Public KeyDB Disc Submissions
MrPenguin
Post by MrPenguin » Wed Nov 19, 2025 6:51 pm
gchancel102 wrote:
Wed Nov 19, 2025 5:05 pm
Here is a dump for the opera Atys from Lully by Versailles Concert.
Can you adjust the "Share" option of that file please, so that people can access it?
MrPenguin
Post by MrPenguin » Wed Nov 19, 2025 6:52 pm
Is there something i'm doing wrong?
Check MakeMKV's "Info" window. Does it say that LibreDrive is enabled for your drive? Because if not, you'll need to flash your drive's firmware.
defaultjovi
Post by defaultjovi » Wed Nov 19, 2025 6:58 pm
Disc type: UHD
Disc dump filename/s: MKB20_v70_RAMBO_DE75
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
This time i tried searching the disc ID through KeyDB Helper and this is the message i got:
[(KeyDB Entry Info)]
[DiscID]: 0xBD62793D0938E2882A448F0BF54BC7A58362FA40
[Volume]: RAMBO
[Title]: RAMBO
[Date]: 2019-06-24
[UnitKey]: 1-0x3B7535CB2D97B69B00A8553AA52BDCD9
[MKB]: 70
[Size]: 65010925568
[KEYDB_STATUS]: (VALIDATED)
[MakeMKV SUPPORTED]: FALSE
What does mean that the keydb status is validated but MakeMKV is not supported? Is my submission valid or am i doing something wrong?
gchancel102
Post by gchancel102 » Wed Nov 19, 2025 10:02 pm
Thanks for your feedback sorry for my mistake, that's done!
keydb_helper
Post by keydb_helper » Wed Nov 19, 2025 10:50 pm
Validated in this context means that the unit key for your disc in the keydb has been used to decrypt a small portion of your disc and the resulting decrypted content is correctly structured.
MakeMKV requires the volume unique key (VUK) to be present before it will decrypt your disc. The VUK is used to derive the unit key. This requirement is a somewhat artificial limitation on the part of MakeMKV but it explains why the key was validated even though MakeMKV didn't support your disc.
Your submitted disc dump was valid and the public keydb has now been extended to allow MakeMKV to backup your particular disc variant. Sync your local keydb and try it out.
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Toad King
Post by Toad King » Wed Nov 19, 2025 11:02 pm
Disc type: UHD
Disc dump filename: MKB20_v82_The_Killer_05E0
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: Not needed
Disc dump link: https://drive.google.com/file/d/1sCeUEM ... L5p3Y/view
keydb_helper
Post by keydb_helper » Thu Nov 20, 2025 2:23 am
Thanks Toad King, your variant of The Killer has been added to the public keydb. These UHD discs were also added:
MKB20_v82_Osiris_8328
MKB20_v82_The_Toxic_Avenger_45EC
The_Red_Shoes
Post by The_Red_Shoes » Thu Nov 20, 2025 1:39 pm
New dump file for: Split Enz Enzyclopedia Blu-ray: https://we.tl/t-b2blQDODZ8
reverandbob
Post by reverandbob » Thu Nov 20, 2025 8:26 pm
I have a bunch that need added. I will start with one and see how that goes before adding the others.
please add this:
https://drive.google.com/file/d/1d5wHkt ... drive_link
skyalrr0103
Post by skyalrr0103 » Fri Nov 21, 2025 12:19 am
Here are two new dumps.
MKB_v82_BD_VIDEO_5416
MKB_v82_BD_VIDEO_5416.tgz
AACS/Unit_Key_RO.inf last date modified 11/21/25
MKB_v82_BD_VIDEO_0BDE
MKB_v82_BD_VIDEO_0BDE.tgz
Daredevil786
Post by Daredevil786 » Fri Nov 21, 2025 3:23 pm
katja2500
Post by katja2500 » Fri Nov 21, 2025 4:39 pm
tomalv
Post by tomalv » Fri Nov 21, 2025 10:49 pm
My first post here, I hope I do it right.
film / movie: Earthquake - 4K Ultra HD
Disc type: UHD
Disc dump filename: MKB20_v82_Earthquake_DA0C.tgz
Drive: BD-RW BDR-UD04
Drive firmware: 1.14
Disc dump link: https://drive.google.com/file/d/1TJttqd ... drive_link
keydb_helper
Post by keydb_helper » Sat Nov 22, 2025 2:22 am
The following UHD discs have been added to the public keydb:
MKB20_v77_CAUGHT_STEALING_4332
mkb20_v82_def_leppard_6e92
MKB20_v82_Legend_EA1E
mkb20_v82_murderinthefirst_6592
It would be appreciated if submissions could follow the template provided in the opening post of this thread.
reverandbob
Post by reverandbob » Sat Nov 22, 2025 3:05 am
Lindsey Stirling - Home for the Holidays
Disc type: Blu-ray
Disc dump filename: MKB_v82_HOMEFORTHEHOLIDAYS_468E.tgz
Drive: BD-RE WP50NB40
Disc dump link: https://drive.google.com/file/d/1d5wHkt ... drive_link
