Public KeyDB Disc Submissions
MrPenguin
Post by MrPenguin » Tue Nov 18, 2025 11:58 pm
Storm85 wrote:
Tue Nov 18, 2025 11:41 pm
Disc type: UHD
Disc dump filename/s: MKB20_v77_Beverly_Hills_Cop_AE57
Drive: BD-RE BU40N
Drive firmware: 1.02
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? no
Have you verified that all submission links are accessible in incognito/private browsing? yes
MakeMKV needs to create this TGZ dump file from the actual UHD disk, and not from its files copied to your hard drive. Fortunately for you, KEYDB already contains your key. However, I also suspect you copied the files to your hard drive without also disabling bus encryption, which makes them unreadable anyway.
jeans_paradise
Post by jeans_paradise » Wed Nov 19, 2025 6:22 am
Disc type: UHD
Disc dump filename: MKB20_v77_Abbott_and_Costello_Meet_the_Invisible_Man_F4D6
Drive: BD-RE BU40N
Drive firmware: 1.03
Disc dump link: https://drive.google.com/file/d/15nfNqG ... sp=sharing
Thank you!
sugoioven
Post by sugoioven » Wed Nov 19, 2025 6:31 am
Disc type: BD-ROM
Disc dump filenames:
dump_FW_DA56D240C71E490FF123.tgz (sorry, im not sure if this is a right dump file, but it's a tgz file)
MKB_v82_『バサラオ』_F2BE.tgz
MKB_v82_『バサラオ』Blu-ray_特典ディスク1_22EE.tgz
MKB_v82_BASARAO_F2BE.tgz
MKB_v82_BASARAO_SPECIAL1_22EE.tgz
I've got 2 drives:
1
maker: SONY(cheap one)
Drive: BD DVD TS-LB23L
LibreDrive status: (sorry there's no libredrive info shown)
2
maker: PIONEER( I read that this may not work, please check if its model really impossible? desperate here.)
Drive: Pioneer RS1041
Drive firmware: ID73
LibreDrive status: Possible, but very unlikely to happen
Did you sync the public keydb within the last 15 minutes? No
Disc dump link: https://www.mediafire.com/folder/mqtgms ... /Disc+dump
bdsucker
Post by bdsucker » Wed Nov 19, 2025 9:04 am
Disc type: UHD
Disc dump filename: MKB20_v82_La_Notte_4K_77C8
Drive: BW-16D1HT
Drive firmware: 3.00
Disc dump link: https://www.mediafire.com/file/3ofgr7o4 ... 8.tgz/file
keydb_helper
Post by keydb_helper » Wed Nov 19, 2025 1:42 pm
Thanks to everyone who submitted suitable disc dump files. All posted discs have been added to the public keydb. The following UHD titles corresponded to new media keys:
MKB20_v77_Abbott_and_Costello_Meet_Dr_Jekyll_and_Mr_Hyde_23CE
MKB20_v82_Death_On_The_Nile_2042
MKB20_v82_Evil_Under_The_Sun_625A
MKB20_v82_Murder_On_The_Orient_Express_CF8E
MKB20_v82_The_Mirror_Crack'd_E25E
youley
Post by youley » Wed Nov 19, 2025 2:34 pm
City on Fire (1987) Arrow Rel.
Disc type: UHD
Disc dump filename: MKB20_v82_CITY_ON_FIRE_0F35
Drive: BW-16D1HT
Drive firmware: 3.10MK
MKB_RO.inf link: https://drive.google.com/file/d/1YLUVvm ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1orwEYX ... sp=sharing
MrPenguin
Post by MrPenguin » Wed Nov 19, 2025 3:38 pm
Disc type: UHD
KEYDB already contains this disk - I think it was added last week.
sacha
Post by sacha » Wed Nov 19, 2025 3:44 pm
The Toxic Avenger 2025 UK
Disc type: UHD
Disc dump filename: MKB20_v82_The_Toxic_Avenger_45EC.tgz
Drive: BD-RE BU40N
Drive firmware: 1.04
Disc dump link: https://limewire.com/d/MCjpb#XynJoLooGG
PES78
Post by PES78 » Wed Nov 19, 2025 3:58 pm
Thank you so much!
Grahamdoh
Post by Grahamdoh » Wed Nov 19, 2025 4:32 pm
Boston Kickout Blu-ray
Fantomas trilogy from Eureka
https://drive.google.com/drive/folders/ ... Q4FV9K_C0p
youley
Post by youley » Wed Nov 19, 2025 4:36 pm
Disc type: UHD
I've just tried to open this disc and still no joy, is it possible it's the shout edition that was added.
gchancel102
Post by gchancel102 » Wed Nov 19, 2025 5:05 pm
Here is a dump for the opera Atys from Lully by Versailles Concert.
https://drive.google.com/file/d/1xpafLF ... sp=sharing
Thanks a lot!
MrPenguin
Post by MrPenguin » Wed Nov 19, 2025 5:29 pm
KEYDB identifies each disk by the SHA-1 hash of its AACS/Unit_Key_Ro.inf file, which allows me to say with certainty that this entry is for your disk:
0x62AC07902956D4888A7CE934917E967B47526B30 = CITY ON FIRE (City On Fire) | ...
You need to copy the latest KEYDB.cfg file into the same directory where MakeMKV writes its TGZ dump files.
youley
Post by youley » Wed Nov 19, 2025 5:56 pm
Thank you for double checking, I went back through this thread and found the original post, turns out the disc is unencrypted but the aacs folder being present is confusing makemkv i deleted it and now it reads
defaultjovi
Post by defaultjovi » Wed Nov 19, 2025 6:51 pm
MrPenguin wrote:
Tue Nov 18, 2025 10:20 pm
defaultjovi wrote:
Tue Nov 18, 2025 10:05 pm
Disc dump filename: MKB20_v77_MARVEL_STUDIOS'_LOKI_SEASON_2_DISC_2_D371
I recently got my hands on Loki's season 2 UHD discs and for some reason i can't rip disc 2 meanwhile disc 1 rips perfectly fine. I tried getting the disc info and validating it through KeyDB Helper but no luck, so here's the dump!
KEYDB already has this disk's key. You cannot rip it because your drive hasn't enabled LibreDrive - for some unknown reason!?
DEBUG: Code 0 at -J6231Kpvy%-_GfBo:213130306
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at JP0V,W`B0e43*0h<e5:121264395
DEBUG: Code 4 at JP0V,W`B0e43*0h<e5:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Try power-cycling your drive.
Hello! Thank you aso much for the pointers I'm kinda new to ripping UHDs, I couldn''t get it to work no matter what i tried i installe JRE, changed cables, usb ports, nothing worked. But when i plugged the drive to my macbook after a couple of hiccups it ripped it without any issues, same thing happened with another disc i couldn't rip, it kept saying the source file was corrupt and couldn't be read at offset xxxxxxxx until i plugged the drive into my macbook. Is there something i'm doing wrong?
