SDF update November 2025
Unplanned9977
Re: SDF update November 2025
Cooking with gas now!
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.04
Serial number:
Firmware date: 2024-10-09
Highest AACS version: 77
Drive platform: RS9331
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.04/ID05
Disc Information
Label: TENET
Timestamp: 2020-11-19 16:07:35
Protection: AACS2.0/C v76
Data capacity: 93.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Great job Mike!
Revision: 1.04
Serial number:
Disc Information
Label: TENET
Number of layers: 3
Great job Mike!
WORKING!
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: CIDL015660UC
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 82
Drive platform: RS8E21
Firmware version: 1.03/ID05
Thank you to Mike Admin (what a fortunate name to be born with, as administrator of this board). You came through again. Thanks also to the not so fortunately named MartyMcNuts, for additional information and instructions.
Revision: 1.03
standforme
OS device name: L:
Revision: 1.02
Serial number: DDDL001716UC
Firmware date: 2022-12-27
Drive platform: RS9330
Firmware version: 1.02
Disc Information
Disc is being loaded
This is not a UHD model. It cannot read UHD discs. Libredrive does not equal UHD readability.jayper wrote: ↑Thu Nov 06, 2025 12:24 amHaving an interesting experience with this drive. I'm seeing that Libredrive is enabled, however, I can't actually get a UHD disc to load or open. It remains stuck in a "disc loading" state. No disc specific information is loaded in the right-hand info pane and I am never able to engage the decrypt button. Standard BDs will load fine, and will decrypt. A FW dump was sent in yesterday. My other drives submitted are working fine.Code: Select all
Drive Information OS device name: L: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD08 Revision: 1.02 Serial number: DDDL001716UC Firmware date: 2022-12-27 Bus encryption flags: 1B Highest AACS version: 82 LibreDrive Information Status: Enabled Drive platform: RS9330 Firmware name: PIONEER BDR-BDS8 Firmware type: Original (unpatched) Firmware version: 1.02 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes Disc Information Disc is being loaded
Hah! Well that explains it... I've had it laying around for quite a while and completely forgot that detail. Thanks Marty!MartyMcNuts wrote: ↑Thu Nov 06, 2025 12:49 amThis is not a UHD model. It cannot read UHD discs. Libredrive does not equal UHD readability.
Lookin good, thanks for your hard work Mike!
Revision: 1.04
Serial number: CADL300210UC
Highest AACS version: 19
My XD08U and XS07U are now working! Thanks Mike!!
My XD07U, however, is still not enabled. I emailed the firmware to support@makemkv.com yesterday.
OS device name: I:
Product: BD-RW BDR-XD07U
Revision: 1.05
Serial number: CCDL910053WL
Drive platform: Pioneer RS8D31
Firmware version: ID05
OS device name: I:
Revision: 1.05
Confirming my BDR-XS07U now works!
Thanks,
Frank
Thanks,
Frank
For sale:
4K UHD Desktop LG Drives, 4K UHD Buffalo Branded Slim LG Drives, 4K UHD LG Branded Slim LG Drives,
drives@nicholasfamilycentral.com
Check first post of each For Sale thread for current/updated availability!
SDF downloaded automatically. No UHD functionality yet.Drive Information
OS device name: E:
Product: BD-RW BDR-X13
Revision: 1.01
Serial number:
Firmware date: 2022-02-18
Highest AACS version: 81
Drive platform: Pioneer RS9400
Firmware version: ID56
To be fair, the firmware with ID56 was not in the list of supported firmwares as of now anyways.
Anything i can do from my side to support the process?
Any chance cross-flashing will ever be a possibility?MartyMcNuts wrote: ↑Thu Nov 06, 2025 12:49 amThis is not a UHD model. It cannot read UHD discs. Libredrive does not equal UHD readability.jayper wrote: ↑Thu Nov 06, 2025 12:24 amHaving an interesting experience with this drive. I'm seeing that Libredrive is enabled, however, I can't actually get a UHD disc to load or open. It remains stuck in a "disc loading" state. No disc specific information is loaded in the right-hand info pane and I am never able to engage the decrypt button. Standard BDs will load fine, and will decrypt. A FW dump was sent in yesterday. My other drives submitted are working fine.Code: Select all
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• PANASONIC SW-9576-C
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
This is wonderful news! Thank you and great work to everyone involved.
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
OS device name: /dev/rdisk4
Current profile: BD-R SRM
Revision: 1.03
Serial number: CGDL009631UC
Drive platform: RS8E20
Disc Information
Label: THE_MATRIX
Timestamp: 2025-08-25 00:11:33
Data capacity: 58.57 Gb4K UHD is not working which is expected.
Custom burned 4k disc made from ripped ISO does work though, most likely due to the ISO encryption being cracked before burning onto the BD-R XL.
Overall very satisfied. I have plenty of other drives that I can rip UHD with, and I am still holding out hope that such a thing will be made possible on my XS07S with a future patch.
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
OS device name: /dev/sr1
Revision: 1.02
Serial number: --redacted--
Firmware version: 1.02/ID05
Unrestricted read speed: YesRe: SDF update November 2025
Pioneer BDR-XS08MB-S here!!!
WORKS LIKE A CHARM RIPPING UHDs!
THANK YOU SO SO SO SO MUCH!
