AACS V82 for The Toxic Avenger Unrated
questinghero
Post by questinghero »
I have emailed the file to svq at makemkv.com and I have also attached the file below.
Update: Google drive link https://drive.google.com/file/d/1uH_qLi ... sp=sharing
Re: AACS V82 for The Toxic Avenger Unrated
questinghero wrote: Tue Oct 28, 2025 2:53 pm I have emailed the file to svq at makemkv.com and I have also attached the file below.
Attaching dumps to posts rarely works since the forum doesn't allow for much space for attachments. It is best to put the dump on the internet somewhere (Google Drive, One Drive, Dropbox, etc.) and post a sharing link so it can be added to the keyDB.
questinghero
dcoke22 wrote: Tue Oct 28, 2025 3:15 pm
I assumed emailing the file was good enough, and was just posting it to make sure. Here is a google drive link if that helps. https://drive.google.com/file/d/1uH_qLi ... sp=sharing
By default, MakeMKV uses the hashed keys mechanism for decrypting 4K UHDs and AACS v82 blu-ray discs. Emailing the dump file MakeMKV produces to svq@makemkv.com is the right thing to do.
MakeMKV supports a separate key mechanism, the Public KeyDB. Making the dump available on the internet for them to download is a way to get the necessary key into the keyDB as well.
questinghero
dcoke22 wrote: Tue Oct 28, 2025 7:47 pm By default, MakeMKV uses the hashed keys mechanism for decrypting 4K UHDs and AACS v82 blu-ray discs. Emailing the dump file MakeMKV produces to svq@makemkv.com is the right thing to do.
Should I notify Public KeyDB about it, or is the link I posted good enough?
MrPenguin
Post by MrPenguin »
questinghero wrote: Tue Oct 28, 2025 7:57 pm Should I notify Public KeyDB about it, or is the link I posted good enough?
Does the latest KEYDB.cfg file contain your disk? Because if so, I suspect this was good enough ;).
questinghero
So, I have not had to mess with the Public KeyDB before, but that is kinda awesome. Key was already added, I downloaded the file and placed it in the data directory in my docker image, and it just works. I am really impressed.
