Public KeyDB Disc Submissions
windkey
Post by windkey »
lisa live is smile always cocktail_party_disc1
Disc type: UHD
Disc dump filename: MKB_v82_BD_ROM_B058
Drive: BD-RW BDR-XD04
Drive firmware: 1.20
LibreDrive status: Possible, but very unlikely to happen
MKB_RO.inf link: https://drive.google.com/file/d/1mmNBBz ... drive_link
Disc dump link: https://drive.google.com/file/d/1TaVg2B ... drive_link
lisa live is smile always cocktail_party_disc2
Disc type: UHD
Disc dump filename: MKB_v82_BD_ROM_EC48
MKB_RO.inf link: https://drive.google.com/file/d/1bS3-U5 ... drive_link
Disc dump link: https://drive.google.com/file/d/1MCyX9C ... drive_link
lisa live is smile always icecream
Disc type: UHD
Disc dump filename: MKB_v82_BD_ROM_49FA
MKB_RO.inf link: https://drive.google.com/file/d/1EMLvZ2 ... drive_link
Disc dump link: https://drive.google.com/file/d/1YNJFwe ... drive_link
Tcr22
Post by Tcr22 »
Two and a Half Men: The Complete Series Blu-ray
https://drive.google.com/file/d/1zXGdgI ... drive_link
keydb_helper
Post by keydb_helper »
tomalv wrote:
Fri Nov 21, 2025 10:49 pm
My first post here, I hope I do it right.
film / movie: Earthquake - 4K Ultra HD
Hey tomalv, your post was well formatted but unfortunately disc dump files generated with your Pioneer drive are not suitable for the public keydb. The MakeMKV team have effectively blocked third party utilisation of these files by obfuscating the disc metadata.
If the MakeMKV team ever remove this intentional limitation, then your drive could be used to generate suitable disc dump files. But for the time being your only option is to either wait for native MakeMKV title support or purchase a UHD compatible LG/Asus/Buffalo MT1959 disc drive and generate a new dump file.
wrgg2
Post by wrgg2 »
Amazarashi 電脳演奏監視空間 ゴースト
Disc type: FHD
Disc dump file name: MKB_v82_BD_ROM_7CCC
Drive: BD-RE BP60NB10
Drive Firmware: 1.02
LibreDrive Status: Enabled
Did you sync the public keydb key in the last 15 minutes: no
Have you verified that all submission links are accessible in incognito/private browsing?: yes
https://drive.google.com/file/d/1l0eYNC ... sp=sharing
jenrashe
Post by jenrashe »
Screamboat (UHD)
Disc type: UHD
Disc dump filename:MKB20_v82_SCREAMBOAT_01_2408
Drive: LG BU40N
Drive firmware: 1.03 - Patched (microcode access re-enabled)
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1U6IU2- ... drive_link
Disc dump link: https://drive.google.com/file/d/1HSfXLT ... drive_link
Dabruce
Post by Dabruce »
Hellboy The Crooked Man
https://drive.google.com/file/d/1If2o1N ... sp=sharing
Disc type: UHD
Disc dump filename: MKB20_v82_Hellboy_The_Crooked_Man_73B8
Drive: BW-16D1HT
Drive firmware: 3.10MK
Thank you
reverandbob
Post by reverandbob »
Perhaps I am missing something here... but I have been using MakeMKV for years and have a rather large collection. It has been rare that I get a disc that has an unknown key. Its only ever happened to me maybe once or twice. Now, all of a sudden, I have a stack of movies sitting on my desk that are all saying that the key is unknown. Maybe I am exceptionally unlucky this month... OR... something else is wrong. If I understand the process correctly, EVERY title MUST have an entry in the KEYDB? I would assume that keydb gets updated by several other sources, besides that of the MakeMKV users ( DVDFab, etc ). If I didn't know better I would think that some other source stopped updating KeyDB. Just saying that this has never been a problem... I've never had issues with ripping a disc... but in the last week, maybe two, I seem to be seeing a number of them. Anyone have any thoughts?
Scavenger
Post by Scavenger »
The Umbrellas of Cherbourg (UK release)
Disc type: UHD
Disc dump filename: MKB20_v77_THE_UMBRELLAS_OF_CHERBOURG_7DF3
Drive: BP60NB10
Drive firmware: 1.02
EDIT: Processed, links removed. Thanks.
keydb_helper
Thanks to everyone who provided suitable disc dumps. The following UHD titles have been added to the public keydb:
MrPenguin
Post by MrPenguin »
reverandbob wrote:
Sat Nov 22, 2025 2:07 pm
Not quite ;). You don't need to use KEYDB at all. However, it can be faster to add your disk to the public KEYDB than to wait for your key to appear in MakeMKV's own private "hashed keys" database.
MakeMKV cannot natively decrypt AACS v82 discs so if you have some new titles (basically from this year) then dumps will be created and should be emailed to svq@makemkv.com so the VUK can be derived and added to the internal hashed keys database.
rjpinca
Post by rjpinca »
The Wolf of Wall Street 4K UHD
The volume key is unknown for this disc
https://drive.google.com/file/d/1A09Xus ... sp=sharing
tsubodait
Post by tsubodait »
Thank you for all the contributions!
* I find 'The Grey Fox' is in the keydb, but Makemkv does not decrypt it.
Maybe the one released in other areas seems to be listed in the keydb.
--- The Grey Fox
Disc type: BD-ROM
Disc dump filename: MKB_v82_THE_GREY_FOX_6D16.tgz
Drive: BW-16D1HT
Disc dump link: https://drive.google.com/file/d/1RPai8G ... sp=sharing
--- Dans la Ville Blanche
Disc type: BD-ROM
Disc dump filename: MKB_v82_DANS_LA_VILLE_BLANCHE_0974.tgz
Drive: BW-16D1HT
Disc dump link: https://drive.google.com/file/d/1Xx8DtC ... sp=sharing
--- Les Annees Lumiere
Disc type: BD-ROM
Disc dump filename: MKB_v82_LES_ANNEES_LUMIERE_63FC.tgz
Drive: BW-16D1HT
Disc dump link: https://drive.google.com/file/d/1awst4m ... sp=sharing
Berumeth
Post by Berumeth »
spiegelscythe
Post by spiegelscythe »
Rei Yasuda - Hikari no Sumika / BROKEN GLASS
Disc type: FHD
Disc dump filename: MKB_v82_BD_ROM_86F8
Drive: BD-RE WH16NS40
Drive firmware: 1.04
LibreDrive status: Possible, not yet enabled
Disc dump link: https://drive.google.com/file/d/1yHyXGc ... sp=sharing
