Dump Submitted - The Sound of Music 4K
chucky527c
Post by chucky527c »
MKB20_v77_The_Sound_of_Music_8E44.tgz
outlier
Re: Dump Submitted - The Sound of Music 4K
Post by outlier »
The 0800 has conventional subtitles and supplementary audio tracks. It looks like the sing-a-long subtitles are specific to the 0700. To get the most ideal result you have to make an mkv from both and then use a tool like MKVToolNix to add the subtitles from 0700 to the file for 0800.
bbraskey67
Post by bbraskey67 »
Anyone else having trouble ripping this disc? I've purchased two copies and neither one has worked. I tried cleaning them both thoroughly, but no luck. It gets about half way through then I get a bunch of errors. I'm using a Pioneer BR-S13U-X that I purchased from a member here.
VarHD
Post by VarHD »
Submitted a dump for the MKB20_v77_THE_SOUND_OF_MUSIC_BCE8.tgz version.
MrPenguin
Post by MrPenguin »
VarHD wrote: Wed Oct 29, 2025 4:46 pm Submitted a dump for the MKB20_v77_THE_SOUND_OF_MUSIC_BCE8.tgz version.
Have you tried the latest KEYDB.cfg file? It already contains a few entries for this title.
VarHD
Post by VarHD »
I haven't, but today it works so either my version was added or yesterday MakeMKV didn't download the latest version of the tile (which it usually does), anyway - works :)
NFAnders
Post by NFAnders »
bbraskey67 wrote: Tue Oct 28, 2025 1:22 am Anyone else having trouble ripping this disc? I've purchased two copies and neither one has worked. I tried cleaning them both thoroughly, but no luck. It gets about half way through then I get a bunch of errors. I'm using a Pioneer BR-S13U-X that I purchased from a member here.
Same problem here, it gives me an error at the end of dumping. I'm using a Pioneer BDR-212 and this is the first disc out of several dozen that has failed to dump
bbraskey67
After doing a bit of Googling, it appears that this is a common issue. Apparently there was batch of discs sent out that were damaged/defective. I've ordered another copy that should arrive on Friday. We'll see if that one has the same issue.
NFAnders
Post by NFAnders »
bbraskey67 wrote: Tue Nov 04, 2025 9:46 pm After doing a bit of Googling, it appears that this is a common issue. Apparently there was batch of discs sent out that were damaged/defective. I've ordered another copy that should arrive on Friday. We'll see if that one has the same issue.
The disc was indeed defective, I let it run in my Sony player in the background and it always stops at 1:56:39. It's a shame since the 4k itself looked great whenever I checked in on it
bbraskey67
My third copy of the movie arrived today and was finally able to rip it. No errors this time. I guess third time's a charm.
burningfool
Post by burningfool »
I just bought this. I'll run it this weekend to make sure it plays OK. Thanks for all the info here.
