Public KeyDB Disc Submissions
banz0
#961 Post by banz0 » Thu Nov 13, 2025 8:49 pm
MrPenguin wrote:
Thu Nov 13, 2025 2:14 pm
banz0 wrote:
Thu Nov 13, 2025 1:43 pm
This one still isn't working. Not sure if it's because I did rename the file when I put it into my Dropbox. The file that MakeMKV creates is named "MKB20_v82_UHD_SPT2_87EA.tgz".
Yep that was it. I thought MakeMKV would grab the new keys automatically. Thanks!
MrPenguin
#962 Post by MrPenguin » Fri Nov 14, 2025 12:16 am
[I thought MakeMKV would grab the new keys automatically. Thanks!
MakeMKV does download its keys automatically :). The KEYDB.cfg file is an alternative key database which MakeMKV can use, if you provide it with a copy. In this case KEYDB has managed to acquire your key before MakeMKV's own "hashed keys" database, which allows you to unlock your disk earlier.
chainmode
#963 Post by chainmode » Fri Nov 14, 2025 2:20 am
The Life of Chuck
Disc type: BD
Disc dump filename: MKB_v82_The_Life_of_Chuck_BB41.tgz
Drive: Polaroid BD162
Drive firmware: Unknown
LibreDrive status: Unknown
MKB_RO.inf link: https://drive.google.com/file/d/1Vo55Am ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1hQlKga ... sp=sharing
Apologies for the unknowns above. I'm using an external USB drive on macOS Sequoia.
MakeMKV reported, "This disc uses newer version of AACS protection."
From MakeMKV Disc Information: Protection: AACS v82
DiscSeeker
#964 Post by DiscSeeker » Fri Nov 14, 2025 6:47 am
Captain Scarlet and the Mysterons – The Complete Series [Imprint] (Australia)
Disc type: BD
Disc dump filename/s: MKB_v82_Captain_Scarlet_and_the_Mysterons_D[1–5]_XXXX.tgz
Drive: BD-RE HL-DT-ST WH16NS60
Drive firmware: 1.03
LibreDrive status: Enabled
Disc dump link: https://drive.proton.me/urls/3NGM1GJC00#pcPVAsCPuT22
This is the newly released Imprint set, not to be confused with any of the existing Blu‐ray releases.
roncole
#965 Post by roncole » Fri Nov 14, 2025 8:51 am
Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
Das Öffnen der Disk schlug fehl.
https://www.mediafire.com/file/g3j0mpm6 ... C.tgz/file
keydb_helper
#966 Post by keydb_helper » Fri Nov 14, 2025 11:57 am
Thanks to everyone who provided new disc dumps. It is also great to see the submission template being followed so well. All submitted UHD disc dumps have been added to the public keydb. The following titles corresponded to new media keys:
MKB20_v82_Barry_Lyndon_EC36
MKB20_v82_MaXXXine_UHD_1F48
MKB20_v82_Nobody_2_E81A
MKB20_v82_Out_of_Africa_9BE2
MKB20_v82_Pearl_UHD_1758
MKB20_v82_The_New_Avengers_-_S1_D5_7808
MKB20_v82_Ticks_65DA
MrPenguin
#967 Post by MrPenguin » Fri Nov 14, 2025 12:29 pm
mikehadfield wrote:
Mon Nov 10, 2025 10:25 pm
Dump file for The New Avengers (TV Series) - Disc 1
This dump isn't usable because it was not created from the original UHD disk. It looks like you have copied the files to your hard drive, and then created a TGZ dump file from that, which unfortunately means it is missing some important metadata.
Can you create a new dump from the actual disk please?
MrPenguin
#968 Post by MrPenguin » Fri Nov 14, 2025 12:35 pm
I've uploaded a dump file created direct from disc using Asus drive
Thanks for doing this. Can you also do the same for Disc 1 please, because the dump already provided for Disc 1 is also unusable for the same reason :(.
Chris01992
#969 Post by Chris01992 » Fri Nov 14, 2025 1:31 pm
Life of Chuck (UK UHD)
Disc type: UHD
Disc dump filename: MKB20_v82_The_Life_of_Chuck_9D18
Drive: LG BU40N
Drive firmware: 1.03 - Patched (microcode access re-enabled)
MKB_RO.inf link: [Not sure where to find this on MacOS]
Disc dump link: https://drive.google.com/file/d/1GsDFtN ... share_link
mikehadfield
#970 Post by mikehadfield » Fri Nov 14, 2025 2:17 pm
Sorry about that. I submitted the first disc and then ripped the rest of the discs in backup mode ready for when keys became supported. I didn't realise that the key would be missing if not ripped direct from the disc instead of from opening the backup on a drive. I've sorted it now and here is the proper file from the disc.
https://1drv.ms/u/c/a327df9983fec5c5/ET ... A?e=gvc9Ux
Mike
keydb_helper
#971 Post by keydb_helper » Fri Nov 14, 2025 2:26 pm
Thank you both for following the submission template. Your discs have been added to the public keydb.
Don't post disc dump files generated with the BDR-UD04 (Pioneer Verbatim 43888) to this thread. The obfuscation in LibreDrive makes those disc dump files useless to everyone outside of the MakeMKV team.
If you have a suitable LG/Asus drive feel free to generate a new disc dump file and post it to this thread.
keydb_helper
#972 Post by keydb_helper » Fri Nov 14, 2025 2:29 pm
Mike
Hey Mike, S1D5 was added to the public keydb a few hours ago. Grab the latest public keydb and you'll be good to go. If you have any issues with the other discs feel free to generate new disc dumps from the actual discs and post them to this thread.
MrPenguin
#974 Post by MrPenguin » Fri Nov 14, 2025 3:27 pm
Thanks for this :). Could you also recreate the TGZ dump for your Disk 1 please? And perhaps also provide dumps for Disks 2-4 as well?
stampie
#975 Post by stampie » Fri Nov 14, 2025 3:35 pm
Disc 1 was detected fine with me, so I assume a working hashkey must already be present in MakeMKV, but not yet in Keydb.cfg.
I don't see an option to manually create a dump file.
Are you sure that the option to allow MakeMKV to access the internet is enabled?
