Dump Submitted - The Sound of Music 4K
chucky527c
MKB20_v77_The_Sound_of_Music_8E44.tgz
Re: Dump Submitted - The Sound of Music 4K
The 0800 has conventional subtitles and supplementary audio tracks. It looks like the sing-a-long subtitles are specific to the 0700. To get the most ideal result you have to make an mkv from both and then use a tool like MKVToolNix to add the subtitles from 0700 to the file for 0800.
bbraskey67
Anyone else having trouble ripping this disc? I've purchased two copies and neither one has worked. I tried cleaning them both thoroughly, but no luck. It gets about half way through then I get a bunch of errors. I'm using a Pioneer BR-S13U-X that I purchased from a member here.
Submitted a dump for the MKB20_v77_THE_SOUND_OF_MUSIC_BCE8.tgz version.
I haven't, but today it works so either my version was added or yesterday MakeMKV didn't download the latest version of the tile (which it usually does), anyway - works
Same problem here, it gives me an error at the end of dumping. I'm using a Pioneer BDR-212 and this is the first disc out of several dozen that has failed to dumpbbraskey67 wrote: Tue Oct 28, 2025 1:22 am Anyone else having trouble ripping this disc? I've purchased two copies and neither one has worked. I tried cleaning them both thoroughly, but no luck. It gets about half way through then I get a bunch of errors. I'm using a Pioneer BR-S13U-X that I purchased from a member here.
bbraskey67
After doing a bit of Googling, it appears that this is a common issue. Apparently there was batch of discs sent out that were damaged/defective. I've ordered another copy that should arrive on Friday. We'll see if that one has the same issue.
The disc was indeed defective, I let it run in my Sony player in the background and it always stops at 1:56:39. It's a shame since the 4k itself looked great whenever I checked in on itbbraskey67 wrote: Tue Nov 04, 2025 9:46 pm After doing a bit of Googling, it appears that this is a common issue. Apparently there was batch of discs sent out that were damaged/defective. I've ordered another copy that should arrive on Friday. We'll see if that one has the same issue.
bbraskey67
My third copy of the movie arrived today and was finally able to rip it. No errors this time. I guess third time's a charm.
burningfool
I just bought this. I'll run it this weekend to make sure it plays OK. Thanks for all the info here.
