Public KeyDB Disc Submissions
Disc type: UHD
Disc dump filename: MKB20_v82_Crocodile_Dundee_2_584C
Drive: WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
Disc dump link: https://drive.google.com/file/d/1uHFiF4 ... drive_link
Drive: WH16NS60
keydb_helper
Hey 99gagamel, thank you for following the submission template. Your disc has been added to the public keydb.
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
crazy_horse9af4
Disc type: UHD
Disc dump filename: MKB20_v76_The_Suicide_Squad_DEE1
Drive: BU40N
Drive firmware: 1.03
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://www.mediafire.com/folder/1y1hin ... cide_Squad
Disc dump link: https://www.mediafire.com/folder/1y1hin ... cide_Squad
Drive: BU40N
keydb_helper
Hey crazy_horse9af4, thank you for following the submission template and remembering to include the MKB_RO.inf file. Your disc has been added to the public keydb.crazy_horse9af4 wrote: ↑Thu Nov 06, 2025 1:27 pmDisc dump filename: MKB20_v76_The_Suicide_Squad_DEE1
zaqqaz6917
I just want to ask for clarification....
The MKB_RO is required only when the dump is less than 3mb or do you want it with every dump submission going forward?
Great job and thanks for help and your valuable time you have graciously put into this project
Technically, speaking the MKB_RO file is only needed when the copy of this file inside the TGZ dump has been truncated to only 56 bytes. The MKB_RO file is very large for UHD disks, and so truncating it will make the TGZ dump file much smaller. For ordinary BD disks, the MKB_RO file is small anyway and I've never known MakeMKV to truncate it. Most likely, the TGZ dump for an ordinary BD contains the full MKB_RO and is still < 3MB in size, which means you don't need to provide the MKB_RO file separately.zaqqaz6917 wrote: ↑Thu Nov 06, 2025 3:09 pmThe MKB_RO is required only when the dump is less than 3mb or do you want it with every dump submission going forward?
To be super technical, look at the dump's 4-character variant code: If this code is even then MakeMKV has not truncated the MKB_RO file. However, if it is odd then the MKB_RO file inside has been truncated, and so you would need to provide the MKB_RO file from the UHD disk separately.
Disc type: UHD
Disc dump filename: MKB20_v77_Enter_The_Dragon_1439.tgz
Drive: LG WH16NS60
MKB_RO.inf link: <Link>
Disc dump link: https://drive.google.com/file/d/1d8uB4P ... sp=sharing
Drive: LG WH16NS60
This disk is already in the KEYDB file. MakeMKV was unable to decrypt it because your drive failed to enable LibreDrive.
Disc type: UHD
Disc dump filename: MKB20_v82_Hard_Boiled_BAF2.tgz
Drive: WH16NS60
Disc dump link: https://drive.google.com/file/d/15lIDke ... sp=sharing
Drive: WH16NS60
keydb_helper
Thanks for following the submission template Lightyear, both of your discs have been added to the public keydb.
Feel free to always include the MKB_RO.inf file. It never hurts to have it. As Mr Penguin noted, providing the MKB_RO.inf can be skipped when the disc dump file contains the entire MKB_RO.inf file, but I'm not going to try to spell this distinction out to users.zaqqaz6917 wrote: ↑Thu Nov 06, 2025 3:09 pmI just want to ask for clarification....
What the fuck... Your variant of Hard Boiled was added to the public keydb over a week ago. Please don't just blindly copy the example submission.
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v77_The_Core_(Remastered)_B58D,tgz
Laufwerk: BH16NS55
Laufwerks-Firmware: 1.05
Haben Sie die öffentliche Schlüsseldatenbank in den letzten 15 Minuten synchronisiert? Ja
Haben Sie überprüft, ob alle Einreichungslinks im Inkognito-/Privatmodus erreichbar sind? Ja
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/1JXcRNx ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/1qfz1z7 ... sp=sharing
Laufwerk: BH16NS55
"The_Core_(Remastered)"
[/quote]
Danke
[/quote]
Danke
Unfortunately, this dump file was created using a Verbatim 43888 containing a Pioneer BDR-UD04 device, which means its metadata is unreadable by The Powers That KEYDB
Disc type: UHD
Disc dump filenames:
MKB20_v82_Teenage_Mutant_Ninja_Turtles_-_UHD_B464
MKB20_v82_Teenage_Mutant_Ninja_Turtles_II-_The_Secret_of_the_Ooze_B6D2
MKB20_v82_Teenage_Mutant_Ninja_Turtles_III_-_UHD_4276
Drive: BD-RE BU40N
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-9qWBiQoxdp
Many thanks!
Drive: BD-RE BU40N
Many thanks!
