Zombi Holocaust UK dump submitted
unclecuddles
Post by unclecuddles »
MrPenguin
Re: Zombi Holocaust UK dump submitted
Post by MrPenguin »
unclecuddles wrote:
Mon Oct 27, 2025 6:11 pm
Unfortunately, this TGZ dump file was created using one of the Pioneer drive models that cannot provide KEYDB with any usable metadata :(. Would you also happen to have access to an LG/ASUS/Buffalo drive please? Failing that, could you at least upload the AACS/MKB_RO.inf file from your physical UHD disk into (say) OneDrive of Google Drive please, and then reply with a public download link? The copy of this file inside your TGZ dump file has been truncated to only 56 bytes, which also makes it unusable to KEYDB.
The Powers That KEYDB would only need the LG drive to create the dump file. Obviously you would still use your Pioneer actually to rip the disk :).
unclecuddles
Bummer, I just got this drive because my old drive struggled to read this disc.
Link to MKB_RO.inf
https://1drv.ms/u/c/913358f6cc9c5607/EQ ... A?e=go3Nt0
MrPenguin
Post by MrPenguin »
unclecuddles wrote:
Tue Oct 28, 2025 6:40 pm
Thanks for the MKB_RO.inf file. Your new drive is fine for ripping disks, but your original LG drive is still useful for generating discatt.dat files. If your LG drive can still at least show this disk in Windows Explorer then that should be enough, even if it cannot rip it.
