive over many years before travelling the world with my HDDs So a big, big thanks to all creators and support, best software :D
Just bought the Buffalo BRUHD-PU3-BK for my UHDs. After seeing a few Buffalo firmware options in the AYNeed pack v reco to use LG 1.03, I’m confused what to use, not done this before.
Help is very much appreciated!
OS device name: E:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN14
Serial number:
Firmware date: 2121-06-21 13:33
Bus encryption flags: 1F
Highest AACS version: 48
You can tell yourself. Post Makemkv info.
OfficerTux
I did not flash yet because I did not want to brick my drive.
Can I just give it a go?
Yes you can.
OfficerTux
Well, that was easy:
OS device name: F:
Revision: 1.03
Firmware version: 1.03
I just tried opening the Dune UHD and it worked fine.
Thanks a lot for this amazing project!
azkey
Post by azkey »
Asmcom :mrgreen:
Oooh yeah... sounds good... will need another backup Pioneer drive :D
