Public KeyDB Disc Submissions
Lightyear
#901 Post by Lightyear » Thu Nov 06, 2025 10:15 am
Disc type: UHD
Disc dump filename: MKB20_v82_Crocodile_Dundee_2_584C
Drive: WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
Disc dump link: https://drive.google.com/file/d/1uHFiF4 ... drive_link
keydb_helper
#902 Post by keydb_helper » Thu Nov 06, 2025 10:54 am
99gagamel wrote: Thu Nov 06, 2025 10:09 am Disc-Dump-Dateiname: MKB20_v66_HALLOWEEN_18_0ED5,tgz
Hey 99gagamel, thank you for following the submission template. Your disc has been added to the public keydb.
crazy_horse9af4
#903 Post by crazy_horse9af4 » Thu Nov 06, 2025 1:27 pm
Disc type: UHD
Disc dump filename: MKB20_v76_The_Suicide_Squad_DEE1
Drive: BU40N
Drive firmware: 1.03
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://www.mediafire.com/folder/1y1hin ... cide_Squad
Disc dump link: https://www.mediafire.com/folder/1y1hin ... cide_Squad
keydb_helper
#904 Post by keydb_helper » Thu Nov 06, 2025 1:53 pm
crazy_horse9af4 wrote: Thu Nov 06, 2025 1:27 pm Disc dump filename: MKB20_v76_The_Suicide_Squad_DEE1
Hey crazy_horse9af4, thank you for following the submission template and remembering to include the MKB_RO.inf file. Your disc has been added to the public keydb.
zaqqaz6917
#905 Post by zaqqaz6917 » Thu Nov 06, 2025 3:09 pm
I just want to ask for clarification....
The MKB_RO is required only when the dump is less than 3mb or do you want it with every dump submission going forward?
Great job and thanks for help and your valuable time you have graciously put into this project
MrPenguin
#906 Post by MrPenguin » Thu Nov 06, 2025 3:21 pm
zaqqaz6917 wrote: Thu Nov 06, 2025 3:09 pm The MKB_RO is required only when the dump is less than 3mb or do you want it with every dump submission going forward?
Technically, speaking the MKB_RO file is only needed when the copy of this file inside the TGZ dump has been truncated to only 56 bytes. The MKB_RO file is very large for UHD disks, and so truncating it will make the TGZ dump file much smaller. For ordinary BD disks, the MKB_RO file is small anyway and I've never known MakeMKV to truncate it. Most likely, the TGZ dump for an ordinary BD contains the full MKB_RO and is still < 3MB in size, which means you don't need to provide the MKB_RO file separately.
To be super technical, look at the dump's 4-character variant code: If this code is even then MakeMKV has not truncated the MKB_RO file. However, if it is odd then the MKB_RO file inside has been truncated, and so you would need to provide the MKB_RO file from the UHD disk separately.
odes1
#907 Post by odes1 » Thu Nov 06, 2025 8:34 pm
Disc type: UHD
Disc dump filename: MKB20_v77_Enter_The_Dragon_1439.tgz
Drive: LG WH16NS60
MKB_RO.inf link: <Link>
Disc dump link: https://drive.google.com/file/d/1d8uB4P ... sp=sharing
MrPenguin
#908 Post by MrPenguin » Thu Nov 06, 2025 9:41 pm
odes1 wrote: Thu Nov 06, 2025 8:34 pm LibreDrive status: Enabled
This disk is already in the KEYDB file. MakeMKV was unable to decrypt it because your drive failed to enable LibreDrive.
Run3!
#909 Post by Run3! » Thu Nov 06, 2025 11:26 pm
Disc type: UHD
Disc dump filename: MKB20_v82_Hard_Boiled_BAF2.tgz
Drive: WH16NS60
Disc dump link: https://drive.google.com/file/d/15lIDke ... sp=sharing
roncole
#910 Post by roncole » Fri Nov 07, 2025 3:01 am
keydb_helper
#911 Post by keydb_helper » Fri Nov 07, 2025 3:33 am
Lightyear wrote: Thu Nov 06, 2025 10:14 am Disc dump filename: MKB20_v82_Crocodile_Dundee_-_The_Encore_Cut_CCBE
Lightyear wrote: Thu Nov 06, 2025 10:15 am Disc dump filename: MKB20_v82_Crocodile_Dundee_2_584C
Thanks for following the submission template Lightyear, both of your discs have been added to the public keydb.
zaqqaz6917 wrote: Thu Nov 06, 2025 3:09 pm I just want to ask for clarification....
Feel free to always include the MKB_RO.inf file. It never hurts to have it. As Mr Penguin noted, providing the MKB_RO.inf can be skipped when the disc dump file contains the entire MKB_RO.inf file, but I'm not going to try to spell this distinction out to users.
Run3! wrote: Thu Nov 06, 2025 11:26 pm Disc dump filename: MKB20_v82_Hard_Boiled_BAF2.tgz
What the fuck... Your variant of Hard Boiled was added to the public keydb over a week ago. Please don't just blindly copy the example submission.
99gagamel
#912 Post by 99gagamel » Fri Nov 07, 2025 7:33 am
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v77_The_Core_(Remastered)_B58D,tgz
Laufwerk: BH16NS55
Laufwerks-Firmware: 1.05
Haben Sie die öffentliche Schlüsseldatenbank in den letzten 15 Minuten synchronisiert? Ja
Haben Sie überprüft, ob alle Einreichungslinks im Inkognito-/Privatmodus erreichbar sind? Ja
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/1JXcRNx ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/1qfz1z7 ... sp=sharing
99gagamel
#913 Post by 99gagamel » Fri Nov 07, 2025 8:35 am
"The_Core_(Remastered)"
[/quote]
MrPenguin
#914 Post by MrPenguin » Fri Nov 07, 2025 8:39 am
roncole wrote: Fri Nov 07, 2025 3:01 am Naked Gun 2 no keys yet
Unfortunately, this dump file was created using a Verbatim 43888 containing a Pioneer BDR-UD04 device, which means its metadata is unreadable by The Powers That KEYDB :(. Would you happen to have access to a different UHD drive please?
MKVDUDE
#915 Post by MKVDUDE » Fri Nov 07, 2025 1:17 pm
Disc type: UHD
Disc dump filenames:
MKB20_v82_Teenage_Mutant_Ninja_Turtles_-_UHD_B464
MKB20_v82_Teenage_Mutant_Ninja_Turtles_II-_The_Secret_of_the_Ooze_B6D2
MKB20_v82_Teenage_Mutant_Ninja_Turtles_III_-_UHD_4276
Drive: BD-RE BU40N
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-9qWBiQoxdp
Many thanks!
