Mr_Orange
Post by Mr_Orange »
asmcom wrote: Sun Nov 30, 2025 12:44 pm The good news is that we have nearly secured more Pioneer stock that was being retained by Pioneer, which they are going to release soon.
Which models?
nupfaka
Post by nupfaka »
Any help is appreciated!
Attempting to flash and getting error...
Input file not found -- /HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Internal error 0x83000001
What am I missing?
Running...
Mac OS 14.7.6
Makemkv 1.17.7
OS device name: /dev/rdisk2
Product: BD-RE BP60NB10
Revision: 1.02
Serial number:
Firmware date: 2121-07-08 15:56
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.02
asmcom
Post by asmcom »
Mr_Orange wrote: Sun Nov 30, 2025 12:51 pm
Which models?
When we secure, information will come in due course Mr_Orange.
Clare
OfficerTux
Post by OfficerTux »
Coopervid wrote: Thu Nov 27, 2025 3:52 pm Better get this Verbatim. It contains a BU40N.
https://www.amazon.de/Verbatim-Blu-ray- ... 0cfb8&th=1
The drive arrived today and ripping normal Blurays works fine. It can open 4K discs but as expected I cannot copy them with the original FW.
Here is the drive Info:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO1P6NB5204
Highest AACS version: 76
From the first post I read that I should flash this firmware:
BU40N on any Firmware directly to > BU40N 1.03MK
But further down below it says
LG 1.04+ / BU40N 1.03 / Asus 3.10+ and similar
The newer OEM firmwares cannot be flashed easily due to the additional downgrade checks
And mine is on FW 1.05 so it probably is encrypted?
I downloaded "The all you need firmware pack" and found the BU40N firmware. My flash command will look like this:
 makemkvcon64.exe f --all-yes -d D: rawflash enc -i Path\To\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Did I get it right?
Thanks in advance :)
McMurphy66
Post by McMurphy66 »
Hi all, newbie post but not new to makemkv - backed-up my archive over many years before travelling the world with my HDDs So a big, big thanks to all creators and support, best software :D
Just bought the Buffalo BRUHD-PU3-BK for my UHDs. After seeing a few Buffalo firmware options in the AYNeed pack v reco to use LG 1.03, I’m confused what to use, not done this before.
Help is very much appreciated!
OS device name: E:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN14
Serial number:
Firmware date: 2121-06-21 13:33
Bus encryption flags: 1F
Highest AACS version: 48
You can tell yourself. Post Makemkv info.
OfficerTux
I did not flash yet because I did not want to brick my drive.
Can I just give it a go?
Yes you can.
OfficerTux
Well, that was easy:
OS device name: F:
Revision: 1.03
Firmware version: 1.03
I just tried opening the Dune UHD and it worked fine.
Thanks a lot for this amazing project!
azkey
Post by azkey »
asmcom wrote: Sun Nov 30, 2025 12:44 pm You will need to be fast as they are selling fast. The good news is that we have nearly secured more Pioneer stock that was being retained by Pioneer, which they are going to release soon.
Asmcom :mrgreen:
Oooh yeah... sounds good... will need another backup Pioneer drive :D
ahaddadin
Post by ahaddadin »
Hello just got this drive but it won’t read uhd disks
Verbatim 43888 Pioneer UD03, UHD discs spin then ‘no disc inserted’, regular Blu-ray works fine”:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
ahaddadin wrote: Fri Dec 05, 2025 12:48 am Hello just got this drive but it won’t read uhd disks
Revision: 1.14
Serial number:
That's not a 43888. The 43888 has either a Pioneer UD04 or a LG BU40N. The other models, namely the 43889, 43890 have either the Pioneer UD03 or a LG BU40N.
Anyway, if you email that drive info to Billycar11, he will be able to help you flash it.
ahaddadin
Post by ahaddadin »
Alright is there a way to get it to read uhd disks? thank you
ahaddadin
Post by ahaddadin »
Thank You
ClueMeIN
Post by ClueMeIN »
I am a complete rookie with this. I followed rule one and tried to read extensively, but I am lost on getting my particular drive UHD friendly. I would really appreciate a kind soul helping me out. I feel confident I can do what's needed if I have the right files and some very basic instructions.
Here is my info:
OS device name: K:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: XXXXXXXXXXX
Firmware date: 2015-10-20
Drive platform: RS8600
Firmware version: E101/ID76
Thank you in advance for the help!
