Public KeyDB Disc Submissions
MrPenguin
Post by MrPenguin » Thu Oct 30, 2025 10:23 pm
crazy_horse9af4 wrote:
Thu Oct 30, 2025 9:21 pm
I put the dumps of all three discs in my initial post. And yes the working one is Deadpool 3.
Thanks, but those dumps were created without LibreDrive being enabled, and so they do not contain some important metadata :(.
Has MakeMKV created new TGZ dumps for "Deadpool" and "Deadpool 2" now that LibreDrive is enabled? In which case, can you upload them as well please? (We'd only need the new TGZ files of course, because the MKB_RO.inf files will not have changed :).)
DavidF
Post by DavidF » Fri Oct 31, 2025 1:38 am
Title: A Star Is Born (2018) UHD 4K
Dump filename: MKB20_v66_A_STAR_IS_BORN_2018_0331.tgz
Region: [USA]
MakeMKV: v1.18.2 (Windows), LibreDrive Enabled
Physical disc: Yes (on hand)
Notes: Please add key to KEYDB.cfg if available.
DavidF
Post by DavidF » Fri Oct 31, 2025 1:40 am
Title: Aquaman (UHD 4K)
Dump filename: MKB20_v68_AQUAMAN_5D07.tgz
Region: [USA]
DavidF
Post by DavidF » Fri Oct 31, 2025 1:41 am
Title: Batman v Superman: Dawn of Justice – Ultimate Edition (UHD 4K)
Dump filename: MKB20_v61_BATMAN_V_SUPERMAN_UE_945F.tgz
Region: [USA]
DavidF
Post by DavidF » Fri Oct 31, 2025 1:42 am
Title: Wonder Woman (UHD 4K)
Dump filename: MKB20_v61_WONDER_WOMAN_7A97.tgz
Region: [USA]
DavidF
Post by DavidF » Fri Oct 31, 2025 1:43 am
Title: The Greatest Showman (UHD 4K)
Dump filename: MKB20_v61_THE_GREATEST_SHOWMAN_2D95.tgz
Region: [USA]
DavidF
Post by DavidF » Fri Oct 31, 2025 1:44 am
Title: Bohemian Rhapsody (UHD 4K)
Dump filename: MKB20_v66_BOHEMIAN_RHAPSODY_65F1.tgz
Region: [USA]
crazy_horse9af4
Post by crazy_horse9af4 » Fri Oct 31, 2025 5:57 am
Ok, I created new dumps. However, the drive information and firmware I didn't change from my first attempt as it indicates that LibreDrive is running.
Disc type: UHD
Disc dump filename Deadpool: MKB20_v60_Deadpool_4237
Disc dump filename Deadpool 2: MKB20_v65_Deadpool_2_4AD7
Drive:BU40N
Drive firmware:1.03
MKB_RO.inf / disk dump link: https://www.mediafire.com/folder/izr130 ... pool_dumps
Some info on my drive, just to be sure:
OS device name: X:
Product: BD-RE BU40N
Revision: 1.03
Serial number: xxx
Highest AACS version: 77
Firmware version: 1.03
Disc Information
Label: DEADPOOL 2
Timestamp: 2018-08-13 19:02:12
Protection: AACS2.0/C v65
Data capacity: 57.56 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Post by dcoke22 » Fri Oct 31, 2025 2:22 pm
Region: [USA]
You should fix your posts to include a link to the dump file. Use Google Drive, Dropbox, or wherever you like. Additionally, email the dump files to svq@makemkv.com.
koberulz
Post by koberulz » Fri Oct 31, 2025 5:36 pm
tommik128
Post by tommik128 » Sat Nov 01, 2025 12:35 am
Is MKB_RO.inf link really needed for MKB_v82 1080p standard blu-rays? I refer to my last post where I posted dumps from LibreDrive Pioneer 212-EBK WITHOUT MKB_RO.inf and it worked that way.
jharle
Post by jharle » Sat Nov 01, 2025 5:50 am
Disc type: BD-ROM
Disc dump filename: MKB_v82_The_Who_-_Who_Are_You_C17E.tgz
Drive: BUFFALO BU12
Drive firmware: 0.BU12O
MKB_RO.inf link: https://tutone2.org/videos/.hidden/MKB_RO.inf
Disc dump link: https://tutone2.org/videos/.hidden/MKB_ ... u_C17E.tgz
MrPenguin
Post by MrPenguin » Sat Nov 01, 2025 12:44 pm
No, it should only be needed when MakeMKV truncates the MKB_RO.inf file inside the TGZ dump, and I've only ever known MakeMKV to do this for UHD disks. I think the dump's variant code is a clue: if it's even then the MKB_RO.inf file is complete, whereas if it's odd then MKB_RO.inf been truncated.
keydb_helper
Post by keydb_helper » Sat Nov 01, 2025 10:29 pm
Thanks to everyone who provided new disc dumps. All posted BD & UHD titles have been added to the public keydb. The following UHD disc variants were new additions to the keydb:
mkb20_v82_americanpsycho_faea
MKB20_v82_Hard_Boiled_BAF2
MrPenguin is correct that the MKB_RO.inf file should only be provided separately when the MakeMKV disc dump contains a truncated MKB_RO.inf file. My prior comments regarding the ~3MB size threshold for requiring the MKB_RO.inf file were intended for AACS2.0 discs which typically have much larger MKB files.
AACS1.0 discs can still be processed and submitted to the keydb when the disc dump is in the 50-150KB range but this is only possible because the full AACS1.0 MKB_RO.inf file is present within the disc dump.
Region: [USA]
Hi David, I appreciate the effort but your posts do not assist with adding support for your discs to the public keydb. You didn't provide links to the disc dump files so no one can download them. In the future, please follow the template in my opening post rather than creating your own template...
Thu Oct 30, 2025 2:20 pm
Disc type: UHD
Disc dump filename Deadpool & Wolverine: MKB20_v77_MARVEL_STUDIOS'_DEADPOOL_AND_WOLVERINE_FB39
Drive:BU40N
Drive firmware:1.03
MKB_RO.inf / disk dump link: ...
Disc type: BD-ROM
Drive: BUFFALO BU12
MKB_RO.inf link: ...
Disc dump link: ...
Thanks for following the template crazy_horse9af4 and jharle!
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
jharle
Post by jharle » Sun Nov 02, 2025 1:15 am
Cheers!
I was able to create a backup of the BD! :D
