(Asmcom:) Pioneer UHD 4K Drives, MakeMKV Discounted Software £39.99, Worldwide Service, Excellent Service!!!
Website is now live
Website is now Live.
Regards
Asmcom
Regards
Asmcom
Re: (Asmcom:) Pioneer UHD 4K Drives, Cheap Shipping, Worldwide Service, Excellent Service!!!
That's great to hear!
Is there a significant difference between these Pioneer drives besides the opening mechanism?
Pioneer BDR-XD08EMB-S
Pioneer BDR-XS07TS
Pioneer BDR-XS07TUHD
Pioneer BDR-XS07TS
Hello
I have emailed but in case this is a better method of communication I thought I should post here.
I’m trying to add the Pioneer Premium BDR-XD08EMB-S to the cart to purchase it, but there’s no “add” button. It says in stock but also out of stock
As far as I understood it, you can only purchase the full package with the protective case and the power supply - at least that's the only option that is selectable.Shamoo wrote: Mon Nov 17, 2025 1:55 pm I’m trying to add the Pioneer Premium BDR-XD08EMB-S to the cart to purchase it, but there’s no “add” button. It says in stock but also out of stock
All parcels are pre-wrapped and tested.f.zst wrote: Mon Nov 17, 2025 2:55 pmAs far as I understood it, you can only purchase the full package with the protective case and the power supply - at least that's the only option that is selectable.Shamoo wrote: Mon Nov 17, 2025 1:55 pm I’m trying to add the Pioneer Premium BDR-XD08EMB-S to the cart to purchase it, but there’s no “add” button. It says in stock but also out of stock
Clare
Lyricalgenius81
Hi Clare,
I’m also trying to order on the website but am seeing conflicting messages about stock . Could you forward me an email address so I can place an order and pay please.
Batman&throbbin
Weird.asmcom wrote: Mon Nov 17, 2025 8:44 amSome computer systems can have issues when using host-powered drives. If the system’s power dips, a Blu-ray drive may produce read errors.”Batman&throbbin wrote: Sun Nov 16, 2025 10:47 am@Asmcomasmcom wrote: Thu Nov 13, 2025 1:14 pm Subject: Recommended Pioneer UHD Drive Options
Hello Spacecowboy2050,
We can supply a Verbatim enclosure fitted with a Pioneer BDR-UD04 drive, which offers significantly better performance than the BU40N.
Price: £160.98 (including carry case)
Alternatively, we highly recommend the Pioneer BDR-XD07TS, supplied with both a carry case and power supply. In our opinion, this model is a better solution and a superior option, as it will easily outperform a host-powered drive.
Price: £159.98 plus postage to your country.
Website will be operational within the next week.
Kind regards,
Asmcom
UHD Friendly Drives Team
uhdfriendlydrives@gmail.com
When you say
‘It will easily outperform a host-powered drive’
Can you elaborate please?
I never had that with BU40N USB Adaptor or Vantec solely running from USB3.
Happens more with laptops that may contain USB power saving measures.Batman&throbbin wrote: Tue Nov 18, 2025 9:05 amWeird.asmcom wrote: Mon Nov 17, 2025 8:44 amSome computer systems can have issues when using host-powered drives. If the system’s power dips, a Blu-ray drive may produce read errors.”Batman&throbbin wrote: Sun Nov 16, 2025 10:47 am
@Asmcom
When you say
Batman&throbbin
Ah Cheers Marty.MartyMcNuts wrote: Tue Nov 18, 2025 9:57 amHappens more with laptops that may contain USB power saving measures.Batman&throbbin wrote: Tue Nov 18, 2025 9:05 amWeird.asmcom wrote: Mon Nov 17, 2025 8:44 am
I run a Mac so I guess that’s why I never experienced it.
A Pioneer 209EBK seller suggesting alternative USB connection on eBay recommends -
I recommend that you disable Windows USB suspend in Power Options and more importantly in the device manager tree relative to the port assigned or if you are not sure, to be safe all of them that have the Power management tab…
For an illustration see photo no.9 > Under the tab ‘Power management’ - DESELECT ‘Allow the computer to turn off the device to save power’
Thats a desktop drive on a USB adaptor works flawlessly according to the listing…
This should work with no problems on the latest Apple Tahoe OS 26.1Batman&throbbin wrote: Tue Nov 18, 2025 10:32 amAh Cheers Marty.MartyMcNuts wrote: Tue Nov 18, 2025 9:57 amHappens more with laptops that may contain USB power saving measures.Batman&throbbin wrote: Tue Nov 18, 2025 9:05 am
Weird.
Asmcom
Just letting you know I am back to the land of the livingnewsoftheworld wrote: Fri Sep 05, 2025 5:14 pm Hi Asmcom,
I hope you are recovering well. When you are back up and running can you contact me please? I'm in no rush.
I have been advised by others on the forum to get a Pioneer drive (Pioneer BDR-212V or Pioneer BDR-212BDK) as I'm looking for a UHD compatible full size drive and a caddy for it to go in (so far I have been looking at Vantec NexStar DX2)
Reading through this forum it seems like it's easy to make a mistake when buying an optical drive as some drives can be upgraded to UHD and some can't. with this in mind If you can assist that would be great.
I live in the UK. Best Wishes.
Highlandword9
Digital moe
Re: (Asmcom:) Pioneer UHD 4K Drives, MakeMKV Discounted Software £39.99, Worldwide Service, Excellent Service!!!
So what's the best drive to go for? Pioneer?
Edit: is there much difference between the pioneer drivers?
4K_SUCCESS
my first exposure to makemkv made 4K work on my Pioneer for the first time, using:
Windows 11 Pro 25H2
MakeMKV 1.18.2
4K ULTRA HD - DARKEST HOUR
Purchased the Pioneer BDR-XS07TUHD in 2023, did not buy their recommended media suite.
My Panasonic 4K player has become unwatchable quality in the 2nd half of my 4K movies, players are frustratingly clunky anyway, so rather than repair or buy new player I took another shot at trying to digitize.
Complete success, the .mkv output file seemless and perfect to my needs
Windows 11 Pro 25H2
MakeMKV 1.18.2
Just wanted to say a very BIG thank you to Asmcom
ordered my BU40NV1-03MKCC on 22nd November, and despite a despatch forecast of 27th November, it arrived 22nd!!
initially had trouble finding a suitable usb 3 port on my SFF computer, not many to choose from, but got there
I'm now on my second day of burning and backing up 3D/4K movies
order with confidence guys, top notchy seller, loving my mini burner
