Public KeyDB Disc Submissions
keydb_helper
Post by keydb_helper »
corky7 wrote: Fri Nov 28, 2025 12:21 am Disc dump filename: MKB20_v82_The_Long_Walk_21AC.tgz
Hey corky7, thanks for the submission but your particular version of The Long Walk was added to the public keydb a few days ago. Please grab the latest keydb to check the current status before posting to this thread.
corky7 wrote: Fri Nov 28, 2025 12:21 am Drive: BD-RW BDR-S13U
I'd also recommend picking up a non-Pioneer drive (LG/Asus/Buffalo) if you get a chance as the Pioneer drives are of limited use.
I believe all other discs have been added to the public keydb. These UHD discs corresponded to new media keys:
MKB20_v76_SCREAM_9DD9
mkb20_v82_endless_night_36a8
mkb20_v82_evil_under_the_sun_576e
Public KeyDB Disc Submissions KeyDB Download
leon_eom
Post by leon_eom »
Hi this is dumpfile and info. Thanks! :D
Disc type: Blu-ray
Disc dump filename: MKB_v82_AIMYON_TOUR_2024-2025_ドルフィン・アパート_DISC1_B2E2
Drive: BD-RE BP60NB10
Drive firmware: 2121-07-08 15:56
LibreDrive status: Possible (with patched firmware)
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://1drv.ms/u/c/6ae4c5c6d0e48eed/Ea ... A?e=fTCTYq
Disc dump link: https://1drv.ms/u/c/6ae4c5c6d0e48eed/Ed ... g?e=6awwy8
keydb_helper
Traume wrote: Fri Nov 28, 2025 3:26 am Hello,
MakeMKV was unable to process this UHD Blu-ray.
It looks like the volume key / hash is not yet in the database.
Disc title: NEW AVENGERS S1 D2 UHD
Region: UHD (region-free)
MakeMKV version: 1.18.2
Drive: HL-DT-ST BD-RE BU40N USB Device
Symptoms:
- Cannot decrypt disc
- Missing key/hash
- Using latest MakeMKV version
The SDF dump (.tgz) generated by MakeMKV is attached.
Thank you for adding support!
Hey Traume, thanks for providing that disc dump file. Your disc has been added to the public keydb. Please follow the instructions linked in the first post of this thread to configure MakeMKV to utilise the public keydb.
darthvader wrote: Thu Nov 27, 2025 10:41 pm Sure. More than happy to contribute in anyway I can. Just started a decrypted backup and I can see the file, it's 4KB. I have copied it here, hope that's the correct one.
Here it is: ...
Let me know if you need anything else.
Thanks for providing that discatt.dat file. Your variant of Saving Private Ryan has been added to the public keydb. Grab the latest keydb, unzip it, rename it to 'KEYDB.cfg" and put it in your MakeMKV data directory. Hopefully that'll resolve that issue.
Traume
Post by Traume »
Many thanks, will do that !
Here is a new dump
Disc type: UHD
Disc dump filename:MKB20_v82_The_New_Avengers_-_S1_D3_13CE
Drive:HL-DT-ST BD-RE BU40N USB Device
Drive firmware:1.00
LibreDrive status:Enabled
Have you verified that all submission links are accessible in incognito/private browsing?Yes
MKB_RO.inf link: https://drive.google.com/file/d/1KdBTPc ... drive_link
Disc dump link: https://drive.google.com/file/d/1GdZjbR ... drive_link
cjw73
Post by cjw73 »
EL
Disc type: UHD
Disc dump filename: MKB20_v82_EL_UHD_BLU_RAY_C24E.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
LibreDrive status: Enabled
Disc dump link: https://drive.proton.me/urls/QMDDJ3NEXW#xAeM8sOI66GE
thanks again
MrPenguin
Post by MrPenguin »
Traume wrote: Fri Nov 28, 2025 1:02 pm Have you verified that all submission links are accessible in incognito/private browsing? Yes
Can you adjust the "Share" option for these files please, so that people can access them?
Traume
Post by Traume »
I've just updated it. Sorry about the incorrect settings earlier.
A quick repost :
Disc type: UHD
Drive firmware:1.00
Many thanks in advance
Traume
Post by Traume »
Sorry again, struggling with my computer :-)
Here are the right links
Disc type: UHD
Drive firmware:1.00
Opera
Post by Opera »
NEW Downloadoption for these dupms: https://workupload.com/archive/88yLqUqzfB
Here are 3 UHD disc dumps from the German bundle of the new Agatha Christie Collection that are still missing from the database - You can download all 3 files via the link, which is the same for all 3 discs.:
Disc type: UHD
Disc ID: 0xD111C00D74302945502D419123777F0637FFDAEE
Disc dump filename: MKB20_v82_MURDER_ON_THE_ORIENT_EXPRESS_08FA.tgz
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link:
Disc dump link: https://workupload.com/archive/88yLqUqzfB
Disc type: UHD
Disc ID: 0xDAB3550F235A867DEEF1FE16A1C7A0B0F0BD549B
Disc dump filename: MKB20_v82_DEATH_ON_THE_NILE_5494.tgz
MKB_RO.inf link:
Disc type: UHD
Disc ID: 0xD8E2F14AA262825B13749FE60793C546D813AB6D
Disc dump filename: MKB20_v82_THE_MIRROR_CRACKD_1F7C.tgz
MKB_RO.inf link:
Thank you very much!
MrPenguin
Post by MrPenguin »
Opera wrote: Fri Nov 28, 2025 6:13 pm Here are 3 UHD disc dumps from the German bundle of the new Agatha Christie Collection that are still missing from the database - You can download all 3 files via the link, which is the same for all 3 discs.:
Can you adjust the "Share" option on those three files please, so that people can access them?
Opera
Post by Opera »
MrPenguin wrote: Fri Nov 28, 2025 11:15 pm
Sorry - Should work now...
keydb_helper
Traume wrote: Fri Nov 28, 2025 5:28 pm Disc dump filename:MKB20_v82_The_New_Avengers_-_S1_D3_13CE
cjw73 wrote: Fri Nov 28, 2025 3:31 pm Disc dump filename: MKB20_v82_EL_UHD_BLU_RAY_C24E.tgz
Thank you both for providing these two new disc dumps. Both have been added to the public keydb.
Opera wrote: Fri Nov 28, 2025 11:31 pm Sorry - Should work now...
Did you try opening your link in Incognito/Private browsing mode? Can you download the disc dumps without needing to login? It doesn't seem to be working for me either.
Traume
Post by Traume »
Many thanks !
Here are 7 new dumps :
Disc type: UHD
Disc dump filename: MKB20_v82_The_New_Avengers_-_S1_D4_795E.tgz
Drive firmware:1.00
MKB_RO.inf link: https://drive.google.com/file/d/1sL4poq ... sp=sharing
Disc dump link:https://drive.google.com/file/d/1FwNrhG ... sp=sharing
Disc type: UHD
[b]Disc dump filename: MKB20_v82_The_New_Avengers_-_S1_D5_0816.tgz
[b]Drive: HL-DT-ST BD-RE BU40N USB Device
[b]Drive firmware: 1.00
[b]LibreDrive status: Enabled
[b]Did you sync the public keydb within the last 15 minutes? Yes
[b]Have you verified that all submission links are accessible in incognito/private browsing? Yes
[b]MKB_RO.inf link: https://drive.google.com/file/d/1lGz0qY ... sp=sharing
[b]Disc dump link: https://drive.google.com/file/d/1LjYXBV ... sp=sharing
[b]Disc type: UHD
[b]Disc dump filename: MKB20_v82_The_New_Avengers_-_S2_D1_D06E.tgz
[b]MKB_RO.inf link: https://drive.google.com/file/d/1pwsj-u ... sp=sharing
[b]Disc dump link: https://drive.google.com/file/d/1DOSd0I ... sp=sharing
[b]Disc type: UHD
[b]Disc dump filename: MKB20_v82_The_New_Avengers_-_S2_D2_DC06.tgz
[b]MKB_RO.inf link: https://drive.google.com/file/d/1W-Eh-W ... sp=sharing
[b]Disc dump link: https://drive.google.com/file/d/1jCoRP7 ... sp=sharing
[b]Disc type: UHD
[b]Disc dump filename: MKB20_v82_The_New_Avengers_-_S2_D3_A0AE.tgz
[b]MKB_RO.inf link: https://drive.google.com/file/d/11mOtGX ... sp=sharing
[b]Disc dump link: https://drive.google.com/file/d/1KqtJtQ ... sp=sharing
[b]Disc type: UHD
[b]Disc dump filename: MKB20_v82_The_New_Avengers_-_S2_D4_1F92.tgz
[b]MKB_RO.inf link: https://drive.google.com/file/d/1f5_Yzc ... sp=sharing
[b]Disc dump link: https://drive.google.com/file/d/1-yofEH ... sp=sharing
[b]Disc type: UHD
[b]Disc dump filename: MKB20_v82_The_New_Avengers_-_S2_D5_24E4.tgz
[b]MKB_RO.inf link: https://drive.google.com/file/d/1Of0VDe ... sp=sharing
[b]Disc dump link: https://drive.google.com/file/d/1AwN1iC ... sp=sharing
reverandbob
Post by reverandbob »
Good Fortune
Disc type: Blu-ray (AACS 1.0)
Disc dump filename: MKB_v82_Good_Fortune_B086.tgz
Drive: BD-RE WP50NB40
Drive firmware: 1.03
LibreDrive status: N/A
Disc dump link: https://drive.google.com/file/d/1OA_SFJ ... drive_link
igloogamer
Post by igloogamer »
It’s strange that this movie was released in 2016 but MakeMKV still reports:
“The volume key is unknown for this disc – video can't be decrypted.
Failed to open disc.”
Below is the disc dump for the public KeyDB. Thanks!
Disc type: UHD
Disc dump filename: MKB20_v61_Jason_Bourne_6C0F
Drive: WH16NS60
Drive firmware: 1.02MK
MKB_RO.inf link: https://drive.google.com/file/d/1jiWNg6 ... drive_link
Disc dump link: https://drive.google.com/file/d/1qiaaOY ... drive_link
